PS4 Video Dropouts / Glitching / Screen Flickering - Please Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 12-15-2013, 07:52 PM - Thread Starter
moshock's Avatar
My equipment: PS4 -> Denon X4000 Receiver -> Panasonic 65" (TC-65PS64)
My previous setup: PS4 -> Denon 3310 Receiver -> Panasonic 65" (TC-65PS64)
Problem: Occasionally, maybe once every 20-30 minutes, I get a video dropout / glitch / flicker (audio not affected) that lasts less than 1 second - The screen will either go black or glitch / flicker with various colors (kind of looks like bad screen tearing). I've noticed while just idling in in the home screen, while playing Resogun, and while playing BF4.
What I've tried:
1) New HDMI Cables from PS4 to Receiver and from Receiver to TV
2) Two different Receivers...
2) Swapped out my PS4 (I thought it was defective, but the new one does it too, ugh)
I have DirecTV as well, running through my Receiver, and I have watched hundreds of hours with the same setup(s) without a single video issue, so I don't think the Receiver or TV are at fault... but I've tried two PS4's, sooo... I don't know what else to troubleshoot! Are there any video settings to change in my PS4 that may help?
Does anyone have suggestions? Is anyone else experiencing random video dropouts / glitching / flickering? Am I the only one?
moshock is offline
post #2 of 38 Old 12-15-2013, 09:02 PM
Bytehoven's Avatar
Quoted: 35 Post(s)
Liked: 66
I used to have a similar and persistent issue with a xbox 360 hdmi output. In that case it was the HDMI socket on the 360. Once the unit was warmed up I could get the video signal to drop by wiggling the cable in the hdmi socket. There were certain positions that would not connect properly. Not sure if this was the result of a poor circuit board trace solder on the hdmi connector.
Have you tried connecting the PS4 directly and eliminating the receiver? Just to see if the issue persists.
I have had the video drop out a few times on my new PS4. My routing is PS4 -> Yamaha 2020 -> Sony VW90. It has only happened twice on about 15 hours of play time, so not enough to really be a problem yet.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #3 of 38 Old 12-16-2013, 08:27 AM
diy_canuck's Avatar
I would try this ^.
Or try a different HDMI input for your PS4 into the Receiver.
PSN - Brohdah
diy_canuck is offline
post #4 of 38 Old 12-16-2013, 08:31 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
check for the HDMI connector issue on the PS4 (a tab that's popped up).
try turning HDMI CEC off -- if it's on.
defdog99 is offline
post #5 of 38 Old 12-16-2013, 10:16 AM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
Have you also tried unplugging all other HDMI input sources? Maybe too much cross talk? Is the PS4 set to default output settings, same is receivers? May not hurt to set everything back to factory default after trying to connect directly to the TV.
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #6 of 38 Old 12-16-2013, 03:12 PM
frankthetoad's Avatar
Quoted: 65 Post(s)
Liked: 88
This has been happening to me as well....both on my first overheating prone PS4 and the one I have now. I have the Panny S60. I haven't tried plugging it directly into the TV yet, but I suspect it may be the TV's problem.
I have the Onkyo 809. I've turned off DeepColor and any other setting in the TV, AVR, or PS4 that might be causing it.
The only thing I can think of is that the HDMI port on the back of my TV is extremely close to the wall. So much so that the cable pushes against the wall. Perhaps there's too much pressure. I may see if I can get an angled cable adapter or something that would take some pressure off the connection.
It is the most annoying thing in the world, especially when it flickers to a completely black screen. Being immersed in a game so completely only to have everything go black is very disorienting.
PSN: frankthetoad
frankthetoad is offline
post #7 of 38 Old 12-17-2013, 02:40 PM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 435
Happening to me as well. About 3 times now. Video will just black screen for 3-7 secs, then pop back on. Happens in multiples too... 2-3 times within a minute then no problem.
Denon receiver & projector.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
post #8 of 38 Old 12-17-2013, 08:46 PM - Thread Starter
moshock's Avatar
I just purchased 2 brand new HDMI cables. I'll give them a try, and if it persists, then I'll try bypassing the Denon Receiver and go straight to the TV. If it still persists, then I'll try the other HDMI port in my TV...
moshock is offline
post #9 of 38 Old 12-24-2013, 10:04 AM - Thread Starter
moshock's Avatar
Well, it looks like my problem is solved folks.
Purchased: http://www.amazon.com/gp/product/B0052SCU8U/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
Ran one from the PS4 to the Denon, and one from the Denon to the TV, and I've played probably 8 hours without a single video glitch.
