"The router in use may not support IP fragments, and the communication features of some games may be restricted." - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-26-2013, 04:37 PM - Thread Starter
frankmrt's Avatar
Does anyone knows how to fix this? I am getting this message with or without a router. I also called SONY, Charter, TRENDnet (router), and they do not have a clue? I also have another PS3 and says the same thing. Does anybody in here knows what's going on?confused.gif
"By learning you will teach; by teaching you will learn."
frankmrt is offline
post #2 of 21 Old 06-26-2013, 04:59 PM
PENDRAG0ON's Avatar
Liked: 574
I had this issue oncewith Charter. Had to enable something inside the router. (Found the answer in a lengthy google search string) I wish I could help more, but you need to make sure MTU is 1500 in both the PS3 and router and find how you can enable the fragmentation inside the router, that is all I can remember.
While you are at it, put your PS3 in the DMZ of the router, this will lead to less lag in online games.
frankmrt likes this.
PSN - Pendragoongp
NNID - Pendragoon
PENDRAG0ON is offline
post #3 of 21 Old 06-26-2013, 05:00 PM
shadowlock's Avatar
Liked: 140
I googled the error msg and found these links that seem to contain the solution:
1) http://community.us.playstation.com/t5/PlayStation-Network/The-router-in-use-may-not-support-IP-fragments/td-p/27572702
2) http://community.us.playstation.com/t5/PlayStation-General/The-router-in-use-may-not-support-IP-fragments-and-the/td-p/36185465
3) http://answers.yahoo.com/question/index?qid=20090607202208AAZWkR6
Try these and see if they help. I've never had this issue, but googling the error message brings back a ton of sites, so it looks like it is a somewhat common problem.
EDIT: Looks like Pendrago0n beat me to it--his info should be correct (the links I posted say the same thing.)
OtherWorlds - My Sci-Fi/Fantasy Writing Blog
shadowlock is offline
post #4 of 21 Old 06-26-2013, 05:09 PM
PENDRAG0ON's Avatar
Liked: 574
You posted links that explain it, so you got me beat.
PSN - Pendragoongp
NNID - Pendragoon
post #5 of 21 Old 06-26-2013, 05:12 PM - Thread Starter
frankmrt's Avatar
Oh ok, I'm getting the message without a router that's where I'm confused.
frankmrt is offline
post #6 of 21 Old 06-26-2013, 05:37 PM
Quoted: 175 Post(s)
Liked: 193
What is your PS3 firmware version?
Crash44 is offline
post #7 of 21 Old 06-26-2013, 05:40 PM - Thread Starter
frankmrt's Avatar
I have 4.41.
frankmrt is offline
post #8 of 21 Old 06-26-2013, 06:33 PM
PENDRAG0ON's Avatar
Liked: 574
You are connected to a device through ethernet or wifi, that is still counted as a router.
PSN - Pendragoongp
NNID - Pendragoon
post #9 of 21 Old 06-26-2013, 06:46 PM - Thread Starter
frankmrt's Avatar
I had Ethernet before I notice the error. I even tried wifi, but still got the error that's when I also tried without the router which also give me the error. I also tried two different routers Asus RT-N56U and TRENDnet TEW-731BR and two different modems Cisco DPC3008 and the Motorola SB6120. I also tried with new ethernet cable CAT5e.confused.gif
frankmrt is offline
post #10 of 21 Old 06-26-2013, 06:50 PM
PENDRAG0ON's Avatar
Liked: 574
The device you use to connect to the charter line is your modem/router, an additional wifi router is a second unit in the chain that can cause issues. You can't connect directly from the PS3 to the charter cable.
PSN - Pendragoongp
NNID - Pendragoon
post #11 of 21 Old 06-26-2013, 06:51 PM - Thread Starter
frankmrt's Avatar
Last thing I'm going to try is replace all my ethernet cables if that does not work I'm going to put the ps3 on the train's tracks. Lol.wink.gif
frankmrt is offline
post #12 of 21 Old 06-26-2013, 06:53 PM - Thread Starter
frankmrt's Avatar
SB6120 is modem only.
frankmrt is offline
post #13 of 21 Old 06-26-2013, 06:54 PM - Thread Starter
frankmrt's Avatar
That's what I did I connected from the modem to the PS3 via ethernet.
frankmrt is offline
post #14 of 21 Old 06-26-2013, 06:58 PM
PENDRAG0ON's Avatar
Liked: 574
Your "modem" is the problem. Hook it up to a PC and go into it's settings and fix the problem as detailed in the links above.
PSN - Pendragoongp
NNID - Pendragoon
post #15 of 21 Old 06-26-2013, 07:12 PM - Thread Starter
frankmrt's Avatar
Okay guys I think is working now the test is now complete with no problems. This is my set up:
SB6120>TEW-731BR>new ethernet cable> PS3. I think it was my ethernet cable I don't know. Just to make sure I'm going to try the Charter's router Cisco DPC3008 again to see if this Cisco router was giving the problem. we'll see.
frankmrt is offline
post #16 of 21 Old 06-26-2013, 11:46 PM
joeblow's Avatar
Liked: 233
Reports are coming from the official site forums that the IP fragment issue is resolved with the newest 4.46 firmware as well as patch the freeze bug some had.
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #17 of 21 Old 06-27-2013, 08:44 AM - Thread Starter
frankmrt's Avatar
That's good to know, but when I spoke to SONY about it they thought I was talking crazy:mad:
frankmrt is offline
post #18 of 21 Old 03-13-2014, 11:21 AM
g_a_carlson's Avatar
Not sure where I read the MTU size should be 1464, but I logged into my router and made the MTU size 1464 on both WAN and LAN (carrier side and home network side) routed interfaces.
I had this problem since the PS3 days and it carried over to my PS4. Before making the change I was getting 6M download and 3 M upload from the PS3/PS4 test network connection. My service is actually 50 down / 10 up. After the change to my router config I got 37 down / 3 up, which is a huge improvement. These speed tests are not to be taken for scripture, but they should give you a ballpark idea of where you are at.
In any case, making that change on my home network equipment made a drastic improvement.
Also, I have a commercial grade router with complete command line access so I can assume that not all routers have the same flexibility and options. So this may not be applicable to all, but hopefully helps some.
g_a_carlson is offline
post #19 of 21 Old 03-13-2014, 01:17 PM
PENDRAG0ON's Avatar
Liked: 574
Setting the MTU below 1500 will cause lag issues in online games. You are putting a bandaid on the problem. The solution is in the links above, give it a try.
PSN - Pendragoongp
NNID - Pendragoon
post #20 of 21 Old 03-14-2014, 09:58 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 55
You say that, but the solution at the links seem to say that the solution is an MTU value lower than 1500. Is it best to ignore the error then? Will this affect NAT type?
bg
garciab is offline
post #21 of 21 Old 03-15-2014, 05:30 PM
PENDRAG0ON's Avatar
Liked: 574
Make sure your modem and router supports packet fragmenting (I think that is what it was called, I had to deal with it 4 years ago so I may get terms wrong) sure, lowering the MTU can fix speed issues, but games will still have issues with hit detection and general lag.
Once I fixed that my packet loss went to zero and my speed was as advertised and even my ping dropped drastically.
PSN - Pendragoongp
NNID - Pendragoon
Reply PlayStation Area
