PS4 Eye extender cable? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 37 Old 10-11-2013, 11:46 PM - Thread Starter
MrSniffer's Avatar
I am seeking some info about an extender cable for the new PS4 Eye. The PS3 unit used standard USB, so a powered extender cable worked just fine. But the PS4 unit is some proprietary interface. Anyone know enough to speculate how to extend it by 15 feet? All my audio equipment is in a closet, and my screen/sofa is 20 feet away. I think lots of folks with serious home theater setups will share this dilemma.
MrSniffer is offline
post #2 of 37 Old 10-13-2013, 08:49 AM
futurecode's Avatar
I inquired about this a few moths ago and found zilch info wise.
I'm just under the assumption well either be raped by Sony for a oem extender cable or go to companies like mad catz or monoproce will have something out shortly after launch.
Till then camera use will have to be set up and broken down for every game session .... booooo.
PSN: futurecode
futurecode is offline
post #3 of 37 Old 11-12-2013, 03:22 PM
IQ22's Avatar
I actually just cancelled my pre-order for the camera due to the lack of an extension cable. I need ~30 foot run to reach the media closet through my smurf tube. Anyone else have any new findings on this?
PSN: MiddKid
IQ22 is offline
post #4 of 37 Old 11-22-2013, 10:41 AM
Majerus_12's Avatar
I was thinking about cutting the cable and splicing it with some cat6. Not sure if it would work but this was part of the reason I bought a ps4 instead of xbox with the kinect being required on xbox.
Majerus_12 is offline
post #5 of 37 Old 11-22-2013, 10:46 AM
IQ22's Avatar
Good conversation over here about splicing in a powered USB 3.0 repeater...it, unfortunately, didn't work. Not feeling good about this...
http://community.eu.playstation.com/t5/PS4-General/Playstation-4-Camera-Extension/td-p/19470384/page/5
PSN: MiddKid
IQ22 is offline
post #6 of 37 Old 11-22-2013, 03:55 PM
Majerus_12's Avatar
Yea that does not look promising..
post #7 of 37 Old 11-22-2013, 04:16 PM
futurecode's Avatar
I'm sure Monoprice or the like will step up eventually.
I used to have a wall mounted Plasma where my screen is now, so I was just lucky enough that I had run HDMI and Ethernet behind there, so I just set up a makeshift rack next to my center channel .... the PS4 kinda looks go there too wink.gif
PSN: futurecode
post #8 of 37 Old 11-22-2013, 05:43 PM
Majerus_12's Avatar
All my stuff is in a closet so I'll need a cable
post #9 of 37 Old 11-26-2013, 08:21 AM
ImmortalServant's Avatar
There is no reason cutting the cord down the middle and splicing a bundle of appropriately gauged wires to both ends of the existing wires on the cords should not work. The only problem I can foresee is if the wires are not color coded.
I would try it, but I have not seen anything compelling enough to make me buy one yet.
ImmortalServant is offline
post #10 of 37 Old 11-26-2013, 09:36 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
What if its sending analog ? Like a rocksmith cable.
defdog99 is offline
post #11 of 37 Old 11-26-2013, 12:55 PM
Wire is wire. If it is analog it needs a higher quality of wire than a digital signal would, but as long as you use copper wire that is a little thicker you should be fine.
You would want to use a little thicker gauged wire than what the original has if you are adding more than 15' probably. You probably could cut the ends off of a long enough usb or hdmi cable (whichever has a large enough number of internal wires to match 1/1 with the eyetoy cable) but you are going to have a thick spot on both ends where you are connected to the original wire.
I CAN NOT GUARANTEE THIS INFORMATION. USE AT YOUR OWN RISK.
post #12 of 37 Old 11-30-2013, 11:29 PM
sawyerthecat's Avatar
Yes, it's a problem, and no I don't want the children in my av closet - so I put the ps3 game system out of the av closet on a 35 foot hdmi cable, and used usb repeater cable for the camera.. now for the ps4..
These folks at ps4eye say it's just a usb3 cabling without the wires for usb2 compatibility- and of course the proprietary connector.
http://ps4eye.tumblr.com/
then there is this that says yes it's usb 3 but attempts failed splicing both powered repeater and unpowered usb3.0 cables to extend the camera cable
http://www.ifixit.com/Answers/View/149998/Anyone+know+aux+port+pinout
sawyerthecat is offline
post #13 of 37 Old 12-02-2013, 06:30 AM
newfmp3's Avatar
Quoted: 291 Post(s)
Liked: 266
Send an email to monoprice. Some of us have already and with enough people asking maybe we can get something.
newfmp3 is offline
post #14 of 37 Old 12-25-2013, 09:19 PM
G--
G--'s Avatar
Quoted: 32 Post(s)
This will get fixed, question how to get the controllers to work from my media closet at 40'?
