PS4 audio settings - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 155 Old 04-21-2014, 11:57 AM
ATC7's Avatar
I just got an email from 2K recommending to change my audio settings on the PS4 from HDMI to Digital Out (OPTICAL) and disable DDS5.1, DTS5.1 and ACC (with Linear PCM checked), they said that would fix the issue. Unfortunately it didn't work, still getting the audio cutting out in matches. I guess I'll have to wait for Sony to drop the 1.7 update, maybe it'll fix this.
ATC7 is offline
post #92 of 155 Old 05-06-2014, 01:37 PM
lagi's Avatar
Hi everyone,
I'm new on this forum even if I have known AVS for a long time.
I don't have HDMI on my amp and my projector anymore because of an overvoltage in my flat. My PS4 is now plugged in optical on the amp, which is a Pioneer VSX-919.
I've only the two front speakers now and I've been wondering which is the best format. I understood that Linear PCM was the best via bitstream. The thing is that my amp seems to be less vibrant than lossy dts or dolby counterparts, which is kind of paradoxical for me.
For the information, I tried bitstream and bitstram mix on a bluray in this 2.1 setup with an optical cable, and I've been surprised that with linear PCM checked :
In bitstream, I just have the lossy dts or dolby decoding in the bluray menu.
In bitstream mix, I have the lossless DTS-HD or Dolby True HD put forward in the bluray menu.
For those who were wondering what the real difference was between bitstream and bistream mix,we may have the beginning of an answer in the 2.1 setup.
The only way to have lossless sound via optical out on bluray films then is to highlight Linear PCM in bitstream mix.
Am I right ? I wanted to be confirmed on this theory.
lagi is offline
post #93 of 155 Old 05-06-2014, 08:43 PM
bradman's Avatar
Quoted: 20 Post(s)
Liked: 29
If you're using optical,you're not getting lossless sound,you're getting its' lossy core.
bradman is offline
post #94 of 155 Old 05-07-2014, 03:48 AM
lagi's Avatar
Not if I'm in a stereo setup. The lossless linear pcm can go through a stereo setup via optical, but that's the limit of this type of connection.
lagi is offline
post #95 of 155 Old 05-08-2014, 05:13 AM
lagi's Avatar
That's exactly what I did to improve my 2.1 setup via optical out. And the difference is real for the movies with a really more detailed and shining sound. I watched Jaws yesterday night which is in 7.1. The sound is far better than when DDS5.1, DTS 5.1 and AAC are checked. It's logic by the way given that all the informations which go to the satellite speakers directly go to the front speakers now.
And when I tried to change between linear pcm, bitstream direct or bitstream mix in the PS4 bluray menu once the film had started, there was no cut of the sound as it used to be when DDS5.1, DTS5.1 and AAC were checked (DTS was then on the screen of the amp even if PS4 bluray menu was showing DTS HD MA in this setup) and I thought at the time that the sound was not very punchy : the dialogs were not very clear and pared back (I'm a French who's watching the original versions, when you don't catch a word, it's easier to notice when the sound is not crystal clear concerning dialogs).
By the way, I left it in bitstream direct because I know it's just the way it should be. In this setup, my Pioneer amp shows me STEREO on its screen. The pure 7.1 DTS HD MA in Jaws is converted in pure stereo with the default linear pcm 44,1 Khz or 48 Khz (which are automatically checked in the sound and screen menu, optical out branch) from the PS4.
It's important for those who are just like me in a stereo setup in optical out to disable DDS5.1, DTS5.1 and AAC (with Linear PCM checked). I don't know for those who are hooked in HDMI but for Optical, that's the way it is and I'm very happy to have solved the problem. Try it, compare and you wouldn't want to come back to the defaulft PS4 setup which automatically enables DDS 5.1, DTS 5.1 and AAC in its sound and screen menu.
lagi is offline
post #96 of 155 Old 05-29-2014, 07:10 PM
jax001's Avatar
Hi can someone help I can't seem to get picture or sound on my ps4 through my cinema system on hdmi I just get the multi pcm come on the front panel unlock comes up and repeats like it's trying to connect but don't?:-)
jax001 is offline
post #97 of 155 Old 05-29-2014, 07:58 PM
scoobdude's Avatar
Quoted: 59 Post(s)
Liked: 30
Does it work direct to the TV? Did anything else work when connected? If it's not the ps4 you will need to work with the cinema system it whatever.
scoobdude is offline
post #98 of 155 Old 05-30-2014, 04:23 AM
jax001's Avatar
jax001 is offline
post #99 of 155 Old 05-30-2014, 04:33 AM
jax001's Avatar
Yea works on direct to tv lol had to buy a optical lead and everything else seems to work I had the ps4 working before so it's gotta be something in settings lol :-)
jax001 is offline
post #100 of 155 Old 06-12-2014, 03:28 AM
godwindx's Avatar
Liked: 0
Does anyone know how to fix this issue?
