Where did all the GBs go??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 02-06-2008, 08:23 AM - Thread Starter
bdwright77's Avatar
I just installed a West Dig Scorpio in my PS3. The numbers I got were ridiculous. Check them out:
HDD capacity - 250 GB (advertised)
HDD capacity after install - 232 GB
Available space BEFORE restore - 205 GB
Available space AFTER restore - 190 GB
Why am I missing 28 GB? The system information shows it as 205/232 GB, but there is nothing on the hard drive at this point. I havent restored all my data.
At least, I should have closer to the 232 GB of free space, considering that there is nothing on the PS3. Any help???
bdwright77 is offline
post #2 of 27 Old 02-06-2008, 08:29 AM
kplex's Avatar
Here's where the some of the initial space went - different ways of measuring a GB :
http://www.diskview.com/disk-size-discrepancy.htm
kplex is offline
post #3 of 27 Old 02-06-2008, 08:35 AM - Thread Starter
bdwright77's Avatar
Thanks kplex...I certainly understand that. However, that surely cant account for 28GB of missing storage space. That would only explain why it says that I have 232 GB instead of 250 GB as advertised.
It doesnt explain why, with nothing on the PS3, I only have 205 GB of free space out of 232 GB.
post #4 of 27 Old 02-06-2008, 09:00 AM
PJ_Rage's Avatar
I would say that is just how much the OS and stuff takes up, but it doesn't do that on my 60gb ?
SXRD/Oppo/Yamaha/Klipsch
PS3/PSN: pj_rage
360/Live: pjrage82
Originally Posted by Daekwan
Dude please, your list of toys is so long its like Santa is your dad lol.
PJ_Rage is offline
post #5 of 27 Old 02-06-2008, 09:01 AM
kplex's Avatar
Just guessing here, but probably the operating system on a PS3 allocates a swap file like Windows or a swap partition like Linux for virtual memory storage.
kplex is offline
post #6 of 27 Old 02-06-2008, 09:17 AM - Thread Starter
bdwright77's Avatar
If I do a full format restore, instead of the quick format restore, will that delete any unnecessary partitions?
Seriously, how the heck can I get back all that storage space? This is pretty frustrating.
post #7 of 27 Old 02-06-2008, 09:22 AM
bdoyledimou's Avatar
question.. what are you restoring if there is nothing on your ps3?
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #8 of 27 Old 02-06-2008, 09:23 AM
Gradthrawn's Avatar
As has been mentioned the file system accounts for some of the discrepancy in usable space you're seeing. However, the OS reserves a certain percentage, instead of a static amount, of the space for system/software (eg games) use only. You will never recover that space as long as the drive is used in the PS3.
Gradthrawn is offline
post #9 of 27 Old 02-06-2008, 09:23 AM
Conspiracy*'s Avatar
Quoted: 25 Post(s)
Liked: 37
Someone has posted a formula on here showing where the space goes. The bigger the advertised drive the more space you lose in the format. Something about HDD companies advertise 1gb to be 1000mb to make even numbers like 250gb etc. This is untrue because 1gb = 1024mb meaning you're automatically losing 24mb per gb advertised. On a 250gb drive thats 6gb right there. I dont know if the bigger the drive the bigger the "buffer" it needs of clean space or what.
I dont know much else, other than its a fact of buying a bigger drive and you have to deal with it. Imagine how sad I felt when I bought a 4gb ipod and realized it only had 3.19gb of usable space.
"Damn, you can't get black levels like that on your projector!"
- My brother, just before he realized his LED display had died.
Link to my Basement build
http://www.avsforum.com/t/1529034/conspiracy-basement-build
Conspiracy* is offline
post #10 of 27 Old 02-06-2008, 10:12 AM - Thread Starter
bdwright77's Avatar
I have backup data on an external HDD that I saved prior to upgrading the HDD.
