PlayStation 4 - Page 325 - AVS Forum | Home Theater Discussions And Reviews
 1451Likes
post #9721 of 21079 Old 11-20-2013, 06:54 AM
rolltide1017's Avatar
Quoted: 238 Post(s)
Liked: 363
Originally Posted by Smigro View Post
I really hope it helps with the crashing issues on BF4...although I have my doubts it will.
I doubt a system patch will do anything for BF4, that will have to come from DICE.
PSN ID: RollTide1017
rolltide1017 is offline
post #9722 of 21079 Old 11-20-2013, 06:54 AM
TyrantII's Avatar
Liked: 833
So quick question, I thought game patches were supposed to download/install while in standby for plus members?
My PS4 was in standby since Monday night and when I turned it on last night it started downloading and then updated KZSF from 1.04 to 1.05. Apparently it didn’t do so while in standby.
I left it in standby today to see if the FW was downloaded when I get home. I assume it’ll never install those, since you need to accept the new TOS/EULA each time.
TyrantII is offline
post #9723 of 21079 Old 11-20-2013, 06:58 AM
samendolaro's Avatar
Quoted: 17 Post(s)
Liked: 304
I know Sony mentioned that it would download in Standby but not sure if it actually installs until it is out of standby.
samendolaro is offline
post #9724 of 21079 Old 11-20-2013, 06:58 AM
TyrantII's Avatar
Liked: 833
Originally Posted by s1njin View Post
Does Sony release a change log?
They do, but they also have a history of FW’s including undocumented fixes.
TyrantII is offline
post #9725 of 21079 Old 11-20-2013, 06:59 AM
newfmp3's Avatar
Quoted: 277 Post(s)
Liked: 252
well spent 20mins on dashboard, psn store using dummy account and so far so good since update. Won't get more time to test until tonight, but that's the longest I have had the system going without random freezes and shutdowns.
newfmp3 is offline
post #9726 of 21079 Old 11-20-2013, 07:04 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
As I understand it standby mode gives you faster time to dashboard and the ability to purchase and install games from a mobile device. Oh and controller charging. I'm pretty sure your system will still turn on in the early AM and do its patch/sync thing in the morning just like your PS3 used to if you were a PS Plus member. I'd have to check it to see, but this morning I had a IP Conflict on my iPad. I can only surmise my powered off PS4 booted at some point just like my PS3 did. My PS4 is currently not in standby.
DaverJ likes this.
Gaming hard from October thru April.
Samsung 60KS8000
Xbox One S
PS4 Pro
Astro A50s (2nd Gen)
s1njin is offline
post #9727 of 21079 Old 11-20-2013, 07:08 AM
SmokenAshes's Avatar
Liked: 53
Is there a way to delete your captured screenshots and videos on the PS4?
SmokenAshes is offline
post #9728 of 21079 Old 11-20-2013, 07:11 AM
lordxar5's Avatar
Quoted: 1158 Post(s)
Liked: 929
I thought that odd too. I had BF issues, go figure, and swapped over to KZ to be greeted by an update message.I'm wondering if it was either released outside the normal window or if that's why my PS4 was on when I got home. Though it only queued the patch when I entered the game.
lordxar5 is offline
post #9729 of 21079 Old 11-20-2013, 07:11 AM
Quoted: 1175 Post(s)
Liked: 969
Yes. I deleted over 6gb worth of stuff.
Settings and I believe its under Application Management or something like that. You will see whats taking up space and you can select the folder for the saved videos.
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #9730 of 21079 Old 11-20-2013, 07:21 AM
anthonymoody's Avatar
Quoted: 588 Post(s)
Liked: 417
So in the. Notifications, Downloads section, if I've highlighted something then hit the Options button I get the ability to Delete it. Will that Delete the file itself from the PS4 or just the item from the list? I ask because the list is rather long and getting cumbersome to navigate as I install multiple games, apps, and updates. I'd like to clean it up but don't want to inadvertently delete anything I want.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
post #9731 of 21079 Old 11-20-2013, 07:27 AM
TyrantII's Avatar
Liked: 833
It’s drawing way too much wattage for that, plus I thought that’s ½ the purpose of the whole ARM chipset, to download and install while in standby. The rest being to do so in the background while the OS/Games do their own thing unimpeded.
