Has anyone tried a wireless N adapter on a PS3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 05-29-2007, 03:53 PM - Thread Starter
Dgephri's Avatar
I have a Linksys PreN GB router.
I have a PS3 running off the G channel in my Theater room (about 40 feet away, 5 walls, low signal, etc.). Using a Linksys G signal booster.
Option 1- crawl around under my house for 5-6 hours, rig up a demarc board near my router, and run CAT6 back and forth.
Cost: Cat6 (not much for a couple hundred feet to feed other rooms at the same time
Me getting dirty under the house and really hating crawlspaces (attic access might be easier).
Option 2-has anybody tried an N-based USB adapter on a PS3 with/without WEP or WPA?
Cost: N-adapter ($100)
no dirt, no mess, little fuss.
Now I know wireless N is nowhere near GB wired. But the upscaled AVIs at 30-60Mbit looked really good on my 1080P screen, just stuttery on Wireless G.
Thoughts?
Dgephri is offline
post #2 of 32 Old 05-29-2007, 03:59 PM
Tripjammer's Avatar
USB 802.11n adapters do not work currently on the PS3, but 802.11 N routers and access points do. You will have to get a 802.11N router that can be configured as a accesspoint and plug that into the back of the PS3 using the gig Ethernet port and configure this router\\access point to talk to the other 802.11N router that your cable or dsl model is plugged into. This will get you the most wireless bandwidth.
Playstation Network Name: Aiphanes
Warhawk Clan: Knights of HalfBros
Resistance Clan: Knights of HalfBros
Folding@home Team 56396
Knights of Halfbros Team STATS
Tripjammer is offline
post #3 of 32 Old 05-29-2007, 04:45 PM - Thread Starter
Dgephri's Avatar
Ugh, another $150+ for the N AP?
Dgephri is offline
post #4 of 32 Old 05-29-2007, 05:56 PM
Emotep's Avatar
Dont bother until Wireless N becomes more stable...
You don't really need all that bandwidth anyways,
Emotep is offline
post #5 of 32 Old 05-29-2007, 06:24 PM - Thread Starter
Dgephri's Avatar
I am going to play with my Wireless G repeater and see if I get better streaming stability.
Cleary wiring CAT6 is the best solution, but also most work (attic, etc.).
Dgephri is offline
post #6 of 32 Old 01-26-2008, 05:04 PM
8IronBob's Avatar
Quoted: 61 Post(s)
Liked: 24
Well, I just picked up a D-Link 802.11n Router from BB today for $70 (being a Reward Zone member, I was able to get 10% off on it, so it was closer to $60). Anyway, I'm hoping that the PS3 can take full advantage of that router, tho. I'm about to upgrade from my Belkin 54G router to the D-Link N router, hoping that will improve things.
Living Room: Samsung UN46A750 46" ToC 1080p, Yamaha HTC-6160 AV Receiver, JBL Cinema 480 5.1 Speakers, Magnavox HDD/DVD Recorder, Scientific Atlanta Explorer 8300HD.
Master Bedroom: Sony KDL-55W950B 55" 1080p, Sony HT-XT1 Soundbar, Xbox One, Scientific Atlanta 8300HD
Basement: Toshiba 32TL515U 32" 1080p 3DTV, PlayStation 3, Xbox 360, Bose Companion II Series 2 2.1 Speakers, Panasonic DMR-EZ28 DVD Recorder
8IronBob is offline
post #7 of 32 Old 01-26-2008, 07:13 PM
steven975's Avatar
G is probably good for 25-30Mbps, N probably 100. That's throughput, not link speed.
USB is good for 200...except it doesn't work.
Are there any N gaming adapters (Wireless N with a Gigabit Ethernet port...no USB)? That may be the best wireless method...but wired is best.
steven975 is offline
post #8 of 32 Old 01-27-2008, 08:16 AM
Arabus's Avatar
Linksys makes one. It is the WGA600N. But it is not clear if the wired port is gigabit.
See http://www.linksys.com/servlet/Satel...=4757740536B01
Arabus is offline
post #9 of 32 Old 03-25-2008, 09:50 AM
edlex's Avatar
Quoted: 30 Post(s)
Liked: 33
I have a linksys wrt600n that I just got and a belkin n1 that it replaced. Could I connect the the belkin to the ps3's ethernet port and have the linksys connect to it at n speed?
