External Hard Drive to PS3 via USB - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2008, 11:26 AM
iamkoza's Avatar
Originally Posted by Ovation View Post
Perhaps a dumb question, but if I dump a bunch of wav files (or high bit-rate mp3, for example) on an external USB HDD (in FAT32), does the PS3 OS see them (assuming I've got a drive that runs)? I'm interested in the PS3's ability to act as a central repository for my CDs without having to get a full-blown media centre or worry about streaming from a PC.
The PS3 can import your CD's to it's HDD in a variety of formats (depending onw hich you choose). But as long as you create a file folder named "music" on your external, it will be able to see your wav's and mp3's.
iamkoza is offline
Old 07-16-2008, 12:30 PM
Ovation's Avatar
Quoted: 102 Post(s)
Liked: 65
How about browsing through the songs? Is that easily done? And can I create the "music" folder using the PS3 or do I have to hook up to a PC and do it on that?
Ovation is offline
Old 05-30-2009, 07:48 AM
noobie123's Avatar
if i buy an Western Digital 1TB (External Hard Drive) and i put pics and vids on it will i be able to view it on my ps3?
noobie123 is offline
Old 05-31-2009, 08:30 PM
andydumi's Avatar
Yes. And music. Format it FAT32 though.
andydumi is offline
Old 11-16-2009, 10:22 PM
mchamblissII's Avatar
What is the best External Hard Drive for the PS3?
mchamblissII is offline
Old 11-23-2009, 11:44 AM
hikouka's Avatar
this seems to be the thread to ask, but is it possible to share a usb external drive plugged into a ps3 over a home network?
Hey, I'm a firm believer in the philosophy of a ruling class
Especially since I rule.
hikouka is offline
Old 12-06-2009, 02:00 AM
justgettingbyu's Avatar
How do you re format an external hard drive????? Davidseay18@yahoo.com if you have the answer to help me out!!! Thanks
justgettingbyu is offline
Old 12-06-2009, 11:35 AM
Zookster's Avatar
Quoted: 641 Post(s)
Liked: 464
On XP you can try Administrative Tools > Computer Management > Removable Storage to access the tools for formatting. You can also open My Computer and right click on the drive you want to format and select Format (make sure you set it to format in FAT32). Or, download Easseus Partition Manager for free at Cnet for even more powerful disk management tools: http://download.cnet.com/Easeus-Part...chmail_sc_name
Zookster is offline
Old 12-06-2009, 12:40 PM
steven975's Avatar
In Vista/7, create a shortcut on your desktop to "cmd"
Run it as an admistrator (right click option).
Type "format x: fs:fat32" where x is the letter of the external drive.
steven975 is offline
Old 02-21-2010, 05:42 PM
Tacklebary's Avatar
Hi Guys
I just picked up a new Seagate 1TB. Doesn't seem to work at all with the PS3 while hooked up by USB. I am a little concerned if I format the thing to a fat32 setting that this thing won't work properly as the software for the unit was already formatted when it came out of the box. Am I right to have these concerns?
Tacklebary is offline
Old 02-22-2010, 11:14 AM
zervinb's Avatar
You will HAVE to format the HDD as FAT32 file sstem, otherwise the PS3 will not recognize it.
zervinb is offline
Old 02-23-2010, 06:41 PM
andydumi's Avatar
Originally Posted by Tacklebary View Post
Hi Guys
What software for the unit? Its a hard drive, it should come formatted and empty from the factory, and whatever file system you format it for should not affect it.
andydumi is offline
Old 02-23-2010, 08:20 PM
Plex's Avatar
Originally Posted by Flavius View Post
1) It needs to be FAT32 PLUS it needs to be externally powered. I found out the hard way that the PS3's USB ports do NOT provide enough power for a standalone USB hard drive, so you need to add your own power supply.
2) The Toshiba Portable External drives (I have the 160GB one) work perfectly out of the box with the PS3 provided you use an AC adapter with them. Luckily, I had a matching one lying around the house.
Will my Denon 3808 AVR provide enough power to drive the HD, its always on if the PS3 is on?
Audyssey setup guide
Plex is offline
Old 03-30-2010, 04:13 PM
Jensen87's Avatar
Hi!
I have a Toshiba 1,5TB haddrive that i connected and used on PC an PS3, it worked fine. Until the day i found out that it was fat-32 format from Toshiba and i couldnt have DVD movies on it because of the file sice limit... therefore i formated the harddrive into NTFS, not knowing that the PS3 was not able to read that! then i tought, hey.. i just make 2 "disks" on it!(one NTFS and one fat-32) didnt work... and the werid thing now, is that i formated the HD back to fat-32 format, put all my videos, music and pics back on it like it was in the beginning when it all worked with out any further luck! in other words, my PS3 now dont recognize the same HD that only has been formated 3 times and should be just like when i first got it...
anyone have had this problem before and have a smart clue on how i get this fixed?