If it’s just booting and checking ad odd hours for updates, there’s really no reason to be powered up as much as it is while in standby.
TyrantII is offline
post #9732 of 21079 Old 11-20-2013, 07:28 AM
TyrantII's Avatar
Liked: 833
You can also get to it from your profile, third button to the right under the avatar. Use the options button while over a file to bring up a menu and you can delete it.
I keep forgeting, but options almost always gives you options for stuff like that (you can delete old notifications this way - it only deletes the notifications not the downloads / requests / ect).
After 20 years start and select are burned into my memory. Share and Options is taking a while to learn... I can only imagine how much a shock the Steam Contoller is going to be.
TyrantII is offline
post #9733 of 21079 Old 11-20-2013, 07:31 AM
Liked: 969
Is there a way to not have the PS4 always record? I dont remember seeing any setting for it.
emartins is offline
post #9734 of 21079 Old 11-20-2013, 07:33 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
Exactly why I'm not really bothering with putting it in standby. So far I'm only using standby when I know I'll hop back on it in a few hours. If I'm 'Done' with it for the day, I turn it off.
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
post #9735 of 21079 Old 11-20-2013, 07:35 AM
TyrantII's Avatar
Liked: 833
No, it's always recording a rolling 15 min to the DVR. Pressing record dumps the last 15 min to a file and creates a new start point.
There's no way to really do start or end points, just dump a recording since the last start point or 15 min buffered since then, which ever was first.
TyrantII is offline
post #9736 of 21079 Old 11-20-2013, 07:39 AM
TyrantII's Avatar
Liked: 833
I kind of wish there was a setting to go from standby to off, either with a button press or a setting after X min.
In Standby the fan still runs in a low RPM state, and if the unit was hot it’ll stay on high and ramp down until it’s blowing out cool air in that low state. That’s really nice on the APU when you compare it to a shutdown, which turns the fan off while the APU is still pretty hot.
Maybe they disabled auto-installing to relieve pressure on the servers; much like how the social features were turned off for a few days.
TyrantII is offline
post #9737 of 21079 Old 11-20-2013, 07:43 AM
s1njin's Avatar
Quoted: 321 Post(s)
Liked: 152
A buddy of mine (who is something of a gadget guru) swears that in standby the fan will eventually turn itself off. If this is actually the case I'm all for suspend as I agree; cooling down the components before turning everything down is probably a good thing. I will experiment with this the next time I'm gaming. I'll suspend it and see if the fan is still whirring the following morning.
Samsung 60KS8000
Xbox One S
PS4 Pro
s1njin is offline
post #9738 of 21079 Old 11-20-2013, 07:55 AM
BAMABLUHD's Avatar
Quoted: 71 Post(s)
Liked: 131
Yep, somehow I was able to play Rush last night for the first time, but still no Conquest, which is what I love. Game is crazy realistic. However, the game still crashed and I got an error message.
How do we know if the new PS4 update has been downloaded and/or installed?
LG 65B6 OLED 4K HDR| Pioneer ELITE VSX-52 | Samsung K8500 4K Blu Ray | Polk Audio RTi and CS2 5.1 | Video cables by Monoprice! Audio cables by Audioquest
PS4 | Apple TV | Sonos | Amazon Echo
BAMABLUHD is offline
post #9739 of 21079 Old 11-20-2013, 07:56 AM
kblee's Avatar
Quoted: 60 Post(s)
Liked: 73
Can someone please confirm my PS+ assumption for me? 2 of the games that I purchased came with 7-day trials. As I started 1 of them last Friday, it should expire tomorrow. I am leaving for my annual deer hunting trip on Friday and am hoping that, if I let it expire (I turned off auto billing to my CC), I can just load the other 7-day trial when I return. Then I have the 30-day trial from the console available when that runs out. I have already downloaded Resogun and Contrast. So - even if my PS+ expires temporarily, those will still be there for me as soon as I re-start my subscription, correct?
PSN = ChitownJackalope
Blackhawk Down(stairs) Theater
kblee is offline
post #9740 of 21079 Old 11-20-2013, 08:01 AM
Quoted: 238 Post(s)
Liked: 363
I'm going to buy an extended warranty (not because of all the failure reports, I do this for most of my expensive electronics) but, I can't decide if I want to buy the Sony extended warranty or go the SquareTrade route. Not sure if everyone is aware of this but, SquareTrade offers more plans and reduced rates on there warranties for Amazon purchases, you just search for and buy the warranty on Amazon instead of SquareTrade.com.