If so how? I really would appreciate any help. I am curious to try it but afraid of frying the ps3.
edlex is offline
post #10 of 32 Old 03-25-2008, 09:59 AM
markc72's Avatar
Quoted: 34 Post(s)
Liked: 29
Unless they come out with a wireless N adapter for the PS3, getting a Wireless N access point is worthless unless you have a laptop that is capable of doing it. Currently the N product has not been officially approved by the FCC yet. Looks like end of this year or early next.
Come join our adult gaming community at www.syndicatedgaming.com
XBL, PSN, and Steam: diehardcubfn
markc72 is offline
post #11 of 32 Old 03-25-2008, 10:17 AM
edlex's Avatar
Quoted: 30 Post(s)
Liked: 33
Ok so would it be possible to connect the belkin router and increase the connection strength? On the g level if not n. I'm really desperate because the signal strength is so low now.
edlex is offline
post #12 of 32 Old 03-26-2008, 02:55 PM
markc72's Avatar
Quoted: 34 Post(s)
Liked: 29
Should work fine on G.
markc72 is offline
post #13 of 32 Old 03-26-2008, 04:46 PM
splinters's Avatar
The two chipsets you have is Broadcom for the Linksys and Atheros for the Belkin, mixing chipset vendors for WDS bridging (the technical name of what your asking for) is not well tested and typically doesn't work very well with links being dropped and lots of wireless troubleshooting work required.
That said, there are two ways to increase your speed/latency as I see it, and 11n is not a requirement in either one.
The first one is to get a 802.11a router or access point, and get a Wireless 11a adapter like this one. If you pair it with a gaming 11a router, you will get LIKELY (not guaranteed) get better performance since fewer people use the 11a's 5Ghz (vs. 2.4Ghz for 11b, 11g, 11n, bluetooth, and microwave ovens). This will net you 54-108Mbps of raw dataspeeds, which translates into 20-45Mbps of real data (wi-fi uses a lot of overhead to handle the wireless connections and error correction).
The second option is to use a powerline ethernet product like the Linksys PLK200. What that will net you is 100+ Mbps of raw throughput, and 60-80Mbps of real data. You will also get lower latency (read: lower ping times) for games and a better network for streaming audio/video from pcs to your ps3. And yes, you are sending data over your home's powerlines to transmit the data.
The 11a solution will cost you some money, but you may find bargains as 11a isn't as popular and you may find stuff on ebay and craigslist for cheap. The Powerline ethernet solution will run you ~150 for a set of new powerline ethernet adapters, but maybe cheaper since they have been out for a few months. There are some newer adapters from other manufacturers that say 200Mbps, but I think this is overkill since most routers have 100Mbps ethernet ports anyways.
In case anyone wants to point it out, yes your home internet connection is the bottleneck, at 500kbps to 6Mbps typically, but for those streaming video or gaming online, the extra bandwidth can offer lower ping times for that extra nano-second advantage.
-Splints
splinters is offline
post #14 of 32 Old 03-26-2008, 05:52 PM
NJ3118's Avatar
mackbook pro running alongside an airport extreme = blazing browsing and speed.
I have a fever and the only cure is more Blu-Ray....
NJ3118 is offline
post #15 of 32 Old 01-04-2009, 10:53 PM
com5984's Avatar
Has anyone tried this with the ps3
com5984 is offline
post #16 of 32 Old 01-04-2009, 11:25 PM
splinters's Avatar
It should work fine with another 11n wireless router, it uses ethernet to connect to the ps3' gigabit network card.
-Splints
post #17 of 32 Old 01-04-2009, 11:32 PM
com5984's Avatar
thanks for that, do you think this would be a faster connection http://www.pcmag.com/article2/0,2817,2333005,00.asp
com5984 is offline
post #18 of 32 Old 01-05-2009, 12:23 PM
Mr. Abulia's Avatar
Has anyone tried using one of the little Apple Aiport Wireless Access Points? Those are not too expensive, a very reasonable size, and you can connect an ethernet cable to them. I've been thinking about that as an upgraded wireless solution (running cable would be a huge hassle in my place).
Mr. Abulia is offline
post #19 of 32 Old 01-05-2009, 10:23 PM
bakerybum's Avatar
why not just use powerline?
bakerybum is offline
post #20 of 32 Old 01-06-2009, 03:36 AM
sli123's Avatar
My desktop died recently so decided to set the new one up next to the HT.
