Proper video and audio PC to receiver hook-up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-01-2008, 05:08 PM - Thread Starter
affiatati7's Avatar
I would like to hook-up the video and audio from my Dell computer to my Onkyo Receiver TX-SR605 receiver and thus a 7.1 surround sound system hooked up to a Samsung LN-T5781F 57" LCD Flat Screen. The purpose is to play video games, saved on my PC, I have onto the LCD Flat Screen with possible surround sound. I would like to plug both video and audio into the receiver then have one HDMI output to TV.
Sound Card: Creative SB Live
Video Card: Radeon X1300/X1550 Series
Questions:
1- What is the best audio/video cable connection configuration to do the job. Attachment shows a picture of the back of my computer (sound card on top and video card on bottom)?
2- Do I have to change the sound card to transfer 7.1 surround sound to receiver?
3- Do the PC games have to be in surround sound? How do I know if they are?
The Onkyo receiver has the following inputs:
HDMI
component video in
S-Video in
Optical Digital in
Coaxial Digital in
affiatati7 is offline
post #2 of 4 Old 04-02-2008, 12:21 PM
Brown Radagast's Avatar
Hi affiatati7 - welcome to the forums
Video: PC HDMI-->Receiver-->TV HDMI
Audio: PC pass-thru Optical/Coax (via rca connectors)-->Receiver-->speakers. Check soundcard config and then see what receiver display says it is getting from PC to ensure DD/DTS/etc. is coming through correctly.
Have fun, just don't turn off all the lights while playing certain sinister-themed games until you get used to having explosions, yelling, bullets flying, etc. all around you!
MY DILEMMA: New car or PJ? New car or PJ? New car or PJ?
Brown Radagast is offline
post #3 of 4 Old 04-02-2008, 08:13 PM
M4H
M4H's Avatar
Everything for the video connection-wise is pointless, since you need a better video card before you even consider anything more intense than Minesweeper HD.
M4H is offline
post #4 of 4 Old 04-11-2008, 03:34 PM
JosephJEHancock's Avatar
If you can afford a new GPU (graphics card), then consider the ATI Radeon HD 3850 512MB for $154.99. It will devour any game from 2006 and before, and does very well with 2007/2008 games. Also, it carries audio over HDMI, which a lot of GPU cards do not do (my 8800GTX for example).
I hope to get an HDMI equipped card next.
JosephJEHancock is offline
Reply General Gaming Help
