HELP!! External Hard Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 63 Old 12-11-2006, 08:37 AM - Thread Starter
coneyparleg's Avatar
My external hard drive / usb mass storage device is coming up on the PS3 as unknown USB device
works fine on any computer I check
What am I doing wrong that my PS3 won't recognize the external hard drive?
coneyparleg is offline
post #2 of 63 Old 12-11-2006, 08:41 AM
dallow's Avatar
What file format is the drive in?
dallow is offline
post #3 of 63 Old 12-11-2006, 08:48 AM - Thread Starter
Not sure. I'm at work so I'll have to check when I get home.
What format should it be in? (some one gave it to me already set up so I'll need to check)
post #4 of 63 Old 12-11-2006, 08:53 AM
meancode's Avatar
Does it need to be in FAT32?
360 - Meancode
PS3 - Meancode
Wii - 1099 5090 9118 8604
meancode is offline
post #5 of 63 Old 12-11-2006, 09:14 AM
dallow's Avatar
Yeah, has to be FAT32.
dallow is offline
post #6 of 63 Old 12-11-2006, 09:43 AM - Thread Starter
If not already in FAT32 will I need to reformatt and lose all my saved content?
post #7 of 63 Old 12-11-2006, 09:44 AM
WriteSimple's Avatar
You have to reformat. But before you reformat, save your content on another drive, then transfer. Should work with files less than 4GB. It's FAT32 after all.
fuad
"DonÂt let them tell you who you are is not enough, that itÂs wrong and that you wonÂt find love. DonÂt let them use my life to put your future down, or tell you that happiness canÂt be found."
WriteSimple is offline
post #8 of 63 Old 12-11-2006, 09:55 AM - Thread Starter
fuad
Thanks thats what I thought.
I hope that this is the fix (FAT32)
post #9 of 63 Old 12-11-2006, 08:06 PM
danieljw's Avatar
For some reason, the PS3 won't recognize my USB-powered 2.5" external. Doesn't even come up as "unknown device" so I don't even think reformatting to FAT32 will help.
Any ideas?
danieljw is offline
post #10 of 63 Old 12-11-2006, 09:06 PM
TwinTurboJosh's Avatar
Any ideas?
The USB ports on the PS3 probably don't provide enough power for the HDD.
TwinTurboJosh is offline
post #11 of 63 Old 12-11-2006, 09:48 PM - Thread Starter
This did not work. I reformated my 200 gig Maxtor external drive to FAT32, put my media back onto it, confirmed that it works for my pcs, but stll unknown usb device, waaaaaaaa
heeellllllpppp!!!!
please
post #12 of 63 Old 12-11-2006, 09:52 PM
asong26's Avatar
Default WinXP doesn't have Fat32 format option. You need to use either 3.rd party software such as Partition Magic, or fdisk. Be absolutely sure that it is Fat32. You can do this by following the steps:
1. Connect the drive to our PC
2. Using windows explorer, locate the disk.
3. Right click on the mounted drive and select 'Properties'
You should see immediately if the file system is indeed Fat32, or NTFS. I had a similar issue today with my portable USB drive. PS3 didn't even recognize it. But once reformatted to Fat32, PS3 picked it right up!
asong26 is offline
post #13 of 63 Old 12-12-2006, 04:28 AM
rcavictor1956's Avatar
If I remember reading correctly, the Western Digital My Book external drives are fat32. I believe I read somewhere here it is pretty much plug in and use without any formatting necessary.
"You know Andy....I never thought our town would come to this....Mayberry....Gateway to danger.
Barney Fife
rcavictor1956 is offline
post #14 of 63 Old 12-12-2006, 05:11 AM - Thread Starter
Positive that it is FAT32, I used MaxBlaster. One partition of about 180 gigs in FAT32.
Do I need to F around with the partitions?
post #15 of 63 Old 12-12-2006, 05:53 AM
AmigaDude's Avatar
If you have time, try it with a partition smaller than 128GB and see if that works.
AmigaDude
AmigaDude is offline
post #16 of 63 Old 12-12-2006, 06:20 AM
dark1x's Avatar
Quoted: 13 Post(s)
I don't think partition size would make a difference. My PS3 picks up a Maxtor 300gb without a problem (single partition).
dark1x is offline
post #17 of 63 Old 12-12-2006, 07:19 AM
asong26's Avatar
As 'TwinTurboJosh' mentioned, it' may be a power issue. If not, may be there are drives that PS3 isn't recognizing. This is really odd.
asong26 is offline
post #18 of 63 Old 12-12-2006, 08:04 AM - Thread Starter
indeed odd, my ps3 will recognize flash drives in the usb and other usb devices, and anything I stick into the smart card readers, the usb mass storage is recognized on everything else I've tried
is it worth it to even call Sony support and find out or will they give me some scripted bs?
