PS2 DVD Player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-04-2005, 08:17 AM - Thread Starter
brianbes's Avatar
Is the PS2 a decent DVD player for movies. I would be hooking up thru component and I have a cheap DVD player now anyway. I know the XBox DVD player for movies is crap from other posts.
brianbes is offline
post #2 of 6 Old 01-04-2005, 09:53 AM
tokerblue's Avatar
Quoted: 191 Post(s)
Liked: 164
The PS2 and Xbox are mediocre DVD players at best. Unless your stand alone DVD player is of the <$50 type, then I wouldn't use the PS2 as a DVD player. Even if it is, it still might be better. :)
tokerblue is offline
post #3 of 6 Old 01-04-2005, 11:00 AM - Thread Starter
brianbes's Avatar
I figured as much, may hook it up with a Svideo cable to my receiver as I switch everything thru my receiver which only has two component inputs which are taken up by the DVD player and cable box. I run it to a Z2 but my receiver will upconvert Svideo thru the component output so I don't have to run another cable to the projector and I really don't want to spend $100 for a component switcher. I'm thinking the Svideo has to look better than composite.
brianbes is offline
post #4 of 6 Old 01-04-2005, 11:42 AM
tokerblue's Avatar
Quoted: 191 Post(s)
Liked: 164
> What receiver do you have? Most receivers aren’t really “upconverting†S-Video or Composite sources to Component. What they’re really doing is sending the original source through the receiver using one output connection. So you’re still getting S-Video or Composite quality. Meaning that you can’t get 480p through a S-Video connection even though the component cables are the last link in the chain.
post #5 of 6 Old 01-04-2005, 12:17 PM - Thread Starter
brianbes's Avatar
I have a Yamaha RXV-750 which is unless you know better its doing exactly what you said, just allowing you to output to component. The Z2 interlacer works pretty well, I have two Go Video DVD-VCR players, one no progressive scan and the second with progressive scan. Tell you the truth I think the one without Progressive Scan produces a better picture thru composite than the one which is progressive thru component. I don't expect it to be perfect but I'm guessing the Svideo output has to look better than composite.
brianbes is offline
post #6 of 6 Old 01-10-2005, 10:25 AM
eawil's Avatar
Both the Xbox and PS2 have mediocre DVD players. However, that being said, the latest PS2 has the better DVD player. It has progressive scan, and a little more modern software on board.
If movies are important to you, you'll probably want to pick up a seperate DVD player, though.
eawil is offline
Closed Thread PlayStation Area
