PlayStation 4 - Page 564 - AVS Forum | Home Theater Discussions And Reviews
 1451Likes
post #16891 of 21079 Old 06-17-2014, 04:38 PM
icelt's Avatar
Quoted: 659 Post(s)
Liked: 516
Might be a little belated on this one but Eurogamer had a pretty good article on upgrading the PS4's hard drive a little while back:
http://www.eurogamer.net/articles/di...-upgrade-guide
Here's the conclusion for those interested:
PS4 hard drives upgrade: Digital Foundry buying advice
PS4 Blu-ray games are seemingly identical to the digital releases, to the point where analysis of the disc itself reveals that the vast bulk of the data is contained in a single .pkg file - the same data structure as downloads from the PlayStation Network. All PS4 titles are designed to install and run directly from the console's hard drive, and we anticipated that there could be huge gains in switching to much faster storage solutions.
However, the reality is that while PS4 has much in common with the PC from an architectural standpoint, disk IO operations are much closer to the PlayStation 3 in practice. That being the case, just like PS3, outside of certain titles the benefits aren't quite as dramatic as one might expect should you choose to install an SSD into your console. Loading and install times are shorter - considerably so in some cases - but this doesn't translate equally across all titles. Performance also remains unchanged in all of the games we tried, with no clear measurable increases in frame-rate or reductions in tearing and judder at times when it appears that streaming could be one of the main causes. In short, there's no repeat of the scenario we saw last-gen where, for example, Skyrim ran much more smoothly from an SSD.
There are some improvements, though: the process of booting up the PS4, getting to the console's dashboard, and then loading up a game is noticeably quicker with an SSD installed in place of the stock hard drive, making system operation feel that little bit more fluid throughout day-to-day use. This alone isn't really worth the trade-off in diminished storage capacity compared to the 500GB drive that comes with the machine though, and we would hope that developers continue to optimise with the stock 5400rpm drive in mind, producing only limited returns for faster hardware.
A smaller improvement over the standard PS4 HDD is possible using faster mechanical drives, so if you require more storage and like the sound of faster loading times, a decent 1TB 7200rpm hard drive like the Z7K1000 we tested here provides a nice low-cost upgrade with plenty of space for your games, apps and other content - just don't expect massive increases in performance over the stock HDD across the board, and treat any faster operation as a bonus.
Of course, the fact that the PS4 is compatible with any 2.5-inch hard drive (with a capacity of 160GB or over) means that there are hundreds of options out there, and we wish we could have tested more of them. Something worthy of serious thought is a 2TB 5400rpm drive: typically, the higher the storage, the more data is crammed onto the platters, so while 5400rpm may not sound particularly fast, bandwidth does increase according to data density. If we were to start this feature from scratch, we would probably swap in one of these drives in favour of the hybrid SSHD - the variable success we got from the onboard caching suggests that the price premium isn't really worth it. On the flipside, while 2TB 2.5-inch 5400rpm drives are expensive, USB 3.0 "passport" variants are actually cheaper, and only a little pricier than the hybrid drive. There's another bonus too: prise the drive out from the enclosure and not only do you have a PS4 upgrade, you also have a caddy in which to house your old 500GB HDD.
However, the fact that the hybrid offers up some occasionally decent gains in performance does open up a tantalising proposition. The PS4 reserves an area of the hard drive (believed to be on the outside of the platter, where performance is best) for game developers to cache data. What if Seagate worked with Sony on a bespoke drive upgrade that ensured that the SSD flash was used exclusively for the cache? Combine that with a 7200rpm drive and we could be looking at the best of both worlds - SSD speeds where it could really make a difference, combined with the cost-effective level of storage that an SSD can't provide right now.
TeflonSoul likes this.
icelt is offline
post #16892 of 21079 Old 06-17-2014, 04:39 PM
lordxar5's Avatar
Quoted: 1158 Post(s)
Liked: 929
The xbone is ok I guess. Its pretty much what I expected going in. The ability to pin stuff on the home screen is nice. Having to log in every time sucks but its leftovers from going Kinectless. If I hadn't traded to get there I would have passed until it was $300. A few minor things I like but personally the PS4 does everything I care about so much better. Its nice having both again though. Don't know why I feel that way but I guess having both last gen for so many years just left a hole with one missing.
Smigro and RemoWilliams84 like this.
lordxar5 is offline
post #16893 of 21079 Old 06-17-2014, 04:45 PM
icelt's Avatar
Quoted: 659 Post(s)
Liked: 516
You're just an Executive Gamer! You simply prefer the option to indulge in the best gaming experiences regardless the source. Nothing wrong with that. "Why choose one when you can afford all?"
icelt is offline
post #16894 of 21079 Old 06-17-2014, 05:47 PM
Quoted: 1173 Post(s)
Liked: 969
Thumbs up
Hey xb1 newbie, you can set the console to log you in automatically.
