PS3, HDMI, and HDTV compatibilty - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 1373 Old 11-18-2006, 10:43 PM
Schmev's Avatar
I can confirm that before I was able to fix my HDMI issue, I had mine set to 1080i, and both Resistance and the Motostorm Demo both downscaled to 480p (Both are native 720p games). When I could get my 1080p to display correctly (see my post above), both of these titles did remain in Widescreen HD, which seems that it will upscale, but it must remain in progressive mode throughout the whole process.
Schmev is offline
post #32 of 1373 Old 11-19-2006, 03:58 AM
Slacker George's Avatar
Liked: 33
So you're saying the PS3 can upscale 720p games to 1080p, just not 1080i?
Slacker George is offline
post #33 of 1373 Old 11-19-2006, 07:28 AM
Jerz's Avatar
If it has to scale RFOM to get the full picture on the Samsung LNS4696D to get 1080P then it work fine for me. Resistance looks good in all 46 inches.
Jerz is offline
post #34 of 1373 Old 11-19-2006, 07:49 AM
IeraseU's Avatar
Guys...concerning the issue of 720p games not upscaling to 1080i, can someone post an e-mail address to PS3 customer support so that AVS members can mass e-mail Sony about this problem, and hopefully if enough people do it we can expedite a resolution.
I did personally check all the paperwork and manuals that came with my PS3, but there was no e-mail listed for customer service. There is a phone number which is: 1-800-345-7669 in case anyone would prefer to call.
Edit: I came up with this link on the Playstation website for customer support in case someone would like to give it a try:
http://www.us.playstation.com/Corpor...nsumerServices
PS Network: HZR
Xbox 360 Tag: HZR Nam 75
Wii Connect: 7793 3308 1436 9373
I support cycle commuting.
IeraseU is offline
post #35 of 1373 Old 11-19-2006, 09:01 AM
speng9's Avatar
The connection for HDMI on the PS3 can get loose very easily and you lose picture.
This was probably what was happening to me as it happens often now. Even a slight shake from your sub-woofer on the TV stand can cause the hdmi to disconnect.
Speng.
PSN: Krelic
speng9 is offline
post #36 of 1373 Old 11-19-2006, 09:31 AM
HybridHB's Avatar
Westinghouse 37w3 and ps3 gets non stop picture flashing when the ps3 changes resolutions. Turning the TV off then on will fix it. Anyone know how these are doing with the SXRD A2000's?
HybridHB is offline
post #37 of 1373 Old 11-19-2006, 09:37 AM
ToddUGA's Avatar
Quoted: 36 Post(s)
Liked: 29
If I could get my hands on one without having to get a second mortgage, I'd test it out on my A2000.
ToddUGA is offline
post #38 of 1373 Old 11-19-2006, 09:45 AM
K-10's Avatar
can anyone comment on the ps3 with either one of these hdtvs?
samsung lns4051
samsung lns4092
K-10 is offline
post #39 of 1373 Old 11-19-2006, 03:06 PM
RommelB's Avatar
I have the Sony R60XBR2. Monoprice HDMI cable works perfectly fine with ps3 for me. BR looks good!
- I don't understand Fanboys.
RommelB is offline
post #40 of 1373 Old 11-19-2006, 05:18 PM
vthee's Avatar
Quoted: 14 Post(s)
I have my ps3 plugged into my denon 4806 via hdmi. When I set the ps3 to output 1080p i get sparkly artifacts on the ps3 user interface as well on talledega nights. My tv is a 70"xbr2. Is the problem on the reciever or the ps3? anybody have this problem? When i set the ps3 to output 1080i everything is perfect.
any work arounds or is this a known problem.
vthee is offline
post #41 of 1373 Old 11-19-2006, 05:20 PM
vthee's Avatar
Quoted: 14 Post(s)
Whats the best config for sound? digital or hdmi? what is the difference between linear pcm adn bitstream for the bd-rom configuration.
Sorry for the double post... thanks in advance.
vthee is offline
post #42 of 1373 Old 11-19-2006, 06:00 PM
jpzsports's Avatar
Ya - I'm a little confused about this also. If you're using an HDMI cable, then what's the point of using a digital optical also? Which is better?
BTW - Can I use the HDMI cable for PlayStation 3DLC-HD20P, which supports HDMI 1.3, even if my TV only has HDMI v1.1 or 1.2?
Also, does anyone know what version of HDMI is in the KDS-R60XBR2 ? And what's the difference between HDMI 1.1 and 1.2?
jpzsports is offline
post #43 of 1373 Old 11-19-2006, 06:49 PM
djpheer's Avatar
I am trying to find someone with an A2000 and PS3 as well to see how they are doing. I have a 60A2000, but alas I cannot get ahold of a ps3.
Samsung 60'' 7150 Series
djpheer is offline
post #44 of 1373 Old 11-19-2006, 07:01 PM
WYSEGUY's Avatar
37w3-flashing screen and no signal, turn off the tv and turn it back on and it seems to work.
this is my problem, will this ever be fixed? with a firmware update, or is it an issue with the tv?