Here's some comaprisons:
All these plans start fromt eh date of purchase, not the end of the original manufacturer's warranty.
Sony Plans:
Protection Plan (3 yrs) = $49.99
Accidental Damage Protection Plan (3 yrs) = $59.99
SquareTrade Plans on Amazon:
2-Year Game Console Protection Plan ($350-400) = $32.62
4-Year Game Console Protection Plan ($350-400) = $74.99
3-Year Game Console Accident Protection Plan ($350-400) = $55.96
SquareTrade Plans from Squaretrade.com (http://www.squaretrade.com/videogames-warranty):
3-Year Protection Plan ($350-399.99) = $53.99
3-Year Accident Protection Plan ($350-399.99) = $79.99
This appears to be the only game console plan they offer on there website, the 2 and 4 year plans must be exclusive to Amazon.
Has anyone had to ever file a claim with SquareTrade, was there service good? I bought an extended warranty for my Panasonic BD player from SquareTrade but, I haven't had to file a claim for anything so far. I think I'm leaning towards either the Sony Accidental plan or the SquareTrade Accidental plan. I just need to decide if I'd rather deal with Sony or SquareTrade if warranty claims are ever needed. Obviously, if you didn't purchase your PS4 through Amazon then it looks like the Sony prices are the best.
Any thoughts?
Spanglo and Cravit8 like this.
post #9741 of 21079 Old 11-20-2013, 08:02 AM
TyrantII's Avatar
Liked: 833
I think it’s just so low you can’t tell. I pulled the console out of its place on my stand and couldn’t hear the fan with even my ear against it, but sure enough felt air on my face. Lick of the finger, and yup, a very very slight movement of cold air coming out the back vents on the right side behind the PSU/APU/Fan system.
Would have never known if someone here didn’t mention it.
The PS3 slim actually did this as well, but only when remote play was enabled through the system settings. If it was enabled, it was never truly off, even though it seemed to power down and show the red off light. The fan ran the same way there.
If you never messed with remote play, off was off like the power down option on PS4.
TyrantII is offline
post #9742 of 21079 Old 11-20-2013, 08:14 AM
lodolfan's Avatar
Quoted: 240 Post(s)
Liked: 164
Sony Plans:
Any thoughts?
So in order to purchase the SquareTrade plan through Amazon, is it required to have purchased the PS4 on Amazon?
PSN:Lodolfan16
XBL: Lodolfan16
LordXarsNexus to Shmoopy- "We're not playing Soccer, we're playing Rocket League!"
lodolfan is online now
post #9743 of 21079 Old 11-20-2013, 08:25 AM
ileff's Avatar
Liked: 30
Originally Posted by ileff View Post
I was having a problem with the optical disc. It sounded like it was stuck periodically trying to eject a disc and it wouldn't allow me to insert a disc.
Sorry typo I meant PS4. I keep the PS4 horizontal. The issue started by it ejecting a disc and flashing. Then it went into an endless loop of sounding like it was trying to eject a disc (even though empty) about every 10 seconds. It would not accept a disc. I pulled the power plug then restarted same thing. Only out of desperation I tried flipping the PS4 upside down and that fixed the issue.
Just mentioning it in case it can help somebody else...
xbl/gamecenter: leff4
psn/twitter: ileff
my app: video poker clock
ileff is offline
post #9744 of 21079 Old 11-20-2013, 08:28 AM
Quoted: 238 Post(s)
Liked: 363
I realized last night that there is no where in settings that you can go and see every file saved on the HDD. When you go to "System Storage Management" under settings, you only see the saved game files for your games, other users' saved game files will not show up unless you log into those accounts. I have a second account on my PS4 that is not connected to a PSN account for my kids to use to play games (they are 6 and 3 yrs old) and I was hoping to be able to upload there saved games from my account to my cloud storage for backup. This isn't possible since they don't show up when I'm logged in. This will also make managing HDD space more of a pain, you'll have to log into each account on your PS4 to delete certain files instead of being able to do it all from one spot, unless I'm missing something.