G-- is offline
post #15 of 37 Old 12-29-2013, 09:22 AM
Jobine's Avatar
I think it's gone be like the Kinect, you need a USB 3.0 extension with a external power supply
They use a special connecter because the camera need 12 volts and the USB port have only 5 volts
That the Pin Out of the Kinect
Jobine is offline
post #16 of 37 Old 02-01-2014, 06:27 PM
cityinruin's Avatar
any update on an extension for ps4 camera?
cityinruin is offline
post #17 of 37 Old 02-21-2014, 12:16 PM
cityinruin's Avatar
Tried modifying a powered usb 3.0 extender. Doesnt work at all. PS4 seems to know that the device is connected but there is no image.
Fortunatelly i was able to reconnect the cable as original and it works fine.... but is unusable for me as the cord is 6 feet too short.
post #18 of 37 Old 03-17-2014, 03:55 PM
ursula1000's Avatar
ursula1000 is offline
post #19 of 37 Old 03-20-2014, 03:00 AM
SuperDre's Avatar
Nope, that's for the PS3 version of the camera...
SuperDre is offline
post #20 of 37 Old 04-03-2014, 03:09 PM
cityinruin's Avatar
anyone else have any success ?
post #21 of 37 Old 05-03-2014, 08:05 AM
Abodnar3's Avatar
Our. Home theater guy is experimenting on a solution, otherwise we're stuck waiting on Sony to sell a 25+ foot cable.
Abodnar3 is offline
post #22 of 37 Old 09-11-2014, 08:34 AM
Manamb's Avatar
Quoted: 35 Post(s)
Still no offerings? Need a 15 ft extension.
WTF Sony!!!!
Manamb is offline
post #23 of 37 Old 09-11-2014, 08:47 AM
Abodnar3's Avatar
I haven't seen anyone find a solution yet.
Abodnar3 is offline
post #24 of 37 Old 09-18-2014, 06:06 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Found this. Hope it works.
http://www.amazon.co.uk/gp/aw/d/B00JFX1IHM?pc_redir=1410713480&robot_redir=1
Whelp , can't order it here in the states to my home or work address. Oh well.
scoobdude is offline
post #25 of 37 Old 09-19-2014, 05:50 AM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
http://www.amazon.co.uk/gp/aw/d/B00J...&robot_redir=1
It seems it must have been a bogus listing because I got a notification that the item is NLA from the original seller which was Amazon.
This wouldn't surprise me since Amazon has a tendency to put items up before conformation that they will be made available.
Ed
Panasonic VIERA TC-P60ST60 Plasma, Onkyo TX-NR1008 receiver, OPPO BDP-83 region free, Xbox One, PS4, eD[c]12 LCR, Klipsch R-14M surrounds, Rythmik FV15HP sub
Xbox GT / PSN ID - Smigro
BD collection http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #26 of 37 Old 09-19-2014, 05:55 AM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Still got my fingers crossed. When I found it yesterday it also mentioned it was for the kinect. And it's still up.
In addition I found a request page on monoprice. Will try and post the link when I find it again.
post #27 of 37 Old 07-20-2015, 01:43 PM
TViewer2000's Avatar
Quoted: 58 Post(s)
Just seeing if there was any update on this. I have my PS4 in a media closet and the PlayStation Camera cord isn't long enough to put by TV.
Abodnar3 likes this.
PSN ID: Onedropshot
TViewer2000 is offline
post #28 of 37 Old 01-07-2016, 05:40 PM
marlon1925's Avatar
Quoted: 62 Post(s)
Any update on this?
marlon1925 is offline
post #29 of 37 Old 01-12-2016, 06:31 AM
Quoted: 58 Post(s)
Originally Posted by marlon1925 View Post
Any update on this?
I bought the camera extension cable from Best Buy. Seems to work mostly. The video works but when I use it for chatting, people say I sound like a transformer. Not sure if the PS4 has enough power going through the cord to handle the extra length. It does seem to work fine with Just Dance so I can live with the comprise of actually using the camera.
PSN ID: Onedropshot
post #30 of 37 Old 10-26-2016, 08:49 AM
oakleez's Avatar
It seems like generic-ish (non-Sony) 6.5ft extensions are still the only option. I recently purchased the PSVR which was the only reason I got a camera... and can't find ANY way to use anything other than a single 6.5' extension (bringing it to about 13ft total length). There has to be a way to add a power-injected external power cable, no?! With my setup, I can't face the TV when using PSVR without a 25ft (total) cable.
Bummer.
oakleez is offline
Reply PlayStation Area
