PS3 problems and setup issues thread! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2930 Old 11-17-2006, 05:30 AM - Thread Starter
Kysersose's Avatar
Quoted: 12 Post(s)
Liked: 34
Please post any and all PS3 problems/setup issues here.
Kyser
"Good... Bad... I'm the guy with the gun."
Ash - Army of Darkness
Kysersose is offline
post #2 of 2930 Old 11-17-2006, 09:22 AM
Slacker George's Avatar
Liked: 33
Has anyone been able to register their PS3 online yet?
http://www.register.us.playstation.com
Not the playstation network, but the hardware registration. It won't take the number from the back of my PS3 or the number on the warranty card.
Slacker George is offline
post #3 of 2930 Old 11-17-2006, 09:53 AM
birdog's Avatar
cannot get 1080p through hdmi on 50 inch sxrd kd-r50xbr1
this is very frustrating because i was told by both best buy and sony that i should be able to achieve this resolution
birdog is offline
post #4 of 2930 Old 11-17-2006, 10:09 AM
a7las's Avatar
Can get 1080p through HDMI on 42 inch Westinghouse (LVM 42W2). However, image contains moving white sparkles around much of the text and practically anything in motion on the screen. Bumping the resolution down to 720p solves the problem, but does not make me happy!
a7las is offline
post #5 of 2930 Old 11-17-2006, 10:11 AM
Mongoos150's Avatar
^ According to CNET your TV doesn't display 1080p.
"Supported DTV Resolutions 480i, 480p, 720p, 1080i"
Bear Down!
See how your Blu-Ray movies stack up. Visit the Blu Ray Tier thread today.
Blu Ray Titles: 17
PSN=Neko150
Mongoos150 is offline
post #6 of 2930 Old 11-17-2006, 10:18 AM
mboojigga's Avatar
Quoted: 627 Post(s)
Liked: 859
Say it correctly now the TV does display 1080P, it just cannot recieve a 1080P signal.
The 5.0 is here
mboojigga is offline
post #7 of 2930 Old 11-17-2006, 10:27 AM
Jon_Irenicus's Avatar
This is incorrect. It can receive 1080P. Though there are some issues with the early models not being able to accept 1080p correctly through HDMI due to a weak chip.
Jon_Irenicus is offline
post #8 of 2930 Old 11-17-2006, 10:29 AM
Davio's Avatar
I hate to be the bearer of bad news, but this was the main problem with the first xbr TV's. They DO NOT accept 1080p inputs. Im afraid you are SOL.
Davio is offline
post #9 of 2930 Old 11-17-2006, 10:51 AM
ay221's Avatar
Is 1080i really that bad from 1080p? Will you really notice it?
ay221 is online now
post #10 of 2930 Old 11-17-2006, 11:02 AM
valav's Avatar
I'm really curious to hear how people like the PS3. Let me know your thoughts. I'm anxious to buy one to hook up to my OPPO combo. Thanks!
valav is offline
post #11 of 2930 Old 11-17-2006, 11:09 AM
UxiSXRD's Avatar
How about no. The XBR1 does not accept 1080p on any input, though it only displays 1080p, upscaling and/or deinterlacing to get there. The A2000 and XBR2 take 1080p over HDMI only. Check the XBR1 owners thread in the Rear Projection forum.
I can't wait for a PS3 for my 60XBR1, but I'll be doing 1080i output just like I do with the 360.
-- "No matter where you go, there you are."
SXRD/Denon/Polk/PS3/360/WiiU
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #12 of 2930 Old 11-17-2006, 11:20 AM
birdog's Avatar
just got off the phone with bb after chewing them out. they are going to call me back and tell me what they can do. I'll keep you posted
birdog is offline
post #13 of 2930 Old 11-17-2006, 11:27 AM
RAVEN56706's Avatar
please dont call bestbuy... they will tell you a toaster is 1080p
2011 SUPERBOWL CHAMPIONS- New York Giants!!!
Gamertag: GENERAL CUPKAKE
RAVEN56706 is offline
post #14 of 2930 Old 11-17-2006, 11:31 AM
UxiSXRD's Avatar
For what? Sounds like you didn't do enough research on the set... Sony never advertised as capable of 1080p inputs. The set IS a 1080p set since it only displays 1920 x 1080 progressive and has a fine deinterlacer.
Now if BB (or their salesschmuck) lied to you, you might have a grevience, but that's unlikely, though it's possible their salesguy just didn't know what he was talking about. In any case, difficult to prove unless you have it in writing (which is extremely unlikely).
Not that I think you'll see much benefit from 1080p HDMI versus 1080i over HDMI with your TV doing the deinterlacing.
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #15 of 2930 Old 11-17-2006, 11:35 AM
L_T
L_T's Avatar
No since any display that is 1080p will take a 1080i signal and adjusted it for 1080p.
Only one problem is that the PS3 doesn't output a 1080i signal. So early adopter with CRT projection TVs that can only display 480i/p and 1080i are screwed. IGN did some tests and it will default to 480p. Bad news for owners of these sets.