I'm honestly quite surprised this was the fix though. I tried several other "nice" HDMI cables (more expensive than these Amazon Basics) already with no success. Oh well, whatever, cheap fix in hindsight!! cool.gif
moshock is offline
post #10 of 38 Old 12-24-2013, 10:10 AM
redshift1's Avatar
I never had video glitches until HDMI.
redshift1 is offline
post #11 of 38 Old 12-25-2013, 01:06 AM
pinkdidilyinks's Avatar
Happening to me as well with the PS4 connected to a Bose Lifestyle system.
If I connect directly to the TV, it doesnt appear to be happening. A google search shows a lot seem to be experiencing a similar problem.
Hopefully a firmware update is on the way soon. Anybody have.a good contact number for Sony?
pinkdidilyinks is offline
post #12 of 38 Old 12-25-2013, 01:18 AM
Here is a video. Is this what you guys are experiencing?
http://www.youtube.com/watch?v=f0-sDih0Ze0
HDMI handshake issue?
post #13 of 38 Old 12-26-2013, 10:05 AM - Thread Starter
moshock's Avatar
^ mine wasn't nearly as bad as that. mine were usually one second tops. sometimes a few seconds. and it'd only happen maybe once every half hour, so it was hard to troubleshoot. but new hdmi cables fixed it for me.
moshock is offline
post #14 of 38 Old 12-26-2013, 10:39 AM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
I have not experienced that with my PS4, but damn do I hate the whole HDMI handshake thing. When I fire up my equipment, I specifically start my FIOS box first, then TV, then receiver, and when all it on and working I will switch my AVR to the GAME input and fire up whatever console I am turning on. If I do not do it this way it is hit or miss as to whether all components will communicate properly.
I blame most of this on HDMI having no real set standard so every different manufacturer does it differently opening us consumers up to this mess that is the HDMI handshake.
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is online now
post #15 of 38 Old 12-26-2013, 10:41 AM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 435
I hope your problem is fixed.
It has happened to me only 3 times in close to 200hrs of playtime. So very intermittent. If I had swapped cables after the last time it happened, then I would've thought the same as you, that new cables fixed the problem since it hasn't happened since.
The problem has happened with 2 setups, one in my office, and one in my living room. Both setups run Denon receivers, one with a projector and one with an LCD. So I'm thinking a PS4 hardware glitch, or possibly a handshake issue with the receivers. I'm not convinced it's a handshake issue, because handshake issues tend to happen with more frequency.
Spanglo is offline
post #16 of 38 Old 01-06-2014, 01:57 PM - Thread Starter
moshock's Avatar
Just throwing a final post here - problem is 100% resolved with new cables. If you have flicker, get some new cables. I don't necessarily think I had bad cables (I'm using them on a different setup now with zero issues), but they didn't seem to play nice with my PS4.
moshock is offline
post #17 of 38 Old 01-06-2014, 02:24 PM
Not using new cables but this has not happened to me for several days. Weird, but maybe it fixed itself somehow.
post #18 of 38 Old 02-06-2014, 02:55 PM
megawatt6693's Avatar
not true i got brand new cable and i have the same problem
megawatt6693 is offline
post #19 of 38 Old 02-07-2014, 06:17 AM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
That is kind of a blanket statement and may not work for everyone, but would be a good place to start for most. With the prices of HDMI cables on Monoprice I don;t see the harm in people getting some newer high speed HDMI cables for these new consoles.
http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024008&p_id=3951&seq=1&format=2
post #20 of 38 Old 02-07-2014, 08:09 AM
Quoted: 65 Post(s)
Liked: 88
After trying just about everything, I broke down and bought one more set of cables- http://www.monoprice.com/Product?c_id=102&cp_id=10240&cs_id=1024004&p_id=3661&seq=1&format=2.
Ran one from the PS4 to my Onkyo 809 and the other from the Onkyo to the TV. This has finally fixed my problem. May not work for everyone, but it's worked for me.
PSN: frankthetoad
post #21 of 38 Old 03-08-2014, 10:16 PM
Plasma5300's Avatar
Quoted: 130 Post(s)
Liked: 24
Im also having this problem. I thought my brand new twisted veins hdmi was the problem so im using my old playstation certified hdmi now and its happened twice. I also have a new sammy plasma which i thought was the problem. Hmmmm. Mine only goes to black screen for a split second them back showing 1080p/60p up top like i changed source. Idk. Guess ill just wait and see. I have a couple weeks to exchange at gamestop.
