PS4 and Harmony remote? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #181 of 267 Old 06-08-2015, 08:46 AM
Player2's Avatar
Quoted: 17 Post(s)
Originally Posted by cembros View Post
Has anyone figured out how to power the unit on? It's great that I can use my remote now but without the power on function it's kind of useless.
I use my TVs HDMI-CEC function so when I change the input to the PS4 HDMI source the system will turn on automatically. I think this integration is a pretty dependent on the TV you have.
Player2 is offline
post #182 of 267 Old 06-08-2015, 09:15 AM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
Probably not the answer you're looking for, but Sony has a PlayStation App for iOS (probably Android too, but I can't say that for sure) that can be used as a "second screen" when paired with your PS4. It has limited functionality as a remote (text entry is probably the most useful feature that I've seen so far). It can also be used to power on a PS4 that is in rest mode.
Chronic masticator.
Gear: Speakers (Paradigm Reference Studio Series): 40 v4 (front L/R), CC-690 v4 (centre), 20 v4 (surround L/R). PSA XS30 (subwoofer).
Denon AVR-X4000, Emotiva XPA-5, Samsung PN64F8500 (64" plasma), DarbeeVision Darblet DVP5000, PS4, PS3, Sony BDP-S6200,
Apple TV (3rd gen.), Harmony One, Sennheiser RS180
tboe77 is offline
post #183 of 267 Old 06-08-2015, 07:51 PM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
You can use the ps4 app to Power it on.
bori is offline
post #184 of 267 Old 06-09-2015, 09:12 AM
cembros's Avatar
Quoted: 191 Post(s)
Liked: 42
Yea I applied that and I guess it works but the remote doesn't connect with blue tooth right away a freezes. The whole thing just seems buggy. I have a seperate blu ray player that I use for movies so I haven't had much of a need to play around with it but for right now it just doesn't work well.
cembros is offline
post #185 of 267 Old 06-09-2015, 09:15 AM
cembros's Avatar
Quoted: 191 Post(s)
Liked: 42
The app solution is a bit useless. The whole point of the universal remote it to have a one remote solution, might as well just get up and turn it on.
I plan on turning a spare bedroom into a home theater in the next couple months and I only want to use the PS4 for blu ray, hopefully I get the kinks sorted by then. Honestly, the power on function isn't that big of a deal because you have to turn on the unit to put a movie in anyway. Just nitpicking I guess. The power off function does work flawlessly though.
cembros is offline
post #186 of 267 Old 06-09-2015, 10:24 AM
anthonymoody's Avatar
Quoted: 564 Post(s)
Liked: 389
I'm SOL too b/c my older Harmony's - which I love - aren't covered, nor is the PS3 adapter. Grrrrrrr.
I have a Harmony Smart Control (the one with no touch screen, + the hub thing) and no matter what I can't get it to stay paired (remote to hub).
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
post #187 of 267 Old 06-09-2015, 02:42 PM
MarkcusD's Avatar
Quoted: 49 Post(s)
Liked: 45
Originally Posted by Rakesh.S View Post
In that case, you're gonna have to keep being sad, Marksaw. These people want you to spend money, not save it.
I'd pay for a new BD remote if they made one for PS4. And you should play Destiny
Rakesh.S likes this.
psn: markcusd
X1: MarkcusD
MarkcusD is offline
post #188 of 267 Old 06-09-2015, 08:39 PM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
How is that working for you?
It works for me in that in turns my PS4 on but the only problem I have is that no matter which activity I select on my Harmony when the TV and AVR are in an off state it always turns my PS4 on.
I have a Panasonic Plasma and Denon AVR with HDMI control turned on - as soon as the AVR/TV is turned on so is the PS4 even if selecting another activity from my Harmony. Let me know if you had better success and how you did it.
EVT is offline
post #189 of 267 Old 06-10-2015, 02:49 AM
bori's Avatar
Quoted: 188 Post(s)
Liked: 125
I have a dumb question. If the ps4 is Bluetooth and smartphones have Bluetooth why can we use phones as a remote control?
bori is offline
post #190 of 267 Old 06-11-2015, 07:13 AM
Quoted: 564 Post(s)
Liked: 389
Solved the pairing problem by rebooting my router. Everything works as it should (though the fact that the remote can't turn the PS4 on really sucks).
You can with the Sony app.
Double True!
post #191 of 267 Old 06-11-2015, 09:54 AM
Player2's Avatar
Quoted: 17 Post(s)
So do you have all of your devices (TV, PS4...etc) going to the receiver and then one HDMI from the receiver to the TV so the TV is always tuned to the same HDMI input?
I have mine separated where Audio goes to Receiver and Video goes to TV.
Maybe that could be the issue?
Player2 is offline
post #192 of 267 Old 06-18-2015, 11:09 AM
EVT
EVT's Avatar
Quoted: 46 Post(s)
Liked: 25
I think that is the issue. I have a couple of devices where I have separated the audio and video as I ran out of HDMI inputs on my receiver and if I start up one of those activities the PS4 doesn't automatically turn on. I suppose I could separate the audio and video on the PS4 but then I would lose HD audio so I think for the time being I'll live with the inability to power on the PS4 with the remote.
EVT is offline
post #193 of 267 Old 06-22-2015, 05:22 AM
Player2's Avatar
Quoted: 17 Post(s)
Does anyone have one of the home control remotes that can comment on how well it does or does not work.
Did some searching this weekend and it appears a lot of people are having issues.
