PS4 Video Output Talk - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 119 Old 05-01-2014, 11:00 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
So just to rule everything out, I took my receiver out of the loop. And now the ps4 passes BTB/WTW in full. Put the receiver back on....and it's clipped. Strange thing though, is my PC passes BTB/WTW just fine in full whether or not it's connected through the receiver. Even under the same port, with the same settings. So there's still something funny going on with the ps4 in full. Limited is fine in either case, so it's still the safest bet. It's possible that some displays may or may not react similarly...who knows. PS4 is weird, nothing makes sense on this damn thing.
Smigro and mphfrom77 like this.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #92 of 119 Old 05-02-2014, 02:06 AM
roadwarrior980's Avatar
To be safe I keep my setting on automatic, along with my display. Seems to pass everything just fine, but I had read a while back that automatic, as an RGB setting on the PS4, is actually the same as the limited setting as far as what's being passed. Again, this will not affect content such as Blu Rays but will for any apps or programs using RGB, which is the XMB menu, apps like NetFlix, and games.
But I think as long as the display is set to take the content from the PS4 without any conflicts (auto/auto, Full/nonstandard, etc) then this isn't an issue, but how some displays behave with the PS4 and how setups can vary may affect this. Or it could be an issue with receivers (or the PS4) not doing a proper 'pass through' or even 'upscale' to send the signal through the HDMI chain without some sort of processing or lack thereof.
"To sin by silence when we should protest makes cowards out of men."
Operation Iraqi Freedom Campaign Veteran, 06-08.
Operation Iraqi Freedom Campaign Veteran, 09-10.
Operation Enduring Freedom Campaign Veteran, 12-13.
roadwarrior980 is offline
post #93 of 119 Old 05-02-2014, 05:32 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Yeah, in my experience automatic will always send limited. Even if I force the display to full range it's not like the ps4 detects that and switches accordingly.
As far as the clipping in full goes, it's not a problem per se....it only clips what's BTB/WTW anyway. It's technically trying to do the right thing. My display is calibrated so I wouldn't see below 16 anyway....but I'd rather not lose the top 10% of the signal. With the receiver out of the picture I couldn't see any difference either...but even if full range doesn't always harm the image, I still can't see a situation where it would help either.
bd2003 is offline
post #94 of 119 Old 05-02-2014, 07:10 AM - Thread Starter
helvetica bold's Avatar
Quoted: 384 Post(s)
Liked: 240
What's the make of your receiver? Denon is known to not pass RGB full that's why I bought a Sony receiver. I have my PS4 RGB set to Full. You can see the picture I posted last night of Outlast looked perfect. I'll played some Infamous as well and with deep color on it looks spectacular.
roadwarrior980 likes this.
helvetica bold is online now
post #95 of 119 Old 05-02-2014, 08:50 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Anthem MRX300.
It passes 0-16 and 235-255 in 16-235/limited mode, so it's not just clipping everything outright.
bd2003 is offline
post #96 of 119 Old 05-02-2014, 12:49 PM
Gamerphile1's Avatar
You know with the option to switch HDCP 'off' or 'on' on PS4. I hooked it up to an analog port on my display via VGA with HDCP 'off' and to my surprise it sets by itself automatically RGB & YCbCr to 'Full', Deep color auto, resolution Auto. This leads me to believe my settings are correct when gaming on a CPU monitor.
Gamerphile1 is offline
post #97 of 119 Old 05-02-2014, 12:51 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Or they're just assuming that anyone who wants to turn HDCP off is using a PC capture card and needs to work in 0-255.
bd2003 is offline
post #98 of 119 Old 05-02-2014, 01:11 PM
I have a Sony STR DN840. I would hope that a sony receiver would pass such signals to the PS3 and PS4 without fault and I believe this is the case.
post #99 of 119 Old 05-02-2014, 01:18 PM - Thread Starter
Quoted: 384 Post(s)
Liked: 240
I own the 1040 receiver and your 840 will work with Sonys new Triloumious TVs.
The receivers also support xvYCC color. Sony receivers usually have awesome video
capability.
post #100 of 119 Old 05-02-2014, 01:38 PM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
Originally Posted by bd2003 View Post
Alright, here's some in game proof of what I'm talking about. I'm using outlast, a game most PS4 people should have gotten for free.
Here's the calibration screen, with the slider pushed all the way up and brightness jacked up on the PJ (exactly at the same level on both), to raise the black floor and bring out any clipping.
Limited on both PJ and PS4
Notice how you can still see the logo?
Now here's full on both.
Even with the brightness jacked up on the PJ, and the in-game slider all the way....the logo is clipped.  This is basically incontrovertible proof that they're converting from limited to full by just clipping data.  Notice how you can't see anything behind the figure on the right? Also clipped. In limited, you can clearly see the brick wall behind him, and the shadow he casts on it. In full....nothing.
Now here's default settings in game, with the PJ restored to proper calibration.
First, limited - notice how you can still see the guy?
Now full...he's gone.
So using full completely changes what you're going to see in game for the worse, even if you calibrate it properly in full. A lot of shadow detail is simply thrown away in full, to the point where nothing you can do in game or on your PJ can bring it back.
So basically....use limited, because you'll get the full range.  If you use full, your range will be limited. I know that sounds backwards, but that's the deal. And it's not a bug.
This is weird. When I was messing with this when I first got my PS4 I had the same issue with crushing the blacks when I set the PS4 to full...but then I found out that my TV (Panny TC-P50G25) was still limited. Once I set my TV from standard to non standard I got my shadow detail back. This is why I think a lot of this dependent upon what gear people have in their chain. For me it its PS4 ----> Onkyo TX-NR1008 ----> Panny TC-P50G25 (I have my Onk set to pass through for my PS4).
edit: just read your post where you took your AVR out of the chain...weird I must say.
helvetica bold likes this.