Plasma5300 is offline
post #22 of 38 Old 10-24-2014, 11:05 AM
Liked: 0
Fix it with shorter HDMI cable vs 10 ft looped one
i was having a problem with video dropout & other glitches with a new Philips 50" flat screen and new PS4 & was thinking what the hecks going on so i check our forum here and the general consensus was ...( HDMI cables ) as the problem so i thought naw it can't be that simple so i looked and remembered i have a 20 foot long HDMI cable looped in a circle to shorten it ... and well i it makes since that i would lose signal & create a problem with by looping and creating a magnetic loop field..... so i switched it out with a standard 6FT PS4 supplied HDMI cable ....A BAM!!! problem solved ............. so try a shorter HDMI cable for shorter signal travel time & don't go cheaper in quality HDMI cables... trust me i got a lot of ethernet & HDMI cables from china that are garbage impure metal and plastic wires....
Mr Carson is offline
post #23 of 38 Old 10-25-2014, 06:19 AM
FuNkYMoNk585's Avatar
Quoted: 20 Post(s)
I had this issue as well, what fixed it for me was going into video settings and switching deep color mode to off from automatic. Hasn't happened once since then and it's been a few months now.
Sony Bravia 55X850D
Denon AVR-591
Sony SSF-5000 Front L/R
Sony SSCN-3000 Center and Surround L/R
Logitech Harmony Ultimate remote
Sony PS4 Gaming Console
FuNkYMoNk585 is offline
post #24 of 38 Old 11-25-2014, 10:36 AM
LegoMania's Avatar
I have this issue as well. PS4 -> Denon Receiver (AVR-1610) -> Samsung (LN37A450). All connections are HDMI. I tried swapping out the cables on all units, no luck. The trick for me is turning off HDCP on the PS4, which is really quite annoying because Netlix does not work with it off.
I've run multiple devices through the same setup before (FireTV, Boxee Box, LG BluRay Player, Macbook Pro, Ouya) and I've never had an issue.
I think the problem is with PS4 firmware and however they are doing HDCP. I'm on the latest 2.02 firmware.
LegoMania is offline
post #25 of 38 Old 12-03-2014, 01:32 PM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
I have the S60 and it has happened to me on every long playing session between Battlefield 4 and Destiny.
I have an AVR between the TV and console.
It is so infrequent I can't troubleshoot it, it is frequent enough that it's annoying.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #26 of 38 Old 12-03-2014, 01:35 PM
Cravit8's Avatar
Liked: 610
There is not enough current in HDMI to create electromagnetic interference.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #27 of 38 Old 12-03-2014, 01:35 PM
Quoted: 65 Post(s)
Liked: 88
I believe my problem was an improperly seated HDMI cable into the back of the PS4. I haven't had the issue in months.
PSN: frankthetoad
post #28 of 38 Old 12-03-2014, 01:38 PM
Cravit8's Avatar
Liked: 610
Ok, so it happening on a different brand TV than mine means it is the PS4 and thankfully not my expensive AVR.
Sad for me, it's not feasible to move my entertainment center for a single cable swap. I painted myself into a corner with this setup.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #29 of 38 Old 12-30-2014, 07:55 AM
Liked: 0
I am having the same issue on my Samsung 60" plasma (PN60F5300AFXZA) I just bought last week.
Since it only has 2 HDMI inputs, I am also using a 5 port HDMI switch.
So I have my TiVo on HDMI 1 then my Xbox360, PS3, PS4 and Computer all on the HDMI switch plugged into HDMI 2.
I have not had the screen go blank while using the TiVo, 360 or PC. (I have not tried the PS3 yet with this TV), but while playing a game on the PS4, the screen goes blank for a second or 2, intermittently.
I will try getting all high-speed HDMI cables and I'll also try the PS4 on its own HDMI port on the TV itself just to see if that helps.
Thank you for the suggestions above.
Steversnlt is offline
post #30 of 38 Old 01-02-2015, 03:18 AM
lapino's Avatar
Quoted: 73 Post(s)
Got the same problem, PS4 > Denon AVR-X2100W > Panasonic 50GT60 or Epson TW9200W. Sometimes pictures disappears (some glitches or black screen) and gets restored within a few secs. Very annoying when playing games. I did not have this issue with my Marantz receiver (only thing I changed). Might try some high quality cable first, but still not sure this will fix it.
lapino is offline
Reply PlayStation Area