Player2 is offline
post #194 of 267 Old 07-06-2015, 06:18 PM
khoyme's Avatar
I am on here in a hunt to see if I can fix all the problems I am having. Bought a PS4 a couple of weeks ago and thought the new Harmony's would work fine. Picked up a Harmony Ultimate Home and the dang thing can't do basic play/pause using the hard buttons on the remote.
Go to https://support.myharmony.com/en/har...-playstation-4 and go down and open the "+" by the Blu-ray Player app and see the limitations listed. I have tried the "double click the PS button" and it doesn't work for me.
If I can't figure something out I will return the Harmony. $350 for no control is really ridiculous. I would avoid until the Harmony site shows actual control of movie playback.
khoyme is offline
post #195 of 267 Old 07-07-2015, 04:35 AM
Quoted: 1175 Post(s)
Liked: 969
Could be an issue with the PS4 itself. I bought a remote awhile back to be able to control the PS4 for blu ray playback and it also didnt work within the bluray app. The media buttons worked fine for other apps and DVD but no with the bluray. Thought it was odd and returned it.
One of the greatest posts I have read
benjamin-benjami - http://www.avsforum.com/forum/142-pl...l#post24609271
emartins is offline
post #196 of 267 Old 07-20-2015, 03:06 PM
schmiggyjk's Avatar
http://www.amazon.com/dp/B00ZJRHSZO/
Anyone seen this yet? Now all we will need a rf to bt adapter right?
schmiggyjk is offline
post #197 of 267 Old 07-20-2015, 03:25 PM
TornadoTJ's Avatar
Quoted: 1662 Post(s)
Liked: 517
Mine won't stay paired no matter what I do.
TornadoTJ is offline
post #198 of 267 Old 07-21-2015, 05:47 AM
curtlots's Avatar
Quoted: 88 Post(s)
Liked: 115
It actually looks like a pretty nice remote! Complete control of the PS4 and limited universal capabilities to boot.
curtlots is offline
post #199 of 267 Old 07-21-2015, 10:43 AM
Player2's Avatar
Quoted: 17 Post(s)
I hope the official remote will now lead to a better alternative for Harmony. I am still holding out hope that I can just by an adapter so my Harmony One can control the PS4 similar to the adapter I bought for the PS3.
Player2 is offline
post #200 of 267 Old 07-21-2015, 11:49 AM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
http://www.playstationlifestyle.net/...ober/#/slide/1
new remote is official. Available in Oct.
Details per the release
Spoiler!
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #201 of 267 Old 07-21-2015, 12:12 PM
MarkcusD's Avatar
Quoted: 49 Post(s)
Liked: 45
Spoiler!
Finally! Preordered it.
psn: markcusd
X1: MarkcusD
MarkcusD is offline
post #202 of 267 Old 07-21-2015, 01:23 PM
jsacevedo's Avatar
Quoted: 504 Post(s)
Liked: 203
Ditto!
Xbox Live Gamertag: JShmoopy
PSN ID: JShmoopy
jsacevedo is offline
post #203 of 267 Old 07-21-2015, 02:10 PM
TViewer2000's Avatar
Quoted: 39 Post(s)
Hopefully Logitech will get the Bluetooth codes so that we can use our remotes with the Bluetooth adapter.
PSN ID: Onedropshot
TViewer2000 is offline
post #204 of 267 Old 08-07-2015, 03:09 PM
cembros's Avatar
Quoted: 191 Post(s)
Liked: 42
PS vue just launched in my area and oh my is it great. They really need to get going with full harmony support so I don't have to get directive back for football season.
cembros is offline
post #205 of 267 Old 08-10-2015, 07:40 AM
TornadoTJ's Avatar
Liked: 517
If you have a hub based Harmony you already can, the only issue is power on. My understanding at this point is that the power on button is something other than bluetooth, possibly RF on a frequency the Harmony can't handle.
If you do not have a hub based Harmony, it is never going to work because the Logitech PS3 adapter doesn't work, and the other Harmony remotes don't have BT.
post #206 of 267 Old 08-12-2015, 07:13 AM
Quoted: 39 Post(s)
Well I figure if they can get the codes then maybe they can make an adapter like they did with the PS3. The hub has both IR and Bluetooth, but my understanding was that no device worked in the same way that the controller does. So you can navigate the menu but the Netflix app won't work with remotes.
PSN ID: Onedropshot
post #207 of 267 Old 08-14-2015, 06:33 PM
tboe77's Avatar
Quoted: 62 Post(s)
Liked: 136
The Netflix app works fine with a harmony (hub-based) remote. Blu-Ray playback, on the other hand . . . not so much.
tboe77 is offline
post #208 of 267 Old 10-07-2015, 01:32 AM
tfoltz's Avatar
Quoted: 62 Post(s)
Liked: 80
Anyone have feedback on using the PS4 with these remotes: Smart Remote and Ultimate Home Touch Screen.
https://www.groupon.com/deals/gg-log...&fallback=true
tfoltz is offline
post #209 of 267 Old 10-07-2015, 06:52 AM
TornadoTJ's Avatar
Liked: 517
That's what most are talking about above, like in the post right before yours. The main thing is it will not power on the PS4. But as you see above, there are other issues also.
post #210 of 267 Old 10-07-2015, 09:15 AM
tfoltz's Avatar
Quoted: 62 Post(s)
Liked: 80
I read through this thread and see that the hub remotes function, but was just looking for feedback as to pros and cons. The biggest difference is clearly the screen vs. no screen. I'll just gather any extra information in other reviews.
tfoltz is offline
Reply PlayStation Area
Playstation 4 Console
