PS4 only outputting stereo via pcm? - AVS | Home Theater Discussions And Reviews
post #1 of 11 Unread Today, 09:16 AM - Thread Starter
Liked: 2
My ps4 is only outputting stereo using the pcm setting on my ps4. my hdmi audio output setting is hdmi, my receiver is a AVR-S500BT - Denon, i have no idea whats worng hopefully someone can help me. i can not get any Dolby or DTS settings to show up either.
brandonb21 is online now
post #2 of 11 Unread Today, 09:52 AM
gixerking's Avatar
Quoted: 22 Post(s)
My god man, I can't get past the display sticker...
What source are you trying to play? Game, movies, Netflix?
gixerking is online now
post #3 of 11 Unread Today, 09:59 AM - Thread Starter
Liked: 2
game, destiny, i also tried grand theft auto and call of duty.
post #4 of 11 Unread Today, 01:58 PM
bdoyledimou's Avatar
check to make sure that the AMP is not set to pass through audio to your TV - if it is -- it will downsample to the max your TV will support (must likely 2 channel stereo).
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #5 of 11 Unread Today, 02:26 PM - Thread Starter
Liked: 2
no its not i checked, i read some wheres im suppose to use "muit in" for ps4 games i have no bluerays to test hd codecs supported by the amp
post #6 of 11 Unread Today, 02:27 PM
Ryan Hendry's Avatar
Set it to bitstream and you should be good.
Ryan Hendry is online now
post #7 of 11 Unread Today, 02:31 PM - Thread Starter
Liked: 2
but then il loose audio quality wont i?
post #8 of 11 Unread Today, 02:35 PM
Negative. Your PS4 will stream the raw data to you receiver, your receiver will decode it and send it to your speakers. Best quality right there.
post #9 of 11 Unread Today, 02:36 PM
You may have to mess with the surround modes until it says "Dolby Digtal" or "DTS".
post #10 of 11 Unread Today, 02:49 PM - Thread Starter
Liked: 2
oh most people say PCM is uncompressed audio their for thats what i should be running.
post #11 of 11 Unread Today, 04:28 PM - Thread Starter
Liked: 2
once i turned on bitstream dolby, "dolby digital" showed up and surround is now working in my games and sounds great
Reply PlayStation Area