I just upgrade my PS3 to PS4 and when I open my PS4 it only give me 720p and 2.1 PCM instead of 1080p + 7.1 PCM.
My old setup is PS3 > HDMI to HDMI Splitter then one HDMI cable go through my receiver(DA2400ES) and another one to my monitor with HDMI-DVI.
If I turn off my receiver i will get 1080p but no sound or turn off my splitter and i will get 7.1 PCM without video.
It was working perfect on my PS3 for like 3 years until today.
godwindx is offline
post #101 of 155 Old 07-13-2014, 01:34 PM
tthayil's Avatar
Thanks to everyone posting here regarding the PS4's HDMI audio problems. I have an Onkyo TX-SR805. No problems with PS3, DVR, XBox, but the PS4 would not
send anything but 2.0 channel audio over HDMI. Tried every possible combination / sound toggle / configuration (both console and bluray playback software)...no luck.
Was ready to send this PS4 back as I considered sending the "optical audio" over the HDMI a defect (and convinced their CS rep of this as well), but really suspected the console
was fine. So I dug into my bin o'cables and pulled out an optical cable. Connected it and now getting DD 5.1 and DTS fine which is fine with me for the time being.
Hope this helps anyone out there in the same boat I was.
T
tthayil is offline
post #102 of 155 Old 07-13-2014, 02:59 PM
UHD Addict
aaronwt's Avatar
Quoted: 5434 Post(s)
Liked: 3271
I know recently I found out the PS4 HDMI cable I had was defective. I had been having some issues but they were intermittent. But I finally figured out it was the HDMI cable that came with my PS4 after I tried it with a couple of other devices. So I just cut the cable and threw it away. I should have never used it anyway. I rarely use the HDMi cables that come with the devices. But I made an exception with the PS4 and XBOne and used those HDMI cables. I normally use Monoprice HDMI cables. Fortunately my XBOne cable has been fine so far but I will probably change that out to just to avoid a chance of issues later. Whenever I get my second PS4 I will make sure I don't touch the HDMI cable that comes with it.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is online now
post #103 of 155 Old 07-14-2014, 11:49 AM
MD MC's Avatar
Quoted: 31 Post(s)
Agreed on the PS4 freebie cable, mine was casuing drops when being fed through a monoprice 4 x1 switcher. Threw it away as well and no issues since.
MD MC is offline
post #104 of 155 Old 10-08-2014, 08:27 PM
mchamblissII's Avatar
T
Yes, i'm having the same issue with my PS4. I just bought a Marantz SR5009 and I went through every combination possible. I really thought my receiver was broken or something. So I did some research and found this page on the search engine. I was wondering if this issue is resolved? I'm really glad that I kept my PS3. I have absolutely no issue when it comes to LPCM.
mchamblissII is offline
post #105 of 155 Old 10-09-2014, 11:50 AM
tthayil's Avatar
Only fixed in that I'm getting 5.1 audio through optical cable and using HDMI for video. Haven't re-checked this in a while as I"m loathe to rewire again.
T
tthayil is offline
post #106 of 155 Old 10-12-2014, 11:48 AM
bradman's Avatar
Quoted: 20 Post(s)
Liked: 29
I can only speak for my own setup, but my PS4 is passing full bitrate DD 5.1 over HDMI. I am selecting DD out in the audio options.
bradman is offline
post #107 of 155 Old 10-15-2014, 11:09 AM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 210
Still not working for me. If I want center channel sound on games, I have to use ProLogicII. I tell it to output audio via optical, even though no optical cable is connected. When I watch movies, I get full surround sound. This PS4 is a POS.
milehighou is offline
post #108 of 155 Old 10-17-2014, 09:14 AM
Argyle Shepard's Avatar
Quoted: 38 Post(s)
Wow glad I found this thread! I posted this in the Mordor thread, but it seems much more appropriate here:
Hey guys, I have an audio question for people playing this on the PS4. My receiver is acting crazy and I can't figure it out. Basically the center channel stopped working and dialogue started coming thru the left and right channels. I tried shadow of mordor last night and the center channel is completely silent. I put a bluray in and I got the proper 5.1 sound with dialogue coming thru the center channel. Also tried nba2k15 and had the same issue with no sound coming thru center channel. Anyone else notice this on their ps4 game or is my receiver going crazy?
