DVD Upscaling for PS3? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 08-04-2007, 08:29 PM - Thread Starter
doctorky1's Avatar
I am looking at the PS3 as a Bluray and DVD player as well as gaming system. The CNET review said it does not upscale standard DVDs, but it was written in November 2006. Has there been an update to the PS3 since then which enables it to upscale DVDs?
doctorky1 is offline
post #2 of 34 Old 08-04-2007, 08:31 PM
Mini123's Avatar
Yes. DVD's look quite attractive now.
"Although I am already in my pyjamas."
Mini123 is offline
post #3 of 34 Old 08-04-2007, 08:34 PM
Davio's Avatar
Agreed.....I bought this partially as an upscale DVD player and Im pretty happy with it. I think obviously some standalones do a slightly better job with the PQ, but considering it plays Blu-Ray as well you'll be happy with its performance.
Davio is offline
post #4 of 34 Old 08-04-2007, 08:36 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Actually, it ranks among the best standalone upscaling players around. You need to be using HDMI/DVI to upscale DVDs.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #5 of 34 Old 08-04-2007, 08:37 PM - Thread Starter
doctorky1's Avatar
Thanks. I wonder why CNET did not revise their review to reflect this and test the quality of upscaling DVDs as they do other Blu-ray players?
Also, is the PS3 get too hot to put in a component cabinet? Thanks.
post #6 of 34 Old 08-04-2007, 08:49 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
CNET doesn't revise many of their reviews.
As for heat, you'll probably want to keep it in an open space, at least someplace that's well ventilated.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #7 of 34 Old 08-04-2007, 08:49 PM
Mattardo's Avatar
Possibly. I have mine on top of my rack to be safe where the air-flow is free. It doesn't get as hot as my Wii console does, which makes no sense, but there you have it.
"The well-placed coin changes much - even itself." - Lao-Tse
Mattardo is offline
post #8 of 34 Old 08-04-2007, 10:32 PM
kylebisme's Avatar
Note that the PS3 does pause on layer change with dual layer disks, though other than that it does a respectable job with DVDs.
kylebisme is offline
post #9 of 34 Old 08-04-2007, 10:35 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
That's a loaded statement. As with each player it really depends on the disk. Certain disks have no pause at all. My player really doesn't have a noticable pause on most dual-layered disks.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #10 of 34 Old 08-04-2007, 10:37 PM
Swift Mojo Hand's Avatar
I have mine enclosed in a cabinet and have not has any problems with it freezing up at all.
As for the upscaling, it works for me. 1080 HDMI.
When in doubt use the spoiler tag "[$poiler] Spoiler text [/spoiler]"
Xbox: Swift Mojo Hand
PSN: SwiftM0j0Hand
Swift Mojo Hand is offline
post #11 of 34 Old 08-04-2007, 10:45 PM
md47's Avatar
you mean hdmi or hdmi>dvi, right..? the upscaling features work if you are connecting using just hdmi cables.
also, didnt i read that the upscaling can/will be improved in future firmware updates..?
finally, if you have a 1080p set, wouldnt you want to set the upscale to the "normal" setting..?
md47 is offline
post #12 of 34 Old 08-04-2007, 10:50 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Yes, I meant you need to be using either HDMI or DVI for upscaling. They will probably improve it, although it is pretty good right now. As for "normal" I think that's correct. Set it to upscale, and "normal" and yes, I think you're all set.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #13 of 34 Old 08-04-2007, 11:45 PM
kylebisme's Avatar
Eh? Not all DL disks switch layers mid film, but ones that do pause when doing so on the PS3.
post #14 of 34 Old 08-05-2007, 09:54 AM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
Says you. Not all of them do so. Some of them are better calibrated than others. Some get more jostled during shipping than others. Mine rarely ever stops for the layer change. It's the same with any other DVD player- it's too bad we can't access a service menu to calibrate it even more. But my PS3 is much better than even the standalone Sony DVP-CX985V 400 disc jukebox which would pause up to 3 secs during the layer change.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #15 of 34 Old 08-05-2007, 09:53 PM
kylebisme's Avatar
From what I've seen the pause is simply cause by players not buffering the disk to avoid it. Regardless, the two DVDs I've watched on my PS3 were both dual layer and both resulted in about 1 second of pause on layer change, the first time I saw it I even rewound a bit to see if buffering would kick in the second time though, but it paused just the same. So the PS3 obviously isn't buffering, and no amount jostling could have caused that and nothing less than a firmware update could fix it.
post #16 of 34 Old 08-06-2007, 05:47 AM
nagus69's Avatar
I thought the PS3 would be THE player to get rid of the visible layer change as it has enough memory to store 2 secs of a dvd movie but unfortunately, i am still waiting for a firmware update that fixes this
nagus69 is offline
post #17 of 34 Old 08-06-2007, 06:43 AM
Mattardo's Avatar
Using one of Sony's crappy mega-changers (no personal offense intended to you as an owner of one - I have also been a former owner) as a yard-stick to measure layer-break change speed in comparison to other players is not such a good policy. When I think of the money I spent hoping that each revision of the changers would vastly improve... well, I could have spent it on a life-time supply of better judgement.