I understand this. However, the OS did not take up this much space on the original HDD. Out of the advertised 60 GB HDD, 55 GB were available. Even if we account for different MB to GB conversions with the new drive and space for the OS, it would still not take up 28 GB of storage space.
Thanks, but again, the discrepancies in conversion and space needed for the OS will still not account for losing all of the 28 GB. It is the conversion and OS that cause it to be limited to 232 GB instead of 250 GB. It does not account for there only being 205 GB available out of the 232 GB.
post #11 of 27 Old 02-06-2008, 11:57 AM
Mr. Hanky's Avatar
Quoted: 93 Post(s)
Liked: 79
There is the issue of cluster size in the formatting of the hdd. For a given cluster size setting (usually not something you get to set, but rather a consequence of the default disk format that is used), a larger harddrive will have to give up more space just for addressing.
Think about the days of FAT16. It uses a relatively small cluster size to index the total space on the disk. This was fine when hdd's where in the sub-1 GB range. However, you start to lose considerable capacity to the formatting as you go past 1 GB in disk size. So then came along FAT32 which used a larger cluster size to index a larger hdd. This was fine back in the days of 10 GB hdd's, and even served well in the 10's of GB size range. However, things are probably getting long in the tooth again now that we are past 100 GB's and closing on the TB range. So that is probably what is happening in your 250 GB hdd. The cluster size of the formatting is taking it's "10%" out of the total capacity, which on a 250 GB drive turns out to be a considerable amount of space that you will never get to use. It's probably not FAT32 in your ps3 hdd, but I'm guessing it is something that adapts the same cluster size as FAT32.
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #12 of 27 Old 02-06-2008, 11:59 AM
ferrisg's Avatar
The OS doesn't take a static amount of drive space. If your example is accurate, it takes about 10% of the drive, which would account for the majority of the space being used that you're seeing. It may not even be a static percentage, but instead be based on the size of the drive. As Gradthrawn said, somewhere on AVS this was covered before with more detailed information on what percentage of the drive the OS uses. I remember seeing it, but I'd probably have a tough time finding it.
ferrisg is offline
post #13 of 27 Old 02-06-2008, 12:01 PM
ferrisg's Avatar
The cluster size only affects wasted space due to small files. That is, if you have a cluster size of 4KB, then any file smaller than that will still require 4KB of disk space to be stored.
The "space lost to format" (which is an entirely inaccurate description) is solely due to the fact that hard drive makers report GB as GB, and OS developers report GiB as GB. When a hard drive is advertised as 1 GB, it is 1 GB. But an OS will tell you that it's 976 MB when it should be telling you it's 976 MiB.
ferrisg is offline
post #14 of 27 Old 02-06-2008, 12:57 PM
MIAaron's Avatar
Did you look at your old hard drive? The '60gb' hard drive in my launch system was a 74gb or 75gb Seagate Momentus. Yet the hard drive in my 40gb was a 40gb hitachi travelstar. It showed up as 32gb left on the ps3. So the 40gb ps3 had 32gb of usable space, and the 60gb had 55gb of usable space but had a 75gb hard drive. So 205gb on a 250gb drive seems about right(approx. 20% reserved for OS).
MIAaron is offline
post #15 of 27 Old 02-06-2008, 01:29 PM - Thread Starter
bdwright77's Avatar
I appreciate all of your responses. The reasons above seem to present valid explanations to what I am experiencing.
I hadnt examined the original HDD to confirm if it was precisely 60 or rather the 75 GB as mentioned above. Nonetheless, I was not aware that the OS would take a percentage, rather than a fixed amount of space.
