What video formats will stream to PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 05-24-2007, 04:11 PM - Thread Starter
protoboard's Avatar
What formats of Video will the PS3 stream? .avi? .mp4? anyone know?
protoboard is offline
post #2 of 27 Old 05-24-2007, 04:17 PM
jkcheng122's Avatar
Quoted: 83 Post(s)
Liked: 92
supposedly nothing divx related are supported, mp4 definitely should work as it is the format for all the trailers we can download.
jkcheng122 is offline
post #3 of 27 Old 05-24-2007, 04:19 PM
NewOrlnsDukie's Avatar
Liked: 29
it's the same formats that were described w/ the original specs
1) mpeg-4 (though it needs to be properly packaged, as those of us that have been transferring QT HD movie trailers are acutely aware)
2) mpeg-2
3) mpeg-1
There are ps3 video transcoders available for PC users, and those of us w/ Visualhub for mac can do the labor-intensive transcoding as well (albeit the process is rather time-consuming).
Edited to add -- there are hints from the PS site that, at some time, more codecs and formats will be compatible eventually. But that hasn't happened as of yet.
NewOrlnsDukie is offline
post #4 of 27 Old 05-24-2007, 04:56 PM - Thread Starter
protoboard's Avatar
Everyone is saying to use WMP11 for streaming to the PS3. However, when I added all the files ot my library, WMP11 failed to pick up the .mp4 files I have.
Does anyone know how to fix this?
post #5 of 27 Old 05-24-2007, 05:06 PM
user friendly's Avatar
Happened to me too. Im still not 100% on which codecs are good to go but my video files from my Sony digicam are working flawlessly.
user friendly is offline
post #6 of 27 Old 05-24-2007, 05:54 PM
awx
awx's Avatar
The Zune software (which I won't install) is supposed to be a tweaked version of WMP11 that adds support for native mp4 to Windows.
PSN: YstadYakuza
awx is offline
post #7 of 27 Old 05-25-2007, 07:04 AM
jkoch6599's Avatar
Anyone???
jkoch6599 is offline
post #8 of 27 Old 05-25-2007, 07:28 AM
Jules343's Avatar
all of the supported formats of course
The following types of files can be played under (Video).
Memory Stick Video Format
- MPEG-4 SP (AAC LC)
- H.264/MPEG-4 AVC Main Profile (AAC LC)
MPEG-1 (MPEG Audio Layer 2)
MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
MPEG-2 TS (MPEG2 Audio Layer 2)
AVI
- Motion JPEG (Linear PCM)
- Motion JPEG (μ-Law)
AVCHD (.m2ts)
and if you use an application like Nero MediaHome or TVersity they will transcode your media on the fly so the PS3 can playback those formats not supported.
PSN ID: Ass
Jules343 is offline
post #9 of 27 Old 05-25-2007, 10:06 AM
Ryguy's Avatar
i'm also getting the problem of MP4 files not showing up. i'm running XP Pro with WMP11 installed. the ps3 recognizes mpg, wmv, and my xvid avi's (the wmv and xvids dont play though).
i'm wondering if it's because WMP11 doesn't natively support MP4. if you go to the file types section, MP4 isn't listed anywhere. also if you right-click/properties on an mpeg, the media type says "Video". for MP4 the media type says "Other".
Ryguy is offline
post #10 of 27 Old 05-25-2007, 10:09 AM
MaliciousBraham's Avatar
engaget posted a link to a hack to allow mp4 in wmp11 in their walkthough yesterday... I'll see if i can find it.
edit: they reference a registry hack, but dont link it or say what it is... engadget link
edit2: FOUND IT here is the link @ doom9
warning! dont goof around in the registry unless you know what you are doing!
MaliciousBraham is offline
post #11 of 27 Old 05-25-2007, 10:10 AM
UMD_Terp's Avatar
Is there any way to get 5.1 audio on movies to stream? I can get some .VOBs streamed over using Nero MediaHome, but audio seems to always be 2-channel PCM.
UMD_Terp is offline
post #12 of 27 Old 05-25-2007, 11:06 AM
jkoch6599's Avatar
I can't get to the doom9 article at work. Would you mind either posting it here, or PMing it to me?
post #13 of 27 Old 05-25-2007, 11:16 AM
Its actually a forum thread... 3 consecutive posts below...
Originally Posted by that link! View Post
unskinnyboy
OK, try this - in the Registry navigate to HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player \\Extensions\\Descriptions
and add a new String Value with the value set to the next incremental number (say 9 is the highest number there currently, your new one would be 10) and set the Data as 'MP4 Files (*.mp4)'.
Now go to HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player \\Extensions\\MUIDescriptions, and create a new String Value with Data 'MP4 Files'.
Lastly go to HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player \\Extensions\\Types and create a new String Value with Data '*.mp4'.
Now try the Open dialog box of WMPlayer. Note that the above paths are for WMP 9 series (which I have). If your version is any different, just poke around and find the appropriate paths yourself.
Originally Posted by that link!!! View Post
Cool thanks. That managed to make the MP4s appear in the drop-down menu.
While I was tinkering around with the registry I discovered how to make explorer recognise them as video too:
So if anyone else is interested:
1. do what unskinnyboy says to do.
