PS3 Firmware update question? - AVS Forum
post #1 of 7 Old 08-09-2007, 10:29 AM - Thread Starter
harhash's Avatar
Is it possible to return back to firmware 1.82 after installing 1.9? and dose anybody have a link to european version of firmware 1.82...? its no longer on sony's website....
harhash is offline
post #2 of 7 Old 08-09-2007, 11:31 AM
VeeArSix's Avatar
you cannot go back to earlier versions once a firmware is installed.
Xbox Live: ChestR0ckWell23 (that's a zero after the R)
PSN: VeeArSix
VeeArSix is offline
post #3 of 7 Old 08-09-2007, 11:49 AM
solo88's Avatar
You can never go back.
My midis bring all the Force to the yard; my midis are better than yours!
solo88 is offline
post #4 of 7 Old 08-10-2007, 02:26 AM - Thread Starter
harhash's Avatar
Another question: Is it possible to update European PAL based PS3s with firmware downloaded from USA? my question is because my PS3 is still on firmware 1.5 and am planning to update and read on another message board (DVDit Pro HD Roxio message board) that firmware 1.9 may be the cause of some problems playing that program's authored blu ray discs..... no I have 1.9 downloaded from UK and 1.82 downloaded from USA but don't have a link for european 1.82 anymore.... can somebody help?
harhash is offline
post #5 of 7 Old 08-10-2007, 06:04 AM
BenjaminG's Avatar
They are all the same firmwares, so no point going to other regions. Just update via the official site in your region, or the network update on the console.
BenjaminG is offline
post #6 of 7 Old 08-10-2007, 11:45 AM
rcbtaw's Avatar
I updated yesterday from the PS3 website, and I got v1.82 instead of v1.9.
Robert Christian Barger
rcbtaw is offline
post #7 of 7 Old 08-10-2007, 01:55 PM
Mattardo's Avatar
That's because you're "format neutral" and Sony knows it. Try editing your description to "Blu-Ray Makes Me Mess My Pants" and Sony will probably give you the newest update. Sony is all-powerful and sees all - theres a word for that, but I don't feel like typing it. Impotent? No, that's not it...or is it? giggedy giggedy allright
"The well-placed coin changes much - even itself." - Lao-Tse
Mattardo is offline
Reply PlayStation Area
User Tag List
