Wireless Router Poll (read even if not using currently) - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Wireless Router Compatibility with PS3
I use a wireless (b) router and it doesn't work 40 4.06%
I use a wireless (b) router and it works fine 71 7.21%
I use a wireless (g) router and it doesn't work 27 2.74%
I use a wireless (g) router and it works fine 206 20.91%
I use a wireless (b/g) router and it doesn't work 73 7.41%
I use a wireless (b/g) router and it works fine 568 57.66%
Multiple Choice Poll. Voters: 985. You may not vote on this poll
post #1 of 724 Old 11-21-2006, 09:27 PM - Thread Starter
dogdoctor's Avatar
I would like to see if with the 40, 60, or 80Gb or wireless adapted 20Gb PS3 if there is any apparent router communication problem. If you prefer to use hardwired ethernet that is your preference, but if you could help other AVS members out that would be awesome. If you have a wireless router, see if you can maintain a connection.
If you could please post the router type/model to help futher AVS wireless router/PS3 users check for compatibility.
Thanks in advance.
UPDATE - SSID Broadcast Alert! - 12/21/06
According to protoboard's post - he has found a fix for the disconnect/connect issue (repeated connects/disconnects with about 15-30 second intervals) with the linksys wireless b router by turning of the routers broadcast of the SSID information. Since then he has had no disconnects. He has made it aware to Sony as have I in a phone call today via a followup to my orginal problem. This may or may not work for other routers that have fallen into the not working category.
This has apparently fixed the problem with a netgear (b) router as well.
UPDATE - Changed Categories - Working - 01/10/07 - Belkin F5D7230-4 b/g
UPDATE - Changed Categories - Working - 02/15/07 - Belkin N1
UPDATE - WRT54G Firmware Fix - 6/8/07 - Linksys Routers
After reading many posts on the Playstation forums and here at AVS, I felt it was necessary to update this thread. At the time of FW 1.8 release on 5/24/07 many Linksys wireless router users were once again stricken with a disconnect issue. As it turns out the problem originated in the implementation of the media sharing feature of the PS3. There 2 are potential solutions depending upon your situation. ONE: disable the media sharing feature on the PS3 if you don't plan to use it. TWO: disable UPnP in the router. For most people just turning off UPnP solved the issue. Others went on to finally set up a static IP for the PS3 (many of us had already done that) and then enable DMZ in the router for the PS3 IP and in some cases that helped as well. Until Sony or Linksys creates a fix - these are the possible workarounds.
If you have the WRT54G router, there is a new firmware that may fix some of these issues: Linksys WRT54G update firmware.
As of 06/23/2009 with 2.8 firmware
Routers that Work:
2Wire 1701HG
2Wire gaming adaptor
Airlink AR325w wireless-g
Actiontec MI424WR
Apple 500 gigabyte AE Time Capsule
Apple AirPort Express b/g
Apple Airport Extreme (the square, draft-N one)
Apple Airport Extreme Base Station 802.11 b/g
Asus WL-500G Premium
Belkin F5D7230-4 b/g†
Belkin F5D8233-4 N
New Update! Belkin F5D8236-4 N (ver. 1110) (Works with PS3/PSP on secured wireless)
Belkin F5D9230-4 b/g
Belkin F6D3230-4 b/g
Belkin Pre-N
Belkin N1†††
Buffalo N Nfiniti
Buffalo WHR-G125
Buffalo WHR-HP-G54 b/g
