HELP !!!!!!! Reset Ps3 Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-25-2007, 12:43 PM - Thread Starter
ajamils's Avatar
What happened was that I was playing around with its display settings and I selected 1080p even though my LCD can only accept signal upto 1080i and now the TV keeps showing "In Valid Format". I tried connected it through component but I still don't get anything on screen.
Is there a way to reset Ps3 settings without seeing the menu on screen ? Or any other way to fix this problem.
[color=Blue]
psn id: hunter4life
Live Gamertag: huntre4life (notice "re" not "er" in hunter)
ajamils is offline
post #2 of 9 Old 05-25-2007, 12:48 PM
ndskyz's Avatar
With the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this cause the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
ndskyz is offline
post #3 of 9 Old 05-25-2007, 01:47 PM - Thread Starter
ajamils's Avatar
Thanks alot mate...that fixed the problem
[color=Blue]
psn id: hunter4life
ajamils is offline
post #4 of 9 Old 12-30-2008, 03:39 PM
rottenmonkey's Avatar
the problem with my ps3 is a little bit different. it decided to power down on its own, and will not fully power back up. it will for 2 seconds then shuts itself back down. have tried the 5 second reset sequence, to no avail. Seems to me it might be a hardware not a sofware issue. could anyone offer any opinion?
thank you very much,
Best regards... Rotten Monkey
rottenmonkey is offline
post #5 of 9 Old 02-25-2009, 12:06 PM
ihavepenonmyface's Avatar
i read all these comments on holding the on/off button for 5 secs to reset settings and i was worryed incase it resets my saved files
sooo.... does it? plzz help
ihavepenonmyface is offline
post #6 of 9 Old 02-25-2009, 12:24 PM - Thread Starter
ajamils's Avatar
it only resets your video output settings.
[color=Blue]
psn id: hunter4life
ajamils is offline
post #7 of 9 Old 02-25-2009, 03:02 PM
thnx dude add me on ps3 mi username is ihavepenonmyface
post #8 of 9 Old 02-26-2009, 09:05 AM
Vince2909's Avatar
your name reads like you have penis on your face. Srsl'y.
PSN: VinnAY-DBC
Vince2909 is offline
post #9 of 9 Old 01-15-2010, 12:43 AM
mk9065's Avatar
HI is it the 60G. if so then it is a hardware problem i had the same fault phoned sony and they swapped it for recon. Hope this helps ( it was aslo out off warrent but may have just been lucky )
mk9065 is offline
Reply PlayStation Area