L_T is offline
post #16 of 2930 Old 11-17-2006, 11:41 AM
You've quoted me out of context. I was refering to the Westinghouse LVM 42W2
post #17 of 2930 Old 11-17-2006, 11:50 AM
UxiSXRD's Avatar
Ah, I did. Sorry!
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #18 of 2930 Old 11-17-2006, 11:57 AM
alexend's Avatar
Quoted: 21 Post(s)
a7las, did you try 1080p via component cable or with a HDMI --> DVI cable to the DVI connector of the 42w2?
alexend is offline
post #19 of 2930 Old 11-17-2006, 12:32 PM
oldbucsfan's Avatar
You cannot get 1080p on component. It must be VGA, DVI, or HDMI.
oldbucsfan is offline
post #20 of 2930 Old 11-17-2006, 01:21 PM
alexend's Avatar
Quoted: 21 Post(s)
oldbucsfan, if you say that it's impossible to output 1080p via component, you're wrong since Xbox360 can output 1080p with componant cable.
But if you're saying the PS3 doesn't output 1080p via component, then that might be true.
alexend is offline
post #21 of 2930 Old 11-17-2006, 01:34 PM
a7las's Avatar
According to Westinghouse's specs, it does not accept 1080p over component cables.
No, I have not tried a HDMI to DVI adapter because I don't own one. I was hoping to avoid buying one, but it appears that I have the older model of the LVM 42W2 with the weak chip that you mentioned. I assumed I was fine because I have 1.19 firmware, but it seems that the new and improved 1.0 is better??
a7las is offline
post #22 of 2930 Old 11-17-2006, 01:50 PM
Hyp Toad's Avatar
I recall reading somewhere that may have been a misprint. I have 360 hooked up via component to the 42" Westy and it certainly accepts a 1080p signal via that connection. It won't play DVDs back at that res, but the dashboard says it's feeding a 1080p signal and the TV says that's what it's receiving.
Hyp Toad is offline
post #23 of 2930 Old 11-17-2006, 02:44 PM
Liked: 33
Having an audio problem with RR7. I'm hooked up with HDMI to the TV and optical to my AV reciever for sound. If I have Dolby Digital 5.1 selected in audio options RR7 has no sound at all. If I unselect it everything's fine, but then there's no surround for RR7.
Tried a couple of blu-ray movies and a downloaded video with no problems at all.
post #24 of 2930 Old 11-17-2006, 03:11 PM
jman069's Avatar
Quoted: 29 Post(s)
HELP!
My PS3 will not accept a disc in the disc drive. I have tried PS2 games, Resistance Fall of Man and Talledega Nights and nothing works. Called Sony and the rep I spoke to was clearly using scripting and didn't know it came with a free movie. She told me they will have to replace and can take up to 14 days!!!
When I put in a disc it doesn't pull it in all the way like a car cd player would. I never force it but give it a little nudge and it won't go in all the way. Press the eject button and it starts to eject and then gets stuck and I pull on it for a sec then it comes out all the way. I have powered down several times and tried again. I have tried more than one disc with no luck. I have tried to get the disc all the way in again without forcing it and no luck.
I didn't try it before the update but I don't think the update has anything to do with it.
Any and all help appreciated.
J
jman069 is offline
post #25 of 2930 Old 11-17-2006, 03:26 PM
Liked: 33
Originally Posted by jman069 View Post
HELP!
J
That sounds bad . It should just slip right in with hardly any pressure at all. I can't think of anything outside of a hardware malfunction that would cause that.
Unless... (sorry, this sounds really dumb) there was already a disc inside the PS3 somehow when you first tried to insert a disc.
post #26 of 2930 Old 11-17-2006, 03:31 PM
jman069's Avatar
Quoted: 29 Post(s)
no disc in the drive. If I give it a little nudge it will go in about 90% of the way and that's as far as it'll go and I don't want to force it.
jman069 is offline
post #27 of 2930 Old 11-17-2006, 04:25 PM
Hetz's Avatar
I have the SAME problem. Downloaded games work fine, but any game that is on a disc will not output surround sound.
Help!
Hetz is offline
post #28 of 2930 Old 11-17-2006, 04:59 PM
Hetz's Avatar
Ok, well I just rebooted the console and now it all works fine!
Hetz is offline
post #29 of 2930 Old 11-17-2006, 05:00 PM
Liked: 33
Good deal. I'll have to play around with it some more.
post #30 of 2930 Old 11-17-2006, 05:27 PM
abates25's Avatar
So...questions and comments....
I have a Westinghouse 42w2 rev 1.19. It is a set which does accept 1080p signals through all of it's ports (well...not composite or S-Video...). I know that the HDMI ports have the issue of hot/sparkly pixels for sets prior to the (confusingly newer) 1.0 sets. I would be thrilled to hear about peoples experiences with this set, a PS3, and a HDMI -> DVI connection and component connection. Success? Failure? Results? Thanks!
abates25 is offline
Reply PlayStation Area
Playstation 3 160gb System
