TVs limited by FPS for gaming? - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2005, 05:24 PM - Thread Starter
punkzip's Avatar
I am thinking about buying a TV that supposedly can only do 30 fps - will this be limiting for video games? How about computer games? Which TVs can do above 30 fps? What will happen if you try to play a game with higher than 30 fps?
punkzip is offline
Old 01-15-2005, 05:50 PM
getme's Avatar
The Ntsc Video standard is 30 fps, it has nothing to do with limiting the FPS on a game. As long as your tv an display a 60hz refresh rate (all tvs do) there will be no problem. There is no such thing as a tv limited to 30 fps.
the arrogance of officialdom should be tempered and controlled... People must again learn to work, instead of living on public assistance. Cicero , 55 BC
getme is offline
Old 01-15-2005, 09:46 PM
Dean Martin's Avatar
I would look more for a TV that will allow the connections you need including DVI or VGA for a PC and make sure the TV you get is PC compatible.
Dean Martin is offline
Old 01-16-2005, 01:30 AM
bkwong73's Avatar
Does anyone here have a plasma tv that can support Computer resolutions?
BK
bkwong73 is offline
Old 01-16-2005, 01:38 AM
turt's Avatar
Quoted: 18 Post(s)
Yes.
Ron
turt is offline
