S-Video for Dreamcast Problems? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 08-11-2008, 10:54 AM - Thread Starter
HMArndtGolf's Avatar
I've bought two S-Video hook ups for my Dreamcast and neither of them work correctly. The L/R/V for each works right but when I plug in the S-Video feed the screen turns black and white and the picture is not clear.
Any idea what the problem might be? I've looked for a place where I have to specify S-Video inputs (both on the unit and in the games) but can't find one.
Thanks for any help.
HMAG
HMArndtGolf is offline
post #2 of 44 Old 08-11-2008, 11:40 AM
number1laing's Avatar
Liked: 32
Does the picture show up with the regular composites? Because if not, your DC is busted.
If it does, then the cables are busted. The DC isn't a PS3 or a 360, you don't need to specify what cables you are using. It just works.
number1laing is offline
post #3 of 44 Old 08-11-2008, 12:10 PM - Thread Starter
Yes, the picture shows up correctly with the standard L/R/V connection that came with the DC and the L/R/V connection that came with the S-Video cable. The picture messes up when I plug the S-Video cable itself into the tv.
I was trying to use an S-Video cable with my DC in order to get a better pic on my 50" plasma.
HMAG
post #4 of 44 Old 08-11-2008, 02:29 PM
meany's Avatar
The S conector on the TV is bad. Give it a wiggle with the cable in and see if it works.
meany is offline
post #5 of 44 Old 08-11-2008, 02:56 PM
antwon412's Avatar
Quoted: 12 Post(s)
grab a vga conector off ebay if you can. that will be the bes PQ you can expect
(A/V)Ignorance is Bliss -------- sweet, cheap bliss
antwon412 is offline
post #6 of 44 Old 08-11-2008, 07:22 PM - Thread Starter
I just tried that, on the back of the tv and on the front, neither one works. Thanks.
HMAG
post #7 of 44 Old 08-13-2008, 01:06 AM
sage11x's Avatar
Quoted: 729 Post(s)
Liked: 808
Seems silly to ask but... Are you unpluging the composite before you plug in the s-video? They can't be both connected at the same time.
Other than that have you tried a different device thru s-video to make sure it's not the jack itself?
I'll agree with another poster that the vga box is the best way to go. Not all games are compatible with it, however.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #8 of 44 Old 08-13-2008, 02:43 PM
DarkZero24's Avatar
Why would you even bother using S-video on a plasma instead of the far-superior VGA signal, unless one of your favorite games is one of the few that does not support it?
If you must use S-video, I'd say the cable is busted. What you could do is get a VGA box that also has outputs for audio, composite video, and S-video. That way, not only can you switch between VGA and S-video, but you'd be able to determine if indeed it is your cable (since any old S-video cable would work with this box) or the Dreamcast itself.
DarkZero24 is offline
post #9 of 44 Old 08-13-2008, 04:07 PM
HDgaming42's Avatar
Quoted: 163 Post(s)
HMAG
Have you verified your s-video port works with another source? Another game system/svhs vcr, cable box etc?
The other posters have a point. You will cry when you see how bad your dreamcast looks over s-video on a plasma. I bought my VGA cable from racketboy
http://www.racketboy.com/store/dream...-cable-box.htm
currently in stock and cheap. Works. And you don't have to deal with fleabay.
Worth a try--just test your vga port first to see that it accepts 640x480 and doesn't look terrible! Not all sets' VGA ports are good...
HDgaming42 is offline
post #10 of 44 Old 08-14-2008, 09:16 AM
Mw182006's Avatar
I'm about to pick up that VGA box as well. How do you have audio connections set up? I understand there's a little RCA out on the box, do you have a splitter going to RCAs then running to your AVR/TV? I'm finally upgrading to a HDMI receiver and wondering the best way of integrating the DC.
X360 games up for trade/$: GTA4, Top Spin 3, Jericho, Dark Sector, RB6: Vegas, Burnout Revenge, Gears of War -- PM me!
