It doesn't work. I have a Dell 2405 and a PS3. I bought a HDMI to DVI cable. All I saw was some colored lines going vertically down my screen. I went back to the people that sold me my cable, and I brought my PS3 Quick Reference manual. The manual says, "If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system. Copyright-protected Blu-ray video discs can only be output at 1080p using an HDMI cable connected to a device that is compatible with the HDCP (High-bandwidth Digital Content Protection) standard."
The Dell 2405 does not support HDCP. I believe that the 2407 supports HDCP.
One can get high definition using the component cables, but the picture isn't as good.
Anyone want to buy my 2405 or my PS3? I need to get rid of one of them. I, either, need to buy the 2407 or sell my PS3. Actually, I like the computer games better than the PS3 games. One can do so much more with a computer game, and it is easy to upgrade a computer. I really don't even like the Blu-ray because it is a reader not a burner.
I don't care for Sony that much. When XBOX came out, they didn't make Xbox so Xbox would only work on some tvs. PS3 could have made it so that the PS3 could work on any high def monitor. It is probably Sony's high def monitors that are mostly HDCP. They probably just want to sell more of their hi def products. Anyway, this isn't good. Also, when I go to BEST BUY, the PS3 is always down, glitched up. Today, when I went there, they didn't even have the PS3 on.