I guess i will have to stomach losing the 28 GB. Thanks for your help everyone, and sorry to cover a topic that appears to be a re-hash for most.
post #16 of 27 Old 02-06-2008, 01:54 PM
DubBucket's Avatar
Huh, I didn't know that. That's awfully nice of them to pop in a 74GB drive and advertise as a 60G. I realize that they were probably trying to cover the OS footrprint that way, but usually they post the higher physical number. Another reason to be thankful for my 60gigger
DubBucket is offline
post #17 of 27 Old 02-06-2008, 02:37 PM
ferrisg's Avatar
There isn't a 75 GB 2.5" Seagate SATA drive (or any other brand that I'm aware of). How did you come to the conclusion that it's a 75 GB drive? There is an 80GB drive, but I think it's unlikely they would've used that in the 60GB system.
ferrisg is offline
post #18 of 27 Old 02-06-2008, 03:16 PM
todrigo's Avatar
very interesting, my 60GB PS3 contained a 60GB hardrive that reformatted to something like 56.5 GB after I removed it from the PS3
PSN - todrigo
todrigo is offline
post #19 of 27 Old 02-06-2008, 05:03 PM - Thread Starter
bdwright77's Avatar
you guys are right. I checked the HDD I removed from my PS3 and it is a standard Seagate Momentus 60 GB HDD. I guess I am still wondering why the OS would take up 5 GB on this drive, but a total of 45 GB on my 250 GB HDD from Western Digital.
post #20 of 27 Old 02-06-2008, 06:37 PM
reisb's Avatar
Quoted: 51 Post(s)
I have std 60GB PS3. How can I check how much available space is left?
reisb is offline
post #21 of 27 Old 02-06-2008, 10:11 PM
Mr. Hanky's Avatar
Quoted: 93 Post(s)
Liked: 79
Yes, there is that situation. However, I was more trying to draw attention to the shear size of the master directory that is needed to keep record of (address) all the clusters that can exist on a 250 GB disk. Naturally, that is something that will grow in size alongside the disk size (one cluster size + plus larger drive ==> more logical clusters to be uniquely identified in a table). At 250 GB, it turns out to be a sizable amount beyond just "a few gigabytes of overhead" that we are accustomed to in smaller drives.
post #22 of 27 Old 02-07-2008, 08:12 AM
reisb's Avatar
Quoted: 51 Post(s)
Anyone know how to do this?
reisb is offline
post #23 of 27 Old 02-07-2008, 08:47 AM
tomsteeper's Avatar
I think that on top of the discrepancy due to 1024 or 1000 being used...which eats up quite a few GBs as the drives get larger, also I think the PS3 reserves a percentage of the drive for cache/swap etc. So on a 60GB this may account for 5GB (guess) but on a drive 4x this size, this would account for 20GB.
This is not concrete information...just something I remember reading a while ago.
Tom
tomsteeper is offline
post #24 of 27 Old 02-07-2008, 08:49 AM
ferrisg's Avatar
That depends entirely on the partition type. For FAT32 (which is what is probably used here), you're only talking a couple of MiB for the FAT on a 250 GB drive. Even if you had the max number of clusters possible (2^28), you'd only take up about 1 GiB for the FAT.
ferrisg is offline
post #25 of 27 Old 02-07-2008, 08:50 AM
Sunkist's Avatar
system information in the XMB, all they way at the bottom of the second "tab"
where system settings and such are.
Sunkist is offline
post #26 of 27 Old 02-07-2008, 11:46 AM
MIAaron's Avatar
After researching replacement HDD's I thought the same thing when I saw it. I didn't care enough to look at it any more carefully than that though, and threw it into an ext enclosure. It's odd that it said that on the drive though, cuz XP Pro shows 74gb of available space as well. Usually I have a pretty good memory, but I'm gonna take it home and remove the drive to check it out again.
MIAaron is offline
post #27 of 27 Old 02-07-2008, 11:59 AM
ferrisg's Avatar
An 80 GB drive will show up as about 76 GB in Windows. Are you sure you didn't have an 80 GB PS3 that you upgraded?
*EDIT*
I see you said launch system, when there weren't 80 GB systems. Odd. I'd be interested to know the model number off the drive. It's on the sticker on the top cover. Usually the second item on Seagate drives.
ferrisg is offline
Reply PlayStation Area