2. Then you need to navigate to HKEY_CLASSES_ROOT\\.mp4.
3.a) Change the (Default) String Value data to mp4file
b) Make a new String Value and name it Content Type.
c) Modify the data to video/mp4
d) Check that the PerceivedType String Value is video
You might wanna check this out:
http://aflux.deltaanime.net/Zero1/MP...install108.reg
(save target as, and double click to add to registry)
I wrote it some time ago for myself, but made it available because I found that some people liked what it did.
What it does is:
a) Associates MP4 files to WMP
b) Adds explorer context menus (Add to WMP list/now playing)
c) Gives MP4 files the icon used by WMP for MPG files.
d) Adds a file filter to WMP in the open file dialog.
And this is what it looks like
pic link at imageshack
Basically MP4 files will act just like AVI files do (or as near as dammit)
I did write some useful info on my forum, which I had to take offline due to spam recently. If you need any more information I'll see what I can do.
hope this helps... sorry for my poor ripping skillz heh.
post #14 of 27 Old 05-25-2007, 11:17 AM
jkoch6599's Avatar
Thanks a lot MB!
post #15 of 27 Old 05-26-2007, 06:19 AM
ulysses191's Avatar
Quoted: 13 Post(s)
Hey everyone, i've just been following along. i've had the same troubles as all of you streaming mp4 to my ps3 using WMP11. Has anyone tried the above mentioned registry hack?
i just did it and yes the icons changed and the wmp11 accepts it, but it won't add to the actual library.
thus, the PS3 still doesn't find these files..
this just me, or is anyone else having the same problem.
Uly
ulysses191 is offline
post #16 of 27 Old 05-26-2007, 12:38 PM
jkoch6599's Avatar
Uly
I'm still having the same problems too.
I think I'm just going to start converting stuff to mpeg-2 instead. It's faster anyway.
post #17 of 27 Old 05-26-2007, 05:14 PM
ulysses191's Avatar
Quoted: 13 Post(s)
great minds think alike my friend...
started doing the same thing. just checking forums again 2 see if someone found a quick answer.
post #18 of 27 Old 05-26-2007, 05:29 PM
Megalith's Avatar
Quoted: 20 Post(s)
WMP is a pain in the ass.
Just go ahead and use Windows Media Connect instead. You'll have to uninstall WMP11 first, though.
Megalith is offline
post #19 of 27 Old 11-21-2009, 11:28 PM
broadwayblue's Avatar
I see this thread is rather old...but I was wondering if there is now an easier way to stream MP4 files to a PS3?
broadwayblue is offline
post #20 of 27 Old 11-22-2009, 08:22 AM
chad473's Avatar
Quoted: 113 Post(s)
Liked: 121
ps3mediaserver is what you want for all things streaming.
Vizio P50-C1 - My Calibration Settings
Xbox One S 2TB
PS4 Pro 2TB
chad473 is offline
post #21 of 27 Old 11-22-2009, 09:37 AM
steven975's Avatar
Windows 7 streams all of my MP4 files (H.264 baseline) to my PS3 natively.
steven975 is offline
post #22 of 27 Old 11-22-2009, 11:17 AM
PvtChurch's Avatar
This. This. THIS!
Anyone dicking around with WMP (gag), TVersity, or PlayOn needs to stop now. I've screwed with all of them and no matter how much BS I tweak, what codec packs I install, and what animals I sacrifice to the fire orb none of them work right 100% of the time. Then I found PS3 Media Server. You install it, open up a port on your router, tell it where your media is stored, and start the program. And then it just works. I have yet to have a problem streaming any format the PS3 will recognize. Better yet I have yet to find a codec PMS (giggle) will not transcode, and this is without having to hunt down and install any codec packs.
It's a god send, it's free, it works on Macs and PCs.
Always remember: The pessimist is never disappointed.
PvtChurch is offline
post #23 of 27 Old 11-22-2009, 11:34 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Originally Posted by PvtChurch View Post
This. This. THIS!
i agree!
zoro is offline
post #24 of 27 Old 11-23-2009, 08:34 AM
azula's Avatar
Quoted: 20 Post(s)
does ps3 media server stream netflix?
azula is offline
post #25 of 27 Old 11-23-2009, 08:40 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 107
Are you being ha-ha here?
If not,
http://www.avsforum.com/avs-vb/showthread.php?t=1191120
-Suntan
Suntan is offline
post #26 of 27 Old 10-31-2013, 03:03 AM
Steffeclove's Avatar
PS3 supports MPEG-4 AVC codec or MPEG-2 video.
So sometimes we still run in to difficulties to transfer MP4 files to PS3 and play MP4 on PS3.
To successful play MP4 files that PS3 failed to see/recognize, transfer, playback or not normally playback, a better solution is to convert MP4 to PS3 supported MPEG-4 AVC codec or MPEG-2 video
Recommend a YouTube video guide about how to convert mp4 to PS3 supported format.
Steffeclove is offline
post #27 of 27 Old 11-24-2013, 01:27 AM
jethrouk's Avatar
Delete the folder location from the video library - give it a few seconds until the video window empties - then add it back - this will cause WMP to re catalogue 'all' the videos in that folder
jethrouk is offline
Reply PlayStation Area