Mattardo is offline
post #18 of 34 Old 08-06-2007, 10:18 AM
FenixP3D's Avatar
was gonna buy a separate upscaling dvd player when the wife said "No, just get the PS3..." I think I'm getting old because after some research the new revisions allows for dvd upscaling and i was gonna burn 80 odd bucks for a standalone despite knowing so... lol and behold i was able to get the ps3 nearly free ($60 when said and done) with my sony card visa points i've collected... i couldn't be much happier... a blueray player, dvd upscaler, and hd game console all in one.... watched a couple of standard dvds and they look nice especially with the samsung 46inch lcd, much better than watching it over my laptop with dell 20" widescreen... tried minority report to test some screens and oh man it's extra grainy...
FenixP3D is offline
post #19 of 34 Old 08-06-2007, 10:23 AM
corejonp1's Avatar
watched rush hour the other day on the ps3, running it with hdmi to my sxrd, and it upscales great. Looked way better than it did on my old pioneer.
.."wouldn't you like to be a pepper too?"
corejonp1 is offline
post #20 of 34 Old 08-06-2007, 04:50 PM
CommanderCool's Avatar
quick question..what do you set the upscaling to double normal etc.? i have it set to double
Xbox 360
Playstation 3 20gb
Samsung LN-S3251D
Logitech Z-5500
blu-ray!
CommanderCool is offline
post #21 of 34 Old 08-06-2007, 05:15 PM
FenixP3D's Avatar
iirc i think mine is set to normal.... i'l hae to check again...
FenixP3D is offline
post #22 of 34 Old 08-06-2007, 06:22 PM
corejonp1's Avatar
mine is set to normal, looks perfect.
try all the settings, see which one looks better.
post #23 of 34 Old 08-06-2007, 06:57 PM
ok cuz i had mines on double i just switched it to normal...im gonna try saving private ryan to see how it looks
Xbox 360
Playstation 3 20gb
Samsung LN-S3251D
Logitech Z-5500
blu-ray!
post #24 of 34 Old 08-06-2007, 07:04 PM
just switched it to normal and dvds look waaayy better than it did on double..black hawk down looks pretty darn good upscaled..now time to pick it up on blu-ray
Xbox 360
Playstation 3 20gb
Samsung LN-S3251D
Logitech Z-5500
blu-ray!
post #25 of 34 Old 08-06-2007, 07:12 PM
Huey's Avatar
I have 8 very good SD-DVD upscalers: Samsung HD-941 (DCDi, FLI-2310), Zenith DVB-318 (DCDi, FLI-2301), Philips 5982/37 (Mediatek), Bravo D1 (Sigma 8500, pixel map to PJ at 1280X720X59.94, HTPC (Radeon 9800 Pro, Zoomplayer, FFDSHOW, WinDVD6, WinXPHome, pixelmap to 1280X720X59.94), Samsung HD-755 (Zoran), Sylvania 1000G (Zoran). I retired Neuneo HVD-108 (AmLogic).
PS3 competes very well with any of these once calibrated. I now use PS3 solely as it plays games, SD-DVD, surfs internet, media playback, and of course BD.
Huey ;-]
Huey is offline
post #26 of 34 Old 08-06-2007, 07:17 PM
sunol's Avatar
Hmm, maybe I am alone in this, but I was actually kinda disappointed in the way the PS3 upscales standard DVDs. I much prefer the Oppo for SD DVDs. That said, I am on a 720p display.
sunol is offline
post #27 of 34 Old 08-08-2007, 09:30 AM
Archaea's Avatar
Quoted: 2839 Post(s)
Liked: 2416
so why can't the PS3 upscale to component?
Archaea is online now
post #28 of 34 Old 08-08-2007, 09:48 AM
saturnotaku's Avatar
It's an issue of copy protection. No DVD player can upscale over component.
saturnotaku is offline
post #29 of 34 Old 08-08-2007, 10:24 AM
crabbz's Avatar
It does upscale over component of the dvd isn't encrypted.
crabbz is offline
post #30 of 34 Old 08-08-2007, 12:00 PM
Evoex's Avatar
Hmm whats the difference between Normal and Full for upscale?
Panasonic AX200U/100" Screen
Onkyo TX-SR605
Xbox 360 Elite
Playstation 3 60GB
e8400 Gaming PC
Evoex is offline
Reply PlayStation Area
