Novice question on PS2 DVD playback - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-01-2005, 07:10 PM - Thread Starter
poethius's Avatar
A friend of mine is using a PS2 to play DVD's, but can't seem to configure the thing to put out the "enhanced" or "anamorphic" 16:9 format, which his widescreen TV will display correctly. He can, of course, get the letterboxed output, at lower picture quality. I'm not at all familiar with the PS2; can anyone tell me how to set it up right?
poethius is offline
post #2 of 8 Old 02-01-2005, 10:21 PM
N8N
N8N's Avatar
You need to go into the DVD menu and set the option.
N8N is offline
post #3 of 8 Old 02-02-2005, 01:17 PM - Thread Starter
poethius's Avatar
OK, but can you give me a little more detail? My friend found his way to a menu that presented options that looked like "4:3 Full 16:9". But whichever one he selected, he got a 16:9 picture letterboxed within a 4:3 frame. Was this the right menu? Did he have to click on something special after selecting the item in order to make the selection take hold?
Poethius
poethius is offline
post #4 of 8 Old 02-02-2005, 01:59 PM
psycho's Avatar
you have to acces the setup menu with a DVD stoped, hit select, you'll figure it out from there.
psycho is offline
post #5 of 8 Old 02-02-2005, 09:40 PM
tokerblue's Avatar
Quoted: 94 Post(s)
Liked: 66
What DVD are you playing? Are you sure the DVD you're trying to play back isn't a Letterbox DVD? You'll need an Anamorphic DVD to make sure it's outputting correctly.
tokerblue is offline
post #6 of 8 Old 02-03-2005, 01:18 AM - Thread Starter
poethius's Avatar
We tried a couple of them, both marked "enhanced for 16:9 playback" or something like that. We'll try again. Thanks, all!
poethius is offline
post #7 of 8 Old 02-03-2005, 08:34 AM
Jordan420's Avatar
Jordan420 is offline
post #8 of 8 Old 02-03-2005, 05:58 PM - Thread Starter
poethius's Avatar
Thanks, guys! I think I have enough info now to go over and help my friend get this to work. If I run into a problem, I'll be back in touch.
poethius is offline
Closed Thread PlayStation Area
