Help me with my component cables plz for PS2 - AVS Forum | Home Theater Discussions And Reviews
Old 03-01-2005, 04:39 PM - Thread Starter
Apollo 13's Avatar
I got some PS2 sony component cables, well I have them hooked to my PS2 and TV, but im getting no signal while my PS2 is on. When I switch to composite the PS2 works fine.
Apollo 13 is offline
Old 03-01-2005, 04:53 PM
FourDoor's Avatar
What make/model TV do you have? Could it be possible that your component inputs on your tv does not support 480i? Do you still get sound when you power up the PS2?
FourDoor is offline
Old 03-01-2005, 05:01 PM - Thread Starter
Apollo 13's Avatar
This is the set I have http://www.bestbuy.com/site/olspage....2&type=product
it works fine with my gamecube and its component cables.
Do I have to put the PS2 in progressive scan first in order for it to work with my component cables? I thought it was plug in play.
*EDIT* for some wierd reason I get audio from my PS2 when I hook up my component cables to my cable box and leave the PS2 Sony componenet cables audio cords in.
Old 03-01-2005, 07:00 PM
Mcklein's Avatar
Do you have the ps2 component on input 2 on your tv/ since it displays 480i, also remember to go into the ps2 configuration screen to set it for component pb,pr,y..it should be set then
Mcklein is offline
Old 03-01-2005, 07:22 PM - Thread Starter
Apollo 13's Avatar
Thx that helped me out a lot.
Old 03-01-2005, 08:49 PM
Mcklein's Avatar
So everything is cool now?
Mcklein is offline