Cisco Aironet 1130G Series IEEE 802.11g Access Point
D-link DI-524 802.11 b/g 2.4GHz*
D-link DI-614+ 802.11 b
D-link DI-624
D-link DI-784**
D-link DIR-625 802.11 (b/g/draft n)
D-link DIR-655
D-link DGL-3420 Wireless Adaptor
D-link DGL-4300 802.11 b/g 2.4GHz
D-link DGL-4500
Juniper 5gt b/g**
Linksys BEFW11S4 802.11 b 2.4GHz**
Linksys WGA54G Wireless Gaming Adaptor
Linksys WRT150N
Linksys WRT300N
Linksys WRT310N
Linksys WRT330N
Linksys WRT350N
Linksys WRT54G v1.0, 2.0, 5.0, 6.0, 8.0***(not the X4 Version)
Linksys WRT54G2
Linksys WRT54GC
Linksys WRT54GL††
Linksys WRT54GS v4.0, 6.0, 7.0 (not 2.0)
Linksys WRT600N
Microsoft MN-700****
Motorola SURFboard SBG900
Netgear DG834PN
Netgear MR814 v2.0 wireless B**
Netgear WGR614 v6.0
Netgear WGT624 v3.0 802.11b/g 2.4GHz
Netgear WGT634U 802.11b/g 2.4 GHz (firmware 1.4.1.10)****
Netgear WPN824 802.11 b/g RangeMax****(thanks Sorry Colts/Freshmeat36)
Netgear WNR854T Pre-N Rangemax
SMC 2804WBRP-G
SMC 7004AWBR
New Update! TRENDnet TEW-432BRP
TRENDnet TEW-631BRP EWC 802.11 (b/g/draft n)
U.S. Robotics Wireless MAXg Router (USR5461)
____________________________________
*with a router reset and without wep - changed categories to working.
**you must turn off the SSID broadcast feature in the router and maybe security.
***if not working check the version number and try using/not using different security measures.
****try different security settings (may not like wep, wpa, or may not like both according to different posters)
†SSID dissabled, no security, open DMZ, enable UPnP and open Ports:tcp/udp 10070-10080, udp 6000-6999
††using DD-WRT firmare: please refer to brazzle's post for further settings for the WRT54GL
†††Please refer to Tripjammer's post in the N1 thread for correct firmware protocols and settings that has found to work with the PS3.
Routers that Don't Work:
Belkin F5D8230-4
Linksys WRT54GS v2.0
Linksys WRT54GX4
PSN ID: dogdoctor
dogdoctor is offline
post #2 of 724 Old 11-21-2006, 09:34 PM
one43637's Avatar
good idea.
Netgear WGT624 v3
802.11b/g 2.4GHz
Wireless works
"After all is said and done, more is said then done..."
one43637 is offline
post #3 of 724 Old 11-21-2006, 11:07 PM
gmorganonw's Avatar
D-link DI-524
802.11b/g 2.4GHz
Doesn't work
gmorganonw is offline
post #4 of 724 Old 11-21-2006, 11:42 PM
Irunnoft's Avatar
DGL 4300
802.11b/g 2.4GHz
Works fine
GT: irunnoft
Irunnoft is offline
post #5 of 724 Old 11-22-2006, 12:44 AM
A7MAD's Avatar
I do not hate, this is not a fanboy post or anything of the sort.
I want to point out the X360 also has compatibility issues with Wireless Routers, which is why MS suggest people buy certain kinds.
From the list you guys have here and what is available here seems the same routers mentioned work with the X360's wireless adapter.
It may be that the compatible routers for the X360's XB Live will also be compatible for the PS3
LIVE: A7MAD
PSN: A7MAD_AU
A7MAD is offline
post #6 of 724 Old 11-22-2006, 05:57 AM
Dagg21's Avatar
I am using Netgear MR814v2 802.11b which does not work.
Dagg21 is offline
post #7 of 724 Old 11-22-2006, 06:52 AM
mjcoffey's Avatar
Apple Airport Extreme Base Station 802.11b/g
works fine with 60 GB PS3
"I believe there is something out there watching us. Unfortunately, it's the government." -- Woody Allen
mjcoffey is offline
post #8 of 724 Old 11-22-2006, 07:21 AM
TwinsPoppa's Avatar
Actiontec MI424WR, 60GB PS3 (35% signal strength), using it with Verizon FIOS Internet no problems.