It only deletes it from the notifications list, I've done it many times. There are 2 ways to delete a game; you can find the game in the media bar and hit Options, there is a delete selection there or you can go into settings under "System Storage Management".
I'll have to pay attention more but, I don't think mine does this. Yes, the fan remains on if I'm downloading something or have just been playing a game but, from what I can tell, it turns off eventually. If not, then it is so quiet that I can't tell if it is on, I can clearly hear my DVR when everything is off but not the PS4.
That's what it says in the product description, I don't know how strict they are about that though. It's near the bottom of the page under the "Things to know" section of the product description: "SquareTrade Protection Plans sold on Amazon only cover products purchased from Amazon within the last 30 days."
lodolfan likes this.
post #9745 of 21079 Old 11-20-2013, 08:29 AM
Smigro's Avatar
Quoted: 235 Post(s)
Liked: 221
I agree but am hoping since I heard DICE came out and said the 1.50 patch is what caused some of the BF4 issues.
Ed
Panasonic VIERA TC-P60ST60 Plasma, Onkyo TX-NR1008 receiver, OPPO BDP-83 region free, Xbox One, PS4, eD[c]12 LCR, Klipsch R-14M surrounds, Rythmik FV15HP sub
Xbox GT / PSN ID - Smigro
BD collection http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #9746 of 21079 Old 11-20-2013, 08:36 AM
PENDRAG0ON's Avatar
Liked: 574
They pulled that statement.shortly after that. It wouldn't surprise me (Wii U day one update caused a few issues) but shifting the blame like that is never wise, especially for a server issue.
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
post #9747 of 21079 Old 11-20-2013, 08:43 AM
Abaddon's Avatar
Quoted: 653 Post(s)
Liked: 620
Originally Posted by Epyon415 View Post
So still trying to hammer down the notifications, but I've seen it tell me something has been added to downloads and something has been installed. Was it the first one you saw?
Thats awesome for Sony. If they are making a profit on this bad boy that can only mean good things for us consumers. $18 profit per unit...$18mil day one cool.gif
Er... retailers aren't selling it for free, there's shipping, there's fixing units that go bad, etc. They are almost certainly losing money although it shouldn't be a huge hit and they should be easily making it up on games with even just a single game per.
Abaddon is offline
post #9748 of 21079 Old 11-20-2013, 08:45 AM
GCanada's Avatar
Ok so I just now got the software update for 1.51 but not paying attention I noticed something, my Harmony 890 Pro was controlling the PS4. I do have the harmony adapter for the ps3. While not all 43 functions work I think its only a matter of time. I can turn the system on and off with it, along with a small number of other features. This is something I haven't seen reported yet but wanted to share. Still curious why my update was so late getting to me as I have had one of the first few since I got mine early. I guess I was just assuming it would get updates sooner or at least on time with everyone else. But at least now we have hope for the harmony remote extension to function fully with the new PS4 instead of having to purchase a new adapter, which has been the case for everything so far with the new console. Keep your heads up folks looks like we are going to start seeing more of the multimedia side of things now.
GCanada is offline
post #9749 of 21079 Old 11-20-2013, 08:56 AM
GCanada's Avatar
I used SquareTrade on several of my cell phones since I buy international unlocked phones and actually had to use the warranty since the screen behind the glass went out when I dropped it. They got it fixed and back to me in a week with no issues or questions of it even being rooted. I even marked it to make sure I got the exact one back and I did. I was very very happy with them.
Also an update on the Harmony adapter. I went through all the functions on my 890 Pro remote and the power button and aspect ratio are the only commands that are working currently.
Sony Plans:
Any thoughts?
GCanada is offline
post #9750 of 21079 Old 11-20-2013, 08:56 AM
Quoted: 17 Post(s)
Liked: 304
he 1.51 update is also required and improves software stability. It also refines the user interface by clearly indicating when a user downloads a game and a game patch at the same time.
Read more at http://www.escapistmagazine.com/news/view/129825-PS4-1-51-Update-Rolls-Out-UI-Refinements#UIgweSGXFwirFpjy.99
Reply PlayStation Area
Playstation 3 160gb System , Playstation 4 Camera , Playstation 4 Console , Playstation 4 Dualshock 4 Wireless Controller , Playstation 4 Games , Sony
