When setting up your PS3 Network, what does NAT Type 3 mean??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 06-08-2007, 06:41 AM - Thread Starter
Rieper's Avatar
Quoted: 154 Post(s)
Liked: 67
After setting up my PS3 for wireless use, I noticed a message saying: "Your PS3 is set for NAT Type 3, some communication features might not work properly".
What does that mean? Is this normal? Does it mean I wont be able to hear other gamers when playing Motorstorm using a bluetooth headset? How do I change NAT Type 3?
Any info would be appreciated. Thanks in advance.
Rieper is offline
post #2 of 20 Old 06-08-2007, 06:50 AM
joe_six_pack's Avatar
Nat 1 is a connection straight to internet
Nat 2 is a connection through a router.
Nat 3 means there is something wrong with your connection. YOu have limited connectivity.
There's a way to fix it, and it's on the official PS forum.
Sony pay me 10 beeeelion dollars to plant blu-ray seeeeds.
joe_six_pack is offline
post #3 of 20 Old 06-08-2007, 07:04 AM
Quoted: 46 Post(s)
Liked: 61
Try this web page
http://www.orpheusinternet.co.uk/support/ps3/index.html
It helped me with my wireless router.
Mike
wmwilker is offline
post #4 of 20 Old 06-08-2007, 02:32 PM - Thread Starter
Rieper's Avatar
Quoted: 154 Post(s)
Liked: 67
Thanks for the link and the info. Much appreciated.
Rieper is offline
post #5 of 20 Old 06-08-2007, 03:06 PM
IhateBestBuy's Avatar
Nat 3 is something you do not want to be lol
IhateBestBuy is offline
post #6 of 20 Old 03-31-2008, 06:44 PM
BlaQice's Avatar
First you need to determine two things?
1. Are you on cable or dsl?
2. If cable skip to NOW DO THIS below.
If DSL what is your ip?
if you STATIC IP is 192.x.x.x
you are "double nat"
That means your modem is acting as a router or switch, then your router
is behind that. YOUR DSL PROVIDER WILL NOT HELP YOU WITH THIS.
They make money off of selling you the $69/month service.
You need to access the MODEM setup of your DSL carrier.
Before you do this make sure you have your user name and password.
Now go to your Router Setup Page
Select PPPoE, enter your user name (complete email address) and password.
Don't save yet. Open another browser window and access your Modem and select PPP Bridged option then save.
Now save your router settings.
Now your ip should be 64.x.x.x or something like that. (on your status page)
You should be able to get NAT TYPE 2 on your PS3 now. If Not,
NOW DO THIS
set up a static ip address for your PS3 and assign it to the DMZ on your router. Don't bother with port forwarding and all that. If you're in a DMZ it's redundant. If you're not in a DMZ, set up one.
Now Save
BlaQice is offline
post #7 of 20 Old 03-31-2008, 07:06 PM
headcase151's Avatar
Call your internet provider.Ask them to help you put your modem in bridged mode.Basiclly that turns the firewall off,in the modem.Then you use the firewall in your router.I did this,and had open NAT on my PS3,and 360.
headcase151 is offline
post #8 of 20 Old 05-20-2008, 08:03 PM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
Modem in bridged mode. Don't want to put my PS3 in the DMZ because then it'll lose connectivity to TVersity. I suppose I could set up a MIP to the TVersity from the DMZ to the server, but really is it necessary? Also, I have/had everything working with the remote play with the PSP, and if I move my wired PS3 to the DMZ, it'll lose connectivity with the PS3. Someone, who's made this work on a flat network?
TornadoTJ is online now
post #9 of 20 Old 05-20-2008, 08:43 PM
TornadoTJ's Avatar
Liked: 510
The only way I can figure out how to do this is to do a mapped IP from the DSL interface to the PS3. Problem is, it won't tie to the PPPoE dynamic address if I do MIP.
post #10 of 20 Old 05-21-2008, 06:15 AM
M4H
M4H's Avatar
"DMZ" on most routers isn't really a DMZ. It just means that any ports not explicity forwarded go by default to the "DMZ" device. You can still hit it from the inside just fine. That said, try UPnP if your router allows it - the PS3 should map everything on its own.