TwinsPoppa is offline
post #9 of 724 Old 11-22-2006, 08:37 AM
firefighter81's Avatar
Linksys WRT54G works perfectly fine here, not a single disconnect.
firefighter81 is offline
post #10 of 724 Old 11-22-2006, 08:42 AM
RommelB's Avatar
Linksys Wireless WRT54G
97% Signal strength from 17 feet
Have not had any disconnect - Only been using for 2 days.
- I don't understand Fanboys.
RommelB is offline
post #11 of 724 Old 11-22-2006, 08:46 AM
RommelB's Avatar
reseting your modem, router, and pc will most likely fix start up problems.
RommelB is offline
post #12 of 724 Old 11-22-2006, 08:57 AM
foulplay's Avatar
Linksys WRT54GX4
I've tried:
restarting modem/router
static IP with port forwarding/DMZ
Switching wireless channel
Allowing just my PC and PS3's mac addys and disabling WPA
Nothing has fixed my problem of constant disconnects from the Playstation Network, but I can still browse the web perfectly on it, which really frustrates me (browser works great, can't sign into PSN)
foulplay is offline
post #13 of 724 Old 11-22-2006, 09:05 AM
Interesting that two people with the standard WRT54G have no problems, but your variation "X4" has problems.
So you can browse the web using the PS3 browser? But when you connect to the PSN it disconnects you? Wow, if that's the case, I have no clue, and the problem is way over my head.
post #14 of 724 Old 11-22-2006, 09:51 AM
bleedblue63's Avatar
Linksys WRT54G works perfectly fine here. I have the router on the 2nd floor and my PS3 is in the basement with 70% signal strength. Downloaded mororstorm demo fine 1st shot. When I downloaded F1 I got one timeout error but on the second try it went through fine. It took some time though. Motor Storm took about 65 min.
Nothing is perfect if you look hard enough.
bleedblue63 is offline
post #15 of 724 Old 11-22-2006, 10:08 AM
rocko1290's Avatar
Linksys BEFW11S4 802.11b 2.4GHz (mine)
D-link DI-524 802.11b/g 2.4GHz
Netgear WPN824 802.11 b/g RangeMax Wireless Router (from playstation boards)
I have the DI-524 and would like to use the wired connection on my PS3 (which I don't have yet). Is this thread only referring to the wireless portion of the router? Will a wired connection to the DI-524 work with PS3?
XBL: Rocko1290
PSN: Rocko1290
rocko1290 is offline
post #16 of 724 Old 11-22-2006, 10:11 AM
Theoretically wired connections should have no issues whatsoever. I haven't heard of a single person yet having problems while wired.
post #17 of 724 Old 11-22-2006, 10:29 AM
foulplay's Avatar
Yeah I'm rather confused with the whole situation. A "possible fix" has been posted on the official playstation boards, which is to switch out your primary DNS with your secondary/tieritary*sp*. I'm going to try it once I get home.
Wierd thing is that my signal never drops below 95% yet I still have all of these connection problems.
foulplay is offline
post #18 of 724 Old 11-22-2006, 11:07 AM
RommelB's Avatar
My post from another thread -
I don't think it has anything to do with routers of any brand. I have the Linksys Wireless WRT54G without the signal booster. It's actually pretty fast. But i know someone who bought the exact same router and always getting disconnected. we're both about 20 feet away from the router. My signal strength is 97%. i don't know his.
RommelB is offline
post #19 of 724 Old 11-22-2006, 11:29 AM
one43637's Avatar
it might be useful to include the firmware version each router is using.
one43637 is offline
post #20 of 724 Old 11-22-2006, 11:42 AM - Thread Starter
dogdoctor's Avatar
Mine works fine wired...just not wireless.
That would be a great a idea too. I know mine is the latest for my router - I checked the linksys website. Will post later - need to work.