post #19 of 63 Old 12-12-2006, 08:45 AM - Thread Starter
I formated the drive thru windows using maxblast 4
should I try formating thru dos?
post #20 of 63 Old 12-12-2006, 08:54 AM
asong26's Avatar
That's a good idea. You will definitely loose storage space capacity doing it this way (initially). I believe Fdisk on Win98 / WinMe will not format the drive up to the theoretical max of 2 Terabytes. It will significantly lower than your drive's full capacity. I've heard that it may max out at 32Gig. I am not sure. But this would be a good starting point. Once you get it working on the PS3, you can always reclaim the lost space using partition magic, or something else out there.... I am not sure about the capabilities of MaxBlaster, since I've never used it.
I have a Western Digital 80 gig drive that I bought couple of years back. Initially, I had it on NTFS, but used partition magic to reformat the drive th Fat32. Voilla! Everything worked.
Good luck! I hope you get it working soon.
asong26 is offline
post #21 of 63 Old 12-13-2006, 08:22 AM - Thread Starter
Still no luck for me
I saw on a differnt forum someone with a similar problem
200 gig external hard drive
FAT32 file format works on all pcs I try
"unknown USB device" on ps3
I'm going to try a friends ps3 when I get a chance, but I'm not sure where the problem lies
is there any good freeware that somone can suggest for formating a hard drive, I have maxblast which came witht hte hard drive
post #22 of 63 Old 12-19-2006, 10:48 AM - Thread Starter
I am still suffering has anyone else had this problem
post #23 of 63 Old 12-21-2006, 08:36 AM
jmik26's Avatar
I was going nuts last night trying to get my external 320gb seagate hard drive converted from NTFS to FAT32. I tried partition magic 6 (errors and locked up), partition magic 7 (errors and locked up), XP Disk management (Only NTFS available), XP installation Disc and DOS with every attempt failed.
I know when I re-installed windows XP before it gave me the option to select FAT32 but now its gone. I also looked on windows XP site and they explain it, I follow it exactly, and FAT32 is not an option, only NTFS, WTF. Is this another Company war!
Did a little more digging at work today and stumbled across this program Swissknife. It worked fine on my 80gig I have at work, hopefully it will be that easy when I get home and try it on the 320gb.
When all is said and done I want to have my external 320gb Seagate hard drive as my bridge between PS3 and HTPC. I have my HTPC hooked up through external SATA connector and use the USB to connect to PS3. This way I can share music, DVD's and TV recordings between the two. Hopefully this works out as planned, I'll keep you guys posted.....
jmik26 is offline
post #24 of 63 Old 12-21-2006, 06:22 PM
jmik26's Avatar
Coneyparleg - the program on the link I gave worked perfect. I now have a 320gb external hard drive hooked up to my PS3, sweet!!!
jmik26 is offline
post #25 of 63 Old 12-21-2006, 07:31 PM
yellajacket20's Avatar
I used Swissknife to format the 80gb hard drive I had in my PS2. Have it in an enclosure and it works perfectly.
yellajacket20 is offline
post #26 of 63 Old 12-22-2006, 08:35 AM - Thread Starter
I tried it and still no luck, it formated my hard drive fine and I can view the files on any pc I've tried and they all say the hard drive is in FAT32. I don't get it, other usb devices like flash drives and headsets work fine.
I have yet to try another hard drive on my ps3 or my hard drive on another ps3 to isolate the issue but its wierd man
post #27 of 63 Old 12-22-2006, 12:07 PM
gamoon's Avatar
Anyone looking for a drive that matches the black shiny finish of the PS3 should look at the Western Digital 120g Passport II unit. I just bought it to transfer photos, music, and videos from my PC to the PS3 and was surprised that unit looks like it was made for the PS3 and it has cool blue LED that matches the PS3 also. And it works fine out the box no reformat or anything just create the PS3 folders on the drive and plug it into the PS3. Cost was 99.00 dollars at BB.
gamoon is offline
post #28 of 63 Old 12-22-2006, 01:40 PM
DR0NE's Avatar
coneyparleg - are you using an external enclosure with its own power supply? I was able to use a 500 GB drive formatted as fat32 through swissknife. Sounds like you have a power issue and not a format issue.
DR0NE is offline
post #29 of 63 Old 12-22-2006, 02:01 PM - Thread Starter
Enclosure purchased from coumpusa - it has its own power supply (I plug it in to a power outlet) and a 200 gig 3.5" maxtor hard drive which I put into this enclosure.
post #30 of 63 Old 12-24-2006, 10:26 AM
sheempa's Avatar
i have an external maxtor hd(fat32) on my ps3, but all my mp3 files that i have on the hard drive wont show up. i see the drive but no files
please help
sheempa is offline
Reply PlayStation Area