I like this quote. I'm enjoying all 3 consoles
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #16895 of 21079 Old 06-17-2014, 05:56 PM
lordxar5's Avatar
Liked: 929
Its only automatic with Kinect
lordxar5 is offline
post #16896 of 21079 Old 06-17-2014, 05:57 PM
Hatcher's Avatar
Quoted: 22 Post(s)
I choose one because I only have the time for one console... I already have a backlog of PS4 games.
PSN = Hatcher14
Hatcher is offline
post #16897 of 21079 Old 06-17-2014, 05:58 PM
Liked: 969
No it's not. I'm going to turn on my console and see exactly where it is. It's a feature they added for you kinectless fools.
emartins is offline
post #16898 of 21079 Old 06-17-2014, 06:02 PM
Liked: 969
Settings - preferences - under system & app last option - instant sign-in. You select the gamertag you want.
lordxar5 and Smigro like this.
emartins is offline
post #16899 of 21079 Old 06-17-2014, 06:34 PM
lordxar5's Avatar
Liked: 929
Will check it out. Da webz said no when I looked.
lordxar5 is offline
post #16900 of 21079 Old 06-17-2014, 06:55 PM
Liked: 969
For now on I'll be your webz. Except for midget pron, that's all you
emartins is offline
post #16901 of 21079 Old 06-17-2014, 07:18 PM
lordxar5's Avatar
Liked: 929
Lazybox, look up miniture donkey pron?
lordxar5 is offline
post #16902 of 21079 Old 06-17-2014, 08:21 PM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
Best to just go to Xbox.com that always has the most accurate info. Xbox Wire is a good source because they show what releases and what's being updated.
The 5.0 is here
mboojigga is online now
post #16903 of 21079 Old 06-17-2014, 11:59 PM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
Originally Posted by aaronwt View Post
So I need to get ready for this 7200 rpm drive showing up this week for my PS4. Since I'm on PS+, do all my game saves get automatcially saved in the cloud? Or will I have to manually back something up before I install the new drive?
As Brad said, be safe back up to USB. You can update everything to the cloud as well from application management menu and to USB.
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #16904 of 21079 Old 06-18-2014, 06:32 AM
UHD Addict
aaronwt's Avatar
Quoted: 5246 Post(s)
Liked: 3137
I looked at everything last night and it looks like everything was saved in the cloud as it should be. So I figure I should be OK in just restoring everything from what's in the cloud. Every file I looked at to save had the same size and date that the online file had. SO hopefully I won't have any issues.
Now I just need to empty a USB flash drive and format it to FAT32 and download the most recent PS4 software.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #16905 of 21079 Old 06-18-2014, 07:18 AM
Liked: 969
Just in case you need the most recent file.
http://us.playstation.com/support/sy...4/new-install/
aaronwt likes this.
emartins is offline
post #16906 of 21079 Old 06-18-2014, 07:37 AM
brakel's Avatar
Liked: 45
Originally Posted by Abaddon View Post
False. Netflix is MUCH better on the PS4 than the PS3, if you are on a WiFi connection at least.
More accurate would be saying the PS4 does very little better than the PS3, seven months in. (If you compared to PS3 seven months in, the PS4 is leaps and bounds better).
I only use WiFi on mobile devices. My PS4 and PS3 are both wired. I'm only playing games on the PS4. I'm playing games and using media apps on the PS3. I'm sure that eventually I'll start doing more than games on the PS4 but for now the PS3 works better for me as a media player.
I'm not sure why I'd compare what the PS3 was doing 7 months in. I was stating what's going on now because now is the time frame in which I exist. I think it would be a mistake for a non-gamer to trade in his PS3 for a PS4 right now in this present time reality.
PSN brakel
brakel is offline
post #16907 of 21079 Old 06-18-2014, 08:26 AM
Abaddon's Avatar
Quoted: 643 Post(s)
Liked: 608
When did this turn into the BF4 thread?
Abaddon is offline
post #16908 of 21079 Old 06-18-2014, 08:28 AM
Abaddon's Avatar
Quoted: 643 Post(s)
Liked: 608
I wouldn't trade in my PS3, no way, so I definitely agree with this. Just pointing out that the PS4 does do a few non-gaming things better than the PS3. The number of things it does better will grow over time, which was why I compared it to the PS3 seven months in. But right now, it is definitely feature lacking in comparison.
Abaddon is offline
post #16909 of 21079 Old 06-18-2014, 10:02 AM
icelt's Avatar
Quoted: 659 Post(s)
Liked: 516
For me the PS3 is still a fantastic 3D-BR player and 3D capability I must have. I'm not saying there aren't better 3D players out there but since I already own one that performs great for my purposes I've no need to replace it. Then coupled with PS+ and the "free-ish" PS3 games I get every month, welp to put it plainly my PS3 draws electricity on a regular basis.
