Can you charge a PS3 controller with your PC's usb ports? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 68 Old 02-08-2012, 11:57 AM
lowarkhog's Avatar
lowarkhog is offline
post #62 of 68 Old 03-22-2012, 02:48 PM
Mr Fusion's Avatar
As others may have posted, I have researched on other forums that the PS3 controller lights may not have to be flashing in order to know that it's charging up properly.
I have a couple of Motorola cell phone chargers I want to test this theory with. Though, I'm afraid that if one of them does work with no lights flashing on and off, will it overcharge the internal battery and cause damage (like exploding)? Being that the controller isn't communicating with anything like the PS3 or a laptop which enables the flashing lights.
Thoughts anyone?
Mr Fusion is offline
post #63 of 68 Old 03-22-2012, 03:40 PM
Quoted: 175 Post(s)
Liked: 193
I have three controllers that I've bought over the last few years, all of them flash until their done charging. When they are full they stop charging automatically and the lights go out, so you know it's done. Not only does automatic charge cutoff save the battery, it allows you to use the controller plugged in for as long as you like without harm.
If you're gonna charge a PS3 controller with a charger that is not using the USB power standard, then you might make a problem for your controller.
Crash44 is offline
post #64 of 68 Old 04-21-2013, 03:32 AM
Blarrg's Avatar
I couldn't get mine to charge via a ipad charger or a usb slot on a powerboard. But pc worked fine.
Also, this thread has been running for 7 years. Cool
Blarrg is offline
post #65 of 68 Old 04-21-2013, 08:05 AM
ThumperII's Avatar
Liked: 183
Not really running, just brutally resurrected every once in a while.
ThumperII is offline
post #66 of 68 Old 04-21-2013, 10:29 AM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
I bought one of these.
http://www.amazon.com/gp/product/B001KYV9AK/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
And it comes with another charging cable so you can charge two things at once. With the additional length of its power cord, you can easily use a DS3 while it's charging.
Witchboard likes this.
500 gigs FTL.
blklightning is offline
post #67 of 68 Old 11-29-2016, 10:55 AM
Witchboard's Avatar
Quoted: 108 Post(s)
Liked: 63
My computer charges mine fine. I also use my printers USB port to charge controllers. I have one of those wall outlets with USB ports and, unfortunately, it doesn't.
Witchboard is offline
post #68 of 68 Old 11-29-2016, 04:05 PM
Jond0's Avatar
Quoted: 146 Post(s)
Liked: 66
Why can't they just include this with a $400 system? But I digress -- thanks for this, it is exactly what I have been looking for without having to buy a charging dock station thing....
Jond0 is online now
Reply PlayStation Area
Playstation 3 160gb System