If UPnP doesn't work, you'll have to do it manually. Quick Googling gets this:
http://boardsus.playstation.com/play...read.id=116102
M4H is offline
post #11 of 20 Old 05-21-2008, 08:55 AM
TornadoTJ's Avatar
Liked: 510
DMZ and UPnP aren't options on my device. I've tried all the options found from Google. I use a "commercial grade" firewall since it's what I support and use at work. It makes it easier for me to transition, and I feel better about the strength of the firewall compared to a "home" device. I realize this would be easier on something made for home and gaming, but I'm determined to not downgrade my device.
I finally gave up and emailed the firewall's support team. I'm wondering if it is the first time they've ever had someone ask how to set one of these up to allow multi-player on a Playstation. LOL!
post #12 of 20 Old 05-21-2008, 09:06 AM
M4H
M4H's Avatar
Manually mapping the missing TCP/UDP ports should work fine. Which ones have you forwarded?
M4H is offline
post #13 of 20 Old 05-21-2008, 11:58 AM
TornadoTJ's Avatar
Liked: 510
I have all the good ones forwarded. I think I may have found my issue. There's a command I have to issue to support multiple ports on a VIP on my firewall.
post #14 of 20 Old 03-21-2010, 11:26 AM
track15's Avatar
hey guys well as i see must of the people get the same problem in the ps3 network connection the nat type3 well i had before nat type3 but i changed it now to nat type 2and it was simple as 123 if you need help with your ps3 just contact me or post here your problem and i ll try to help
track15 is offline
post #15 of 20 Old 04-20-2010, 10:16 PM
habsman27's Avatar
HEY i desperately need help. I called my internet company telus to open the ports. They said that they opened the UPnP port and it should work. We checked everything, the ip address is the same etc. It still says NAT 3 and UPnP not available. Is it my internet or my ps3? HELP!!!!!!!
habsman27 is offline
post #16 of 20 Old 04-21-2010, 02:47 PM
DaBuzzard's Avatar
I see you are on Telus - you likely got the Siemens wireless gateway.
If so, the only way I could get my ps3 to nat 2 on Telus was to buy a stand alone broadband modem and use a seperate router.
Give the PS3 a static ip, drop it in the DMZ, voila! nat 2
There are no stupid questions. Stupid answers are a whole other story...........
DaBuzzard is offline
post #17 of 20 Old 04-21-2010, 09:40 PM
star_man's Avatar
Most likely you're device has the capability for doing this but there's not a button like for soho devices.
Which device are you using?
UPnP allows ports to be opened as needed. Not super secure. Apparently a lot of people don't care about security. Like EULAs, people will just click yes if it means they can play games.
star_man is offline
post #18 of 20 Old 04-22-2010, 06:39 AM
maximuslcd's Avatar
Quoted: 86 Post(s)
Liked: 77
when i run a connection test on ps3 it says nat type 3, but then when i play cod it says nat type open...even though it says i have nat 3 i have never had a problem and until I do i'm not messing with my setting and crap..DSL by the way
I work to live and live for the beach.
Amateur HT enthusiast.
Samsung 65KS8500/Onkyo 656 AVR, Dolby 5.1, Samsung UBD 8500 4K blu Ray player
Sharp Quatron 3D 60" Onkyo 705 Bonus room
Sharp Quatron 60" Bedroom
maximuslcd is offline
post #19 of 20 Old 05-08-2010, 02:51 PM
tj_kan's Avatar
My ps3 is stuck on NAT type 3.....I am unfortunately a hughesnet user with a linksys router. Hughesnet refuses to help me brdge my modem, I was hoping somebody could help. Let me know how or even if i can do it myself, from what i read my only other option is to get a static ip address which hughesnet wants to charge me for, so before I fork over any cash to em I'd like to make sure it's my last resort. Thanks in advance for the help!
tj_kan is offline
post #20 of 20 Old 05-08-2010, 04:52 PM
Im2sexy's Avatar
Read this I am assuming this is your modem too?
Im2sexy is offline
Reply PlayStation Area