WYSEGUY is offline
post #45 of 1373 Old 11-19-2006, 10:07 PM
Schmev's Avatar
My post on the first page states I tried a HDMI-DVI adapter and the sparklies are all gone at 1080p now. Perhaps it could be inconvenient for you, but it's a proven workaround IME.
Schmev is offline
post #46 of 1373 Old 11-19-2006, 10:10 PM
Schmev's Avatar
I don't know what's better, but I run my HDMI cable to my TV, and the Optical cable goes to my component video switch and then to the receiver for decoding.
Schmev is offline
post #47 of 1373 Old 11-19-2006, 10:33 PM
WYSEGUY's Avatar
i have the 32" westinghouse, if i use a HDMI-DVI adaptor will the blinkin/flickering screen go away?
WYSEGUY is offline
post #48 of 1373 Old 11-19-2006, 10:40 PM
mboojigga's Avatar
Quoted: 590 Post(s)
Liked: 822
The PS3 is the only device on the market that has HDMI 1.3 so no no display has 1.3 yet. You can connect to any HDMI port it doesn't matter what version as far as connection goes.
As far as HDMI and Fiber Optic, if you have a HDMI reciever then you don't use fiber optic. If you don't have an HDMI reciever then you have to use optic to get digital surround from the PS3
The 5.0 is here
mboojigga is online now
post #49 of 1373 Old 11-19-2006, 11:05 PM
vthee's Avatar
Quoted: 14 Post(s)
Is this a known problem or is something wrong with the ps3?
vthee is offline
post #50 of 1373 Old 11-19-2006, 11:20 PM
rkim87's Avatar
hey all
i'm using a sony kdl-v32xbr1
connected through hdmi
runs flawlessly, i've played resistance for hours and hours so far and i can't complain
i haven't had any of the problems i've read about (knock on wood)
haven't had a chance to play talladega nights or any other blu-ray dvd or standard dvd for that matter..i'll post again when i get a chance to do so
rkim87 is offline
post #51 of 1373 Old 11-19-2006, 11:20 PM
TwinTurboZX's Avatar
It seems that the PS3 doesn't automatically switch based on the game content's resolution. I tried hooking the PS3 up to my XBR960 via HDMI and resistance would output at 480p when the XMB was set to 1080i. I had to manually switch the XMB to 720p in order for the game to output 720p. This also goes for the Motorstorm demo. On the other hand, when I had the XMB set to 720p and put in the Talladega Nights BD, the PS3 automatically switched to 1080i when the disc started playing.
TwinTurboZX is offline
post #52 of 1373 Old 11-20-2006, 11:25 AM
WYSEGUY's Avatar
i have this problem, i was wondering is this something that could be fixed with a firmware update? or is this something that will always happen no matter what?
WYSEGUY is offline
post #53 of 1373 Old 11-20-2006, 12:32 PM
cjmcgee's Avatar
JVC HD-61FN97: (rear projection HD-ILA, with I believe has the latest HDMI 1.3 support)
With the PS3 hooked up to the HDMI:
- 1080p works with no problems
- 720p work with no problems
- 480p (might be i... whatever is used when booting PS2 games) I get a flashing input and the TV never synchs. If I switch from the HDMI cable to the PS3's composite cable then I can see these 480i games fine.
With my cable box hooked up via HDMI 1080i, 720p, and 480i all work with no problems. (The cable box does not upscale these in my setup)
It seems odd that it is having problems with 480p, but not the higher resolutions...
cjmcgee is offline
post #54 of 1373 Old 11-20-2006, 03:38 PM
benso37's Avatar
Quoted: 45 Post(s)
Has anyone tried the playstation 3 with one of the 3 HDMI ports on the Hitachi 42HDT79 or 42HDS69? Does it accept the resolution at 720p or 420p?
benso37 is offline
post #55 of 1373 Old 11-20-2006, 07:05 PM
jpzsports's Avatar
I thought that there aren't any TVs currently available that use HDMI 1.3 - am I correct?
post #56 of 1373 Old 11-20-2006, 07:22 PM
WYSEGUY's Avatar
is the screen flickering on the westinghouse tv fixable? or is it permanent, maybe with a firmware update?
WYSEGUY is offline
post #57 of 1373 Old 11-20-2006, 08:29 PM
HybridHB's Avatar
I hope the westinghouse issue gets fixed with the next ps3 update. I think ill just get a better tv such as the A2000 though.
HybridHB is offline
post #58 of 1373 Old 11-20-2006, 09:27 PM
HighLatency's Avatar
I have my PS3 hooked up to my Westinghouse LVM-37W3 via HDMI and I have this problem as well.
Will using an HDMI to DVI converter work as a workaround until this is fixed?
HighLatency is offline
post #59 of 1373 Old 11-20-2006, 09:31 PM
Dralt's Avatar
Are we sure the issue is on the PS3 side?
Dralt is offline
post #60 of 1373 Old 11-20-2006, 09:39 PM
WYSEGUY's Avatar
heres a link to something a guy said on another forum
http://www.hardforum.com/showpost.ph...&postcount=648
he didnt specify what his friends tv was tho...
WYSEGUY is offline
Reply PlayStation Area
Westinghouse , Jvc , Playstation 3 160gb System