On the subject of the PS4, I must admit I was initially highly skeptical of claimed improvements for Tomb Raider Definitive Edition. I first played TR on the PS3 thanks to PS+ however my buddy loaned me his DE last week. After spending a good 15 to 20 hrs with the DE I am now fully in the camp of "holy effn wow this game and protagonist (O.O) look awfully good in full 1080P!" Smooth as butter gameplay as well. It's a damn fun and tight game, I'm rather grateful that someone finally convinced me to give it a chance.
icelt is offline
post #16910 of 21079 Old 06-18-2014, 10:43 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 412
If you have disc games, you'll have to reinstall all those games to the new drive.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #16911 of 21079 Old 06-18-2014, 11:01 AM
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 758
Thankfully the PS4 is amazingly fast for installing disc based games
gus738 and Smigro like this.
freemeat is offline
post #16912 of 21079 Old 06-18-2014, 11:21 AM
UHD Addict
aaronwt's Avatar
Liked: 3137
Even with Digital games they would need to be re-installed.
I thought everything has to be installed again?
aaronwt is offline
post #16913 of 21079 Old 06-18-2014, 11:33 AM
Yrd
Yrd's Avatar
Quoted: 553 Post(s)
Liked: 412
Yes, but my intent was just to remind you that your disc games have to be installed too. As previous consoles if you have a disc, you don't have to install anything.
XBL Gamertag- Yrd
PSN - Yerd
Steam - Yrd
Yrd is offline
post #16914 of 21079 Old 06-18-2014, 12:29 PM
lordxar5's Avatar
Liked: 929
Sorry we rubberbanded out of the BF4 thread...
lordxar5 is offline
post #16915 of 21079 Old 06-18-2014, 12:42 PM
PENDRAG0ON's Avatar
Liked: 574
You get one internet for that.
PENDRAG0ON is offline
post #16916 of 21079 Old 06-18-2014, 12:58 PM
freemeat's Avatar
Quoted: 391 Post(s)
Liked: 758
Yes! I played the PS3 version again and man the difference is so dramatic and the PS3 version was a great looking game for its time.
I hope the difference feels similar for The Last of US.
freemeat is offline
post #16917 of 21079 Old 06-18-2014, 01:06 PM
PENDRAG0ON's Avatar
Liked: 574
Tomb Raider DE is the reason I paid off The Last of Us Remastered the day it was announced. I'm done with PS3 for everything but the Tales of games. Xillia 2 and Zestiria need PS4 versions...
post #16918 of 21079 Old 06-18-2014, 01:40 PM
Big Brad's Avatar
Quoted: 303 Post(s)
Liked: 424
I wish I could be done with previous gen like some of you, but with PS+ I don't want to let go of my PS3. It'd be easier for me to get rid of my 360, but I still have quite a few digital download titles on there that I wouldn't want to part with.
Maybe I'll just ditch the 360 and buy a Vita. Haha.
Nayan likes this.
Big Brad is online now
post #16919 of 21079 Old 06-18-2014, 02:16 PM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
So 2014 has a ton of PS4 exclusives...most of which i guess are indie/2D/sidescrollers:
http://psgamer.co.uk/ps4/451/the-40-...-come-in-2014/
Some look pretty, and might be fun to play.
freemeat likes this.
PSN & XBL: Epyon415
Epyon415 is offline
post #16920 of 21079 Old 06-18-2014, 06:23 PM
UHD Addict
aaronwt's Avatar
Liked: 3137
Wow!!!! This update system is nice. I wish the XBOne hard drive could be upgraded like this.
Replacing the hard drive took only two to three minutes. No messing around with some super tiny screw like I had to with the PS3. Five decent size screws that could be unscrewed with a normal phillips screwdriver. It couldn't be much easier
The thing that actually took the longest was downloading the 750MB update file since it was only downloading at 16Mb/s. I put the file on a USB 3.0 flash drive.
Initializing and Installing the update was quick. In just under five minutes the PS4 had finished installing and rebooting. And I was logging into the PSN.
Now I'm downloading all my content. That looks like it might take some serious time since the download speeds seem slow like the update file was.
But I am certainly pleased with the process. I just hope the HGST Travelstar 7200rpm drive I put in is fine. My Amazon package was waiting when I got home. I just put it into the PS4 right after I opened the box. I never even tested it. I even forgot to take a picture of it for the serial number. But it seems fine so far. It seems quiet like stock drive was.
EDIT: I see I need to wait until the game is installed before I can download the save file from the cloud. So I guess I'll need to let the PS4 download everything tonight and tomorrow and download the save files when I get home from work tomorrow.
aaronwt is offline
Reply PlayStation Area
Playstation 3 160gb System , Playstation 4 Camera , Playstation 4 Console , Playstation 4 Dualshock 4 Wireless Controller , Playstation 4 Games , Sony
