A/V receiver for ps3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-02-2007, 01:47 AM - Thread Starter
delusive1's Avatar
Can anyone recommend a receiver that will utilize ps3's full potential. If not how long do I have to wait till such a thing exist?
thanks
delusive1 is offline
post #2 of 18 Old 01-02-2007, 02:28 AM
BBS G35's Avatar
Quoted: 35 Post(s)
Liked: 43
A Receiver capable of 1080p and 7.1 LPCM Audio through HDMI pretty much? Onkyo TXSR804, Denon AVR 2807 or the 3807 for more.
BBS G35 is offline
post #3 of 18 Old 01-02-2007, 08:04 AM
metalsaber's Avatar
Quoted: 963 Post(s)
Liked: 774
Higher end Pioneer Elites will work.
metalsaber is online now
post #4 of 18 Old 01-02-2007, 01:13 PM
Earz's Avatar
thanks
I would go for the Panasonic sa-xr 700 which has no -10 sub problems, passes 1080p and 7.1 PCM via hdmi or hdmi/dvi.
Look at Vanns for a good price.
Earz is offline
post #5 of 18 Old 01-02-2007, 01:21 PM
Ragnarok's Avatar
thanks
I would wait for an HDMI 1.3 capable receiver.
Friends don't let friends game in SD.
Ragnarok is offline
post #6 of 18 Old 01-02-2007, 01:30 PM
walk's Avatar
Indeed, I would wait for 1.3 and Dolby TrueHD and DTS-HD MA decoders built in.
Use optical for now (bitstream 5.1 DD/DTS)
walk is offline
post #7 of 18 Old 01-02-2007, 02:04 PM
Earz's Avatar
From my understanding receivers like the Panasonic with 1.2a will already playback DTS-MA and DD-HD via HDMI and output them as PCM....and only future advanced colors will matter for 1.3....in which case you need a 1.3 source, display, receiver and future software to really have a need for 1.3.
Earz is offline
post #8 of 18 Old 01-02-2007, 03:53 PM
td911's Avatar
How about the Yamaha HTR-6090, which I'm looking at very seriously?
td911 is offline
post #9 of 18 Old 01-02-2007, 03:53 PM
Ragnarok's Avatar
I believe HDMI 1.3 is the first spec with the bandwidth needed for DTS and DD lossless encoding.
Ragnarok is offline
post #10 of 18 Old 01-02-2007, 08:19 PM
Earz's Avatar
If its output from the player....the current (a few) receivers will already output up to 7.1 channels of DD-HD or DTS-MA as PCM.
Its all PCM in the end anyway....right?
Read this http://www.avsforum.com/avs-vb/showthread.php?t=738511
Earz is offline
post #11 of 18 Old 01-02-2007, 08:26 PM
Stupac's Avatar
They can't do 7.1 LPCM through HDMI. Have to use analog for that just like the new Sony's
Stupac is offline
post #12 of 18 Old 01-02-2007, 08:32 PM
Earz's Avatar
The Panasonic sa-xr 700 does do 7.1 pcm via HDMI and 1080p over both straight hdmi connections and from hdmi/dvi connections.
It will do this with either the Panny player after it gets its DTS-MA upgrade...or the PS3 after its DTS-MA upgrade.
And I am sure there are at least a couple more out that can also.
No need for hdmi 1.3 in this scenario.
Earz is offline
post #13 of 18 Old 01-02-2007, 08:46 PM
maveric23's Avatar
Quoted: 12 Post(s)
I'm waiting for the new HDMI 1.3 Denons slated to be released this summer.
Grouchy Golf
maveric23 is offline
post #14 of 18 Old 01-09-2007, 12:57 PM - Thread Starter
delusive1's Avatar
I guess I'll wait for HDMI 1.3 Optical will do for the time being.
post #15 of 18 Old 01-09-2007, 01:15 PM
metalsaber's Avatar
Quoted: 963 Post(s)
Liked: 774
Get a Pioneer Elite 82 or 84 to get 7.1 channel LPCM via HDMI.
post #16 of 18 Old 01-12-2007, 07:01 PM
hogholley's Avatar
Need some help. I just got the PS3, and I have the video straight (HDMI to DVI) because Westinghouse apprently didn't have the memo that HDMI inputs were going to be pretty crucial when I bought my TV a year and a half ago. ANYWAY, I tried running an optical audio from PS3 to my receiver (BOSE 3-2-1) and and changed the audio output setting on the PS3 to optical audio, but I get no sound at all. Checked to make sure I was on the correct input and I was, so I don't get it. Right now I have the AV (composite) cables that came with the PS3 running the audio. Sounds okay, but it doesn't make sense to me why the optical wouldn't work with the exact same setup. Anyone know what I'm missing? Thanks.
hogholley is offline
post #17 of 18 Old 01-12-2007, 09:14 PM
metalsaber's Avatar
Quoted: 963 Post(s)
Liked: 774
Make sure under the BD/DVD settings that audio via optical is set to Bitstream.
Make sure when you choose Optical in the audio section, that you go to manual and check all signals your receiver can handle.
post #18 of 18 Old 01-12-2007, 11:29 PM
hogholley's Avatar
BD/DVD is set to Bitstream, when I go to audio settings I select Dolby and DTS, but it won't let me uncheck Linear; is that interfering with something. Either way, still nothing.
Reply PlayStation Area