Jensen87 is offline
Old 03-30-2010, 04:55 PM
sitlet's Avatar
hmm not sure. i have my 1tb hard drive set up like that: a 100gb fat32 partition, and a 900gb ntfs partition. what software are you using to partition? are you doing a quick format or a full one?
and fyi, you can fit full dvds onto fat32. instead of making an ISO of the disc, you can just rip the VIDEO_TS folder. if you use a program like DVD Decrypter or DVD SHrink, it will automatically split the files into sizes that fat32 will accept.
sitlet is offline
Old 03-31-2010, 12:35 PM
zervinb's Avatar
But, I thought the PS3 was not able to play back ripped VIDEO_TS folders properly. I'd heard there's a slight pause when the PS3 changes from one file to the next. Although, this doesn't happen when the PS3 plays regular DVD discs. Anyone find this strange?
zervinb is offline
Old 03-31-2010, 06:59 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
turn sequential play? option on! Last time I had those transfered on ps3 hard disc, they just played flawless in sync
zoro is offline
Old 04-01-2010, 03:23 AM
zervinb's Avatar
Thanks for that. I started using a PS3 Slim recently (my first Playstation). Never used that functionality because I felt it wouldn't work (had read it in a few earlier posts).
Will definitely give it a try.
zervinb is offline
Old 04-01-2010, 11:27 AM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
keep us posted. btw I watch some asian dvd that possibly have screwed up flags and once ripped and viewed, anamorphic dvd is only viewed as letterbox oar, anamorphic function disappears! I could not figure that one. Can some one comment/?
zoro is offline
Old 04-02-2010, 12:44 PM
UxiSXRD's Avatar
Since my first YLOD showed me the errors of upgrading to my 320GB (and the planned upgrade to 500GB), I've seen the light in using an external drive for my media. Outside of the encryption/reliability issue, updates took forever (about 8 hours IIRC) on the 320GB.
Now I'm just wishing we had a rear USB port or two to hide the ugly cable coming off the front.
-- "No matter where you go, there you are."
SXRD/Denon/Polk/PS3/360/WiiU
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
Old 04-02-2010, 01:17 PM
dogdoctor's Avatar
You really think that the HDD upgrade is part of the cause of your YLOD? I really doubt it unless you were planning to run HDDs that ran at the higher RPMs even though I thought they were shown to only produce negligable heat differences and therefor while not impossible, would be very unlikely to contribute to YLODs. I'm of the opinion that if your mother board was going to YLOD it had nothing to do with you changing the HDD and more so the time invested into using the machine.
Just reread your post..
Or are you saying that your YLOD has shown you the need to keep external back-ups of your media. Now that I'm 100% behind. I have a HDD for my music (back-ups in case of failure and for ease of transport) and a HDD specifically for my PS3 HDD backup saves. If my machine goes down...I'm 99% covered for catastophic failure.
PSN ID: dogdoctor
dogdoctor is offline
Old 04-02-2010, 02:23 PM
UxiSXRD's Avatar
No, you took that the wrong way. I don't think upgrading the drive was a cause. But it ultimately showed me that using external USB was better (for shorter backup/restore time, if nothing else).
I am copious in backing up my data, so still have all the music, videos, etc. You can just pop a USB drive on there and near instantly have access to all of it... with the only current downside being that you'll have an ugly cable protruding from the front.
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
Old 04-02-2010, 03:51 PM
dogdoctor's Avatar
Ah yes, that makes much more sense. Now can I ask a question though. When I rip a CD on the PC, I can copy to the USB drive or transfer to the PS3 via wireless. But no matter what I do, when I view the music folder via the PS3, the tracks are always in random order. Now if you copy to the PS3, when viewing the music, it's all in the right place. Am I doing something wrong, or is that just something that you get used to if you don't copy the music to the PS3's internal drive.
PSN ID: dogdoctor
Old 04-03-2010, 07:19 AM
zervinb's Avatar
The PS3 too rips audio CDs, and quite well at that. Usually the PS3 displays the tracks in the order of their track number. You can manually change the track number in the metadata on the PS3. Hit triangle on a track and select "Edit". Lower down, you can see the track number.
zervinb is offline
Old 04-06-2010, 12:13 PM
Sucubus's Avatar
Quick note to say you may be able to use a non-powered USB HD by using a USB Y cable.
I am running one now.
Sucubus is offline
Old 04-06-2010, 04:48 PM
njfoses's Avatar
Quoted: 73 Post(s)
Liked: 63
So people are aware im using a seagate free agent go 880gb which is powered by a single usb cable and it works perfectly on my p3s.
njfoses is online now
Old 04-07-2010, 01:02 AM
TedSeattle's Avatar
Quoted: 87 Post(s)
Liked: 204
I just bought a 1TB Western Digital My Book Essential, but was unable to reformat it to FAT32. The formatting utility I downloaded from wdc.com gave me an error; I think it might be out of date.
Any recommendations on brands/models that are easier to reformat?
TedSeattle is online now
Old 04-07-2010, 01:08 AM
zervinb's Avatar
There are 3rd party programs that reformat your external drive as FAT32. A simple search on google will help you out.
zervinb is offline
Old 04-07-2010, 02:05 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Get this...
http://download.cnet.com/Easeus-Part...-10863346.html
Should do the trick.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
Old 04-07-2010, 03:21 AM
TedSeattle's Avatar
Quoted: 87 Post(s)
Liked: 204
If I partition the drive into a NTFS volume and a FAT32 volume, will the PS3 recognize the drive?
Playstation 3 160gb System