I should also mention that on my XBOX ONE I get proper 5.1 thru games but when running the cable box thru the HDMI input I was not. So I used an HDMI slot on the receiver for the cable box and 5.1 works fine. Weird.
Argyle Shepard is offline
post #109 of 155 Old 10-17-2014, 10:15 AM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 210
Good luck. I think it's an issue with the way PS4 outputs game audio. I have my system connected via HDMI, but I have to go to 'audio settings' and tell it to use optical out (even though there isn't a cable connected). Then I can select ProLogic II on my receiver, and I get center channel on games.
For movies, I go back to audio settings and set PS4 audio out to HDMI. Movies play as expected, with center channel audio.
Switching back and forth all the time is getting really old, but that's the only workaround I've found. Either that, or just play games and get used to not having center channel.
post #110 of 155 Old 10-17-2014, 11:20 AM
Quoted: 38 Post(s)
Welp... that work exactly as you said. Lmao. I have o optical cable but telling the PS4 I'm hooked up via optical works perfectly. Go home PS4 you're drunk
post #111 of 155 Old 10-17-2014, 11:58 AM
mcclayton's Avatar
Quoted: 117 Post(s)
What sound comes out of the ds4 speaker? I just noticed mine is all the way down.
mcclayton is offline
post #112 of 155 Old 10-17-2014, 11:59 AM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 210
Glad it's working for ya. It's still not "real" surround sound. We're just faking it out with ProLogic, but at least we're getting audio out of that speaker. I can't believe Sony still hasn't fixed this. It doesn't seem to be a problem for everyone; maybe it's only certain receivers?
post #113 of 155 Old 10-17-2014, 01:43 PM
Quoted: 38 Post(s)
Well, if it's only certain receivers the irony is I own a Sony one lol.
post #114 of 155 Old 10-17-2014, 02:13 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 210
LOL.
I used to have a Sony and it worked fine with my PS3. In fact, everything worked great. Center channel sound, no problem. Now I have a Marantz, but I think the issue is with the PS4. Everything else works great with my AVR...except the PS4
post #115 of 155 Old 10-17-2014, 02:31 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
Any of you guys with center speaker issues have the last of us?
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #116 of 155 Old 11-02-2014, 09:09 AM
kumanzc's Avatar
Quoted: 23 Post(s)
Anyone else having any audio issues using Plex on their PS4. I have no issues with Blu-ray or Netflix but only getting 2.0 sound with Plex.
kumanzc is online now
post #117 of 155 Old 11-03-2014, 07:17 AM
Quoted: 38 Post(s)
I haven't tried plex but I did spend about an hour last night trying to finure out what's going on with this audio issue. I tried both Shadow of Mordor and NBA2K15.
Both games didn't work. Here is what I saw. When I set the PS4 to give me 7.1 PCM via HDMI my receiver recognizes it. Immediately the receiver will tell me that the signal is coming in properly. At this point I'm only getting 2.0 stereo audio and I have no way of changing it to surround. When I tell it to give me optical audio (no optical audio cable connected) it sends out 2.0 sound and I can then fake surround vía PL2. The weird part is that when I play a bluray disc and I set the audio back to HDMI and PCM, it all works like it should. This has to be something on the PS4 end and I doubt they will patch it at this point. Not being able to game with true surround is extremely frustrating.
post #118 of 155 Old 11-03-2014, 08:25 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
No PCM, DTS-MA or TrueHD
Hi
Does anyone experience this issue after upgrading ps4 to version 2?
When playing a bluray movie or playing a game the "Auto Surround" set the audio as STEREO!
At first I thought it was an issue with my Pioneer SC81 but I swap the Ps4 with my PS3 and works fine the Auto surround and set the audio to dtsma, truehd or pcm. But put back again the ps4 and set the audio back to Stereo!
All I know this issue started after fw upgrade. Anyone has this issue? Or found a way to fix it? And yes I setup the ps4 audio output to both settings and didnt worked!
javygonx is offline
post #119 of 155 Old 11-03-2014, 08:31 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
It happens to me after ps4 fw upgrade to version 2. I put ps3 and works fine hd audio.
javygonx is offline
post #120 of 155 Old 11-05-2014, 09:02 PM
javygonx's Avatar
Quoted: 100 Post(s)
Liked: 27
Btw. HD Audio Problem was fixed with software update 2.01 ! Thanks Sony!
javygonx is offline
Reply PlayStation Area
Playstation 4 Console
