PS3 Media Server stopped working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-17-2014, 05:46 PM - Thread Starter
Westly-C's Avatar
Quoted: 322 Post(s)
Liked: 200
PMS hasn't worked for me for the last 4 days. I can't get it to show on the PS3 or my Samsung Smart TV. I've made no changes before it stopped, and I've spent most of my free time today wrestling with it...I checked the firewall, it has all the correct permissions. I deleted rebooted, and reinstalled. Nothing.
Has anyone else run into this recently, and how-if at all, did you resolve it?
Dazed and confused over high tech.
Sigh...Concrap. The Internet Overlord Cometh
They're not com-tastic!
Westly-C is online now
post #2 of 5 Old 06-18-2014, 12:03 AM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
By PMS you are referring to Plex Media Server?
Can say I've encountered this, is it only with the PS3 not seeing it? Does PS3 see DLNA at all, if so, it should see movies/music etc as just your server. What OS is your server running? Check your PS3 settings specifically, networking, and whatever category media is under (i'll have to boot mine up to confirm).
Only thing I can think of is that DLNA got turned off on accident (?) or Plex is unexpectedly borked.
Have you also tried plugging both into the same switch/router?
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #3 of 5 Old 06-18-2014, 10:56 AM - Thread Starter
Westly-C's Avatar
Quoted: 322 Post(s)
Liked: 200
It is the PS3 Media Server. On a Win XP desktop. Rebooted router also. Won't show up as a media server on the PS3, or on the Smart TV. Both plugged into router via ethetnet cables.
PS3 Media Server UI normally shows both devices on it's home screen. Now it just says ''No renderers were found''.
post #4 of 5 Old 06-18-2014, 11:22 AM
Liked: 0
I had this same exact problem about 2 months ago, spent 8 plus hours trying to figure it all out. It's a real easy fix, you are just going to have to get a new media server client for streaming your content. Google Universal Media Server & download that, I was back up & running in minutes once I found this streaming client & I couldn't be happier. It's much better than PS3 Media Server. It's made by the same person who did PS3 Media Server so the look, feel & setup will be very familiar. Has better features as well, I believe you can do a side by side comparison of the two also. Hope this solves your problem.
DreMarceaux is offline
post #5 of 5 Old 06-24-2014, 09:01 PM - Thread Starter
Westly-C's Avatar
Quoted: 322 Post(s)
Liked: 200
Problem solved. There was an update to ZoneAlarm Security Suite, that caused the blocking. The solutions provided by a ZA support tech, was to do a clean install. Had to uninstall, then run a Clean uninstall utility program provided by them, and then download the latest version all over again.
And, that did the trick.
Through all the hassle, one good thing came of it, the Universal Media Server recommended by DreMarceaux. It's just like PS3 Media Server, only it doesn't choke on streaming MKVs. Thanks for the suggestion.
Reply PlayStation Area