PSN ID: dogdoctor
post #21 of 724 Old 11-22-2006, 11:44 AM
RommelB's Avatar
How do I check what firmware i have? I won't be home for another 10 hours but I'll check. I just bought the router 4 days ago and have not updated anything. I didn't even bother to use the disc that it came with. I just plug and play. I didn't know routers needed firmware updates. if that's that case the router at my parents house is 5 years behind in updates haha.
RommelB is offline
post #22 of 724 Old 11-22-2006, 12:47 PM
one43637's Avatar
you can check the firmware you're running when you log into your router and check the status page.
one43637 is offline
post #23 of 724 Old 11-22-2006, 04:50 PM
Stupac's Avatar
Sony will come out with one of these list I'm sure. It takes a while to verify it all.
Stupac is offline
post #24 of 724 Old 11-22-2006, 06:32 PM
Gai
Gai's Avatar
Apple Airport Extreme Base station works perfect with mine.
Thanksgiving can be a sham, but it's a sham with yams. It's a yam sham.
Gai is offline
post #25 of 724 Old 11-23-2006, 02:11 PM - Thread Starter
dogdoctor's Avatar
Polite Bump...keep the feedback coming.
PSN ID: dogdoctor
post #26 of 724 Old 11-23-2006, 02:30 PM
kenchi's Avatar
D-Link DIR-625 802.11 (b/g/draft n)
Works Great.
This is my 2nd wireless router, and it literally took 5 min to set up.
kenchi is offline
post #27 of 724 Old 11-25-2006, 09:21 AM - Thread Starter
dogdoctor's Avatar
RommelB - I just picked up the wrt54g v6.0 and it works fine too but I was reading on the playstation forums about a person with the wrt54g v5.0 wigh problems. I would check the friend's router version on the sticker on the bottom of the router.
PSN ID: dogdoctor
post #28 of 724 Old 11-26-2006, 10:16 AM
jeffs2's Avatar
Is anyone having a problem with filtering mac addresses? I'm running a netscreen 5GT wireless and things worked just fine out of the box.
Then I upgraded the PS3 OS, and I couldn't get on-line at all. By chance I happened to try turning off the mac address filtering and that fixed the problem. The netscreen is only seeing 1 address from the Ps3, but adding it to the permit list just doesn't seem to work.
I'm not all that knowledgeable about wireless, but is it possible that the PS3 is using a different mac address for part of the wireless handshake?
jeffs2 is offline
post #29 of 724 Old 11-26-2006, 10:23 AM
blklacker's Avatar
Try taking of the fire wall and open up your router then try it again. maybe your wep keys need to get regenerated.
blklacker is offline
post #30 of 724 Old 11-26-2006, 10:55 AM
Dralt's Avatar
Originally Posted by dogdoctor View Post
I would like to see if with the 60Gb or wireless adapted 20Gb PS3 if there is an apparent (b) router communication problem even though Sony says they support (b)/(g) routers. If you prefer to use hardwired ethernet that is your preference, but if you could help other AVS members out that would be awesome. If you have a wireless router, see if you can maintain a connection. The problem that some of us are experiencing is repeated connects/disconnects with about 15-30 second intervals.
If you want to post on diagnostic/help for wireless users please post here.
Thanks in advance.
Please note you can vote for more than one if you have tried different routers.
As of 11/22/06
Routers that WorK:
Netgear WGT624 v3 802.11b/g 2.4GHz
D-Link DGL4300 802.11b/g 2.4GHz
Linksys wireless-G 2.4 with speedbooster (from ps3forums)
Actiontec MI424WR
Linksys WRT54G v6.0**(not the X4 Version) - works fine for me with wep (as of 11/24/06)
*with a router reset and without wep - changed categories.
**if not working check the version number.
Linksys WRT54GX4
Check my post in the set-up issues thread...the PS3 Wi-Fi radio suffers from a terrible SNR...
In fact, in my case, it is so bad that I can't use it...I had to hook it up to my client bridge.
People should also be aware that with proper wireless access, the PlayStation Store is not so slow. I was able to download the F1 demo in less than 20 minutes.
Dralt is offline
Reply PlayStation Area
