HAVEN'T TURNED MY PS4 OFF SINCE I'VE HAD IT - AVS Forum | Home Theater Discussions And Reviews
Old 11-16-2013, 01:30 PM - Thread Starter
epicbloodline's Avatar
When Im done I hold the PS button down and put it on standby mode,
dont ask why
xboxlive: BLACKSOULTRAIN or SILVERBACK XXL
epicbloodline is offline
Old 11-16-2013, 04:42 PM
TyrantII's Avatar
Liked: 833
Haven't shut down mine yet, besides for a few reboots. Always a good idea to burn in new CE's, especially complicated ones.
TyrantII is offline
Old 11-18-2013, 08:58 AM
duffman33's Avatar
Just wanted to put this out there, I also have been putting it into standby mode since that seems the most like the PS3 mode, since if it's actually off, you can't install updates or turn it on with the controller. Well, yesterday we had terrible storms in Illinois, and while my power didn't actually go out, it did flicker and surge, shutting off the PS4. When I turned it back by pressing the button on the system, it came up with a message that it hadn't been shut off properly, but nothing bad seemed to have happened from what I can tell. Just want to make sure everyone is aware of this, since power outages happen.
65JS9500
Sony STR-DN1030
Pioneer SP-C22 Andrew Jones Designed Center Channel Speaker
Pioneer SP-FS52-LR Andrew Jones Designed Floor standing Loudspeaker - Fronts
Infinity Primus 363 6.5" Tower Speaker - Surrounds
Martin Logan Dynamo 300 8" 75 Watt Subwoofer x2
duffman33 is offline
Old 11-18-2013, 11:20 AM
SharpOne's Avatar
Quoted: 21 Post(s)
Tyrant,
I have heard/read about breaking in speakers/subwoofers, but I have never heard anything on electronics.
What is the theory here? Sustained steady state operation for some amount of time, achieving what? Some type of tempering or conditioning effect for the equipment?
SharpOne is offline
Old 11-18-2013, 12:49 PM
Big Brad's Avatar
Quoted: 300 Post(s)
Liked: 419
I leave mine on standby all day and then turn it off before I go to sleep.
PSN ID/XBOX Live! Gamertag: BiffCo
My SD/HD movie collection
Big Brad is offline
Old 11-18-2013, 02:30 PM
TyrantII's Avatar
Liked: 833
My idea is to just normal use test the hardware with use, in the hope that anything faulty with fail sooner than later. Usually with electronics faulty components will show up quickly, but if one doesn't use their device much they might no have a failure until they're out of the warranty period.
TyrantII is offline
Old 11-18-2013, 05:53 PM
brakel's Avatar
Liked: 45
If you do a full shutdown of the PS4 you can still turn it on with the controller.
PSN brakel
brakel is offline
Old 11-18-2013, 06:48 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
I shut it down. No use putting low power hours on the hardware for no reason. Plus it specifically states that you shouldn't unplug the power cord while in standby mode. What about a power outage? I don't know what I'd lose and I don't want to find out.
500 gigs FTL.
blklightning is offline
Old 11-18-2013, 10:59 PM
brakel's Avatar
Liked: 45
You won't necessarily lose anything as a result of loss of power while in standby. If it happens you get the standard tsk tsk you shut down incorrectly warning.
PSN brakel
brakel is offline
Playstation 4 Console