1.2TB HDD with all cd's ripped in WAV directly connected to the HT.
No more drop-outs, no more issues with TVersity not talking to the PS3 and vice versa.
Very friggin' happy!
"What are you waiting for, you're faster than this. Don't think you are, know you are"
sli123 is offline
post #21 of 32 Old 01-06-2009, 04:49 AM
john barlow's Avatar
I've been using a Belkin wireless N router for almost a year and not one dropout with it.
john barlow is offline
post #22 of 32 Old 01-06-2009, 03:20 PM
com5984's Avatar
I'm gonna get the netgear powerline, from all reviews I've read there pretty good.
Cheers
Rob
com5984 is offline
post #23 of 32 Old 05-21-2009, 10:52 AM
swb.311's Avatar
I use an Apple Airport Express ($99) to pick up wireless N, run an ethernet to my PS3 (or XBOX 360). The Express also has a minijack input so i have connected my receiver with surround sound to the Express allowing me to stream music from itunes to my surround while i play online on the PS3 on Wireless N.
Very easy, very badass.
swb.311 is offline
post #24 of 32 Old 05-22-2009, 12:24 PM
Gandu's Avatar
Quoted: 58 Post(s)
Liked: 82
Where my PS3 is located I couldn't get a good, consistent signal with an N router. I got the Netgear XAVB101 Powerline Ethernet networking kit ($115 amazon) and it works great, 5 min to install, get a solid 90+Mbps consistently.
Gandu is offline
post #25 of 32 Old 05-24-2009, 11:00 PM
BuckoNZ's Avatar
Quoted: 28 Post(s)
When in doubt and where you can, lay cable. It just works and you get decent speeds.
Television: LG SUPER UHD 4K TV 55'' [55UH850T] / Receiver: DENON AVR-X2300W / Blu-Ray Player: OPPO UDP-203
Main Speakers: KLIPSCH KG 2.5 / Centre Speaker: KLIPSCH KV 1
Surround Speakers (x4): CAMBRIDGE AUDIO Minx 22 / Sub-Woofer: ENERGY XL-S8
BuckoNZ is offline
post #26 of 32 Old 07-01-2009, 06:43 PM
d_logan's Avatar
If you have 2 N routers that you can put DD-WRT on, you can use one as an AP, and one as a client, and connect the client's ethernet port to the PS3's ethernet port.
But even with N, you won't beat a 100Mbps ethernet link as far as reliability, and constant speeds, IMO. Gigabit ethernet, and there's absolutely no comparison.
You have to keep in mind that wireless, especially with good encryption, has a lot of overhead.
d_logan is offline
post #27 of 32 Old 07-02-2009, 05:51 AM
coneyparleg's Avatar
i use this and it works great, doubled my speedtest.net results
coneyparleg is offline
post #28 of 32 Old 12-02-2009, 09:55 AM
chrisfromalbany's Avatar
Can PS3 Media player still see the PS3 if you are running through the Airport Express instead of the wireless card in the PS3?
chrisfromalbany is offline
post #29 of 32 Old 12-02-2009, 10:39 AM
DarrellG's Avatar
Quoted: 90 Post(s)
Liked: 118
Awesome, I just ordered that from Buy.com for $49.99. Should be here on Monday. I'm going to do some Speedtest.net tests also. My PS3 connection is usually only at 60% due to the location of the PS3 - Bottom shelf of my TV Stand and behind a wall. I plan on hanging this on my kitchen wall with a 10 foot CAT-5 cable so the wall isn't in the way.
My HD streaming is a little shaky, and Netflix stuff is always switching back and forth from HD to SD so it's really annoying.
Few questions:
1. does the unit have slots to mount onto a wall?
2. Are you running full N or mixed?
I have the Linksys WRT300N with DD-WRT installed running mixed. I plan on switching over to full N once I get this. I also ordered an ASUS WL-520gC to use as a secondary router for my stuff that needs G/B. The ASUS can also run DD-WRT.
DarrellG is offline
post #30 of 32 Old 12-30-2009, 01:11 PM
Can I use a Airport Express to PS3 and get the 802.11n instead of the 802.11g that comes from the PS3?
Reply PlayStation Area
