PS3 20GB and Wireless Connections - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 10-01-2008, 06:21 PM
steven975's Avatar
that's right. Or unless your WiFi chip broke after the warranty expired.
steven975 is offline
post #62 of 66 Old 10-02-2008, 04:50 AM
bryansj's Avatar
Quoted: 241 Post(s)
Liked: 256
I had my PS3 40GB connected to a wireless bridge instead of using the built in wireless. I did this since I had my Xbox360, HD DVD player, and DirecTV HD-DVR already connected to the bridge.
I now have the home theater as the main hub so that wireless bridge is now the main router and my network printer is connected to the bridge (I deactivated my desktop pc and moved to a laptop).
bryansj is online now
post #63 of 66 Old 10-02-2008, 09:06 AM
chad473's Avatar
Originally Posted by mondo3 View Post
so theres no reason to have a bridge unless you own the 20g model?
some of us have found that a bridge or gaming adapter gives much better speeds than the internal wireless. not really sure why, but download speeds are drastically different.
xbox live/PSN: Chad473
chad473 is offline
post #64 of 66 Old 10-02-2008, 10:11 AM
steven975's Avatar
that may very well be. The PS3's wifi has a pretty bad antenna...and I'm not sure how they connect it to the motherboard...I'm sure it's probably an internal USB thing. The only other internal connection options are PCI or PCI Express, and the PS3 has neither.
post #65 of 66 Old 10-02-2008, 12:16 PM
Durbo20vT's Avatar
hmm i dont see how this would work since the ps3 doesnt have the drivers, but if you set it up on a PC first, like the gaming bridges (as it states) then this might be possible.
here is a pic of the ps3 wifi/bluetooth antenna
The Ride
Ps3 500gb & Ps3 250gb
Xbox 360 Elite
Durbo20vT is offline
post #66 of 66 Old 10-02-2008, 03:32 PM
steven975's Avatar
the product in the link above merely becomes an access point when you plug it into a PC.
The PS3's internal wifi connects to the product above and uses the PC's internet connection. Basically, it's for people without a wireless router (which is WHO?).
Reply PlayStation Area