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #101 of 119 Old 05-02-2014, 01:54 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
The only thing in absolutely certain of at this point is that it's ridiculous that we still need to deal with this on diigital displays.
newfmp3 and Smigro like this.
bd2003 is offline
post #102 of 119 Old 05-02-2014, 02:17 PM
newtophoto's Avatar
After reading this whole damn thread, I am still confused as ever. I have a Sony W900A and PS4. I think I'll just leave everything as automatic when playing games and watching movies on the PS4.
steve1022 likes this.
newtophoto is offline
post #103 of 119 Old 05-02-2014, 02:25 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Well here's the part I'm stumped on right now. If limited passes BTB and WTW in-game, it's using all 256 steps. Full obviously is as well. Both are being fed by the same 8bit frame buffer....that means one of them has to be a conversion of the other.
bd2003 is offline
post #104 of 119 Old 05-02-2014, 09:07 PM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
Curious, could each specific game title call for a specific RGB range?
I just wonder if some are designed for limited and others for full. Or if some are better designed in this regard than others.
mphfrom77 is offline
post #105 of 119 Old 05-02-2014, 10:03 PM - Thread Starter
Quoted: 384 Post(s)
Liked: 240
I have the same setup and your fine with that selection. Both are new Sony products and talk to each other through Bravia sync.
post #106 of 119 Old 05-03-2014, 04:05 AM
SeeNoWeevil's Avatar
I get no video signal on my Onkyo 828 when Deep Color is enabled after the v1.70 update. Also, if I connect the PS4 to one of the '4K' labelled HDMI ports on the receiver the picture is flickery and unstable, Deep Color off on both the console and the amp. It's perfect on the other ports. PS4 HDMI implementation seems really buggy to me, loads of threads on the official boards with HDMI related issues.
SeeNoWeevil is offline
post #107 of 119 Old 05-07-2014, 08:00 PM
TheGrumpyCat's Avatar
Quoted: 12 Post(s)
Hello. I picked up a Samsung 2233 monitor today, which has 1080p and HDCP. No HDMI port. Only VGA and DVI.
Should I have no problems with a HDMI to DVI cord?
TheGrumpyCat is offline
post #108 of 119 Old 05-08-2014, 07:44 PM
Nope, just update to the newest PS4 firmware update, and use the DVI connection with HDMI connector and you're good to go.
post #109 of 119 Old 06-06-2014, 04:06 PM
sl@cker's Avatar
What is the difference between ycbcr limited and full? Is it the same as the rgb settings? Where limited is 16-235, full is 0-255?
sl@cker is offline
post #110 of 119 Old 06-07-2014, 12:15 PM
sl@cker's Avatar
Bump
sl@cker is offline
post #111 of 119 Old 07-18-2014, 04:13 PM
CLEHD's Avatar
So what's the verdict on Deep Color? I get setting RGB And Y Pb... to Limited. Does it even matter what I choose for Deep Color?
CLEHD is offline
post #112 of 119 Old 07-19-2014, 12:19 PM
reallynotnick's Avatar
Quoted: 342 Post(s)
Liked: 227
Has anyone tried to test banding on one verses the other? If limited has more banding than it is being rendered at 0-255 if full has an uneven progression of banding that it is being rendered at 16-235 and converted to 0-255. Since the PS4 is obviously only rendering at one of these it would be really nice to know what is he native one so I can display it without on conversion.
reallynotnick is online now
post #113 of 119 Old 07-19-2014, 01:37 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
I tried, but it's really not obvious one way or another.
bd2003 is offline
post #114 of 119 Old 02-17-2015, 07:25 AM
Quoted: 17 Post(s)
According to the following article, RGB Full isn't always the way to go with a TV:
http://referencehometheater.com/2014...ll-vs-limited/
My old TV didn't support RGB Full, so I was never able to experiment with this setting before.
Being as the W9 I now own does support it, I tried the PS4 and TV set to Full, but then the image settings were out when it switched to Limited for video content, so I returned the PS4 to Limited and the TV to Auto.
Whilst I ran my PS4 and TV in Full, there was a noticeable flicker when I played video content, such as a Blu-ray. I guess this was the switch from Full to Limited.
I'm going to set the TV to Limited later to match the PS4 output and see how it compares to the TV on auto.
The setting I'm not sure what to do with on the PS4 is Y Pb/Cb Pr/Cr. It has the same options as RGB: Auto, Full, Limited. Should the setting match whatever I have RGB and the TV set to?
I have PS4 Deep Colour set to off.
mjpartyboy is offline
post #115 of 119 Old 03-19-2015, 01:02 AM
Leonheart's Avatar
Quoted: 80 Post(s)
Liked: 24
I have a lm6200
Leonheart is offline
post #116 of 119 Old 04-08-2015, 08:21 PM
Liked: 0
How come on the PS4 there are settings for YCbCr to be either Full or Limited when YCbCr range is always 16-235? Which do I set it to if my TV's range is limited (16-235)?
OrganicOrange is offline
post #117 of 119 Old 04-09-2015, 05:11 PM
Liked: 0
Halp
post #118 of 119 Old 04-09-2015, 06:25 PM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
You mean RGB not YCbCr right?
If so then you should set your RGB on the PS4 to Limited to match your TV which you stated was limited.
You are using HDMI, correct?
post #119 of 119 Old 11-19-2015, 04:22 AM
mishari84's Avatar
Quoted: 119 Post(s)
Liked: 25
today I tried playing PS4, but picture was greening, I had to set color space on projector to auto to fix it. So rec.709 color space was the problem. How to fix it from PS4 settings?
mishari84 is offline
Reply PlayStation Area
