PS4 blu-ray sound errors - AVS Forum
Old 09-22-2014, 12:00 PM - Thread Starter
Dizman7's Avatar
Question PS4 blu-ray sound errors
Probably should have posted this a long time ago, but I've been experincing this since the system launched in Nov.
On a large portion of my blu-rays, if I set the Blu-ray Player app setting (not the console's setting) to "Bitstream" the audio will CONSTANTLY and forever skip every 10 secs, so basically unplayable. Star Trek Into Darkness blu-ray is my default test disc but it does it with other too Iron Man was another blu-ray I recall trying.
I want my reciever to do all the decoding, and from the very few disc I've tried that do work, it does sound the best (IMO) having the app set to Bitstream.
Anyone else experinced this problem, and maybe even fixed it? Or does my PS4 sound broke and I should be calling Sony?
Dizman7 is offline
Old 09-24-2014, 06:38 PM
PS3forlife's Avatar
I had to set the options on mine when the disc starts playing hit the option/start button on the ps4 then navigate to the audio section and change it. Should fix it. Mine would never show DD on reciever till i did this.
PS3forlife is offline