Mw182006 is offline
post #11 of 44 Old 08-15-2008, 08:35 AM
Liked: 32
I honestly have hooked up the DC to my 40" LCD via VGA and eh... its not that great. Honestly I am thinking about hooking it up to my 22" monitor, or even getting a cheap older TV for it (and SNES, and NES, etc.). These systems were just not designed for these TVs.
post #12 of 44 Old 08-17-2008, 08:25 PM
acampero's Avatar
I have my DC hooked up via VGA to my 56" Toshiba HD CRT and I must say it's amazing.
Even though some of the Capcom games have sprites that are low res, it still looks incredible and games like Jet Grind Radio, Alien Front Online and Marvel Vs. Capcom 2 just blow me away.
So much better resolution and color than the S-Video cable.
Only bummer is a few games don't support it, but thats the tradeoff.
Definitely worth it if you are a DC fan
acampero is offline
post #13 of 44 Old 08-21-2008, 09:19 AM
Mw182006's Avatar
How are you running audio?
Mw182006 is offline
post #14 of 44 Old 08-21-2008, 10:11 PM
acampero's Avatar
Stereo mini out of the VGA box to L/R inputs on my receiver.
acampero is offline
post #15 of 44 Old 08-24-2008, 09:35 PM
Slydragon's Avatar
I have the same issue as the op, It did this on my 2 LCD tvs and I tried the cable with 2 different DC's. I know the S videos work because I tested them out with my camcorder. I only get it to work with R/L/V cable.
Slydragon is offline
post #16 of 44 Old 10-27-2008, 11:22 PM
pcweber111's Avatar
Quoted: 30 Post(s)
Liked: 267
Nah it's not silly to ask and more people forget to disconnect the composite video before pluggin in S-video than I care to remember (assuming we're talking about the same input here).
As for the VGA adaptor it's great and all but to me the s-video produces a damn good looking image that is hard to beat with older 2d games.
pcweber111 is offline
post #17 of 44 Old 10-28-2008, 01:19 AM
Shin CZ's Avatar
VGA'd Dreamcast looks better than a Wii via Component. Their 480p is far superior despite the lak of widescreen.
Shin CZ is offline
post #18 of 44 Old 10-28-2008, 01:22 AM
Shin CZ's Avatar
On my (now sold) 1080p LCD, Dreamcast via VGA looks BETTER than a Wii via Component. I know I'm repeating myself, but seriously, my Dreamcast came back to life JUST because of the VGA.
Shin CZ is offline
post #19 of 44 Old 10-28-2008, 12:58 PM
Mw182006's Avatar
I've yet to pick up the VGA adapter, is it worth it if I have upscaling in my AVR (Denon 1909) and TV (Samsung 5087)?
Mw182006 is offline
post #20 of 44 Old 10-31-2008, 05:58 AM
Shin CZ's Avatar
Regardless of what upscalers you may have, VGA gives the best possible PQ your Dreamcast can have.
Yesterday I played Marvel vs Capcom 2 on my new 67" 1080p set and it looked GREAT.
Shin CZ is offline
post #21 of 44 Old 01-10-2009, 03:34 PM
HDTVblues3's Avatar
I'm having the same issue with a s video/av I bought off ebay. I get b & w picture on each input i tried.
I tried the DC with S video on my lil bro's tv and it worked/looked great.
MY set: Sony Wega 30" Widescreen hs420
Tried in full and Normal
Bros: Magnavox 20" Flat-screen
Shop I bought from:
vpgames.com (I purchased through ebay/paypal, tho)
gift card: "vpgvd3" for $3.00 off
HDTVblues3 is offline
post #22 of 44 Old 03-25-2009, 02:23 PM
kmlm13's Avatar
Was this ever solved because I'm having the same problem?
kmlm13 is offline
post #23 of 44 Old 03-26-2009, 06:34 PM
SlaughterX's Avatar
Yeah my Dreamcast S-video cable that I bought off ebay years ago just stopped working for some reason last year. When it did work however, it looked great on the CRT HDTV in my bedroom. I also have a Dreamcast hooked up to my 22" LCD PC monitor and it also looks great, but s-video does give VGA a run for its money on the Dreamcast from my experience, though VGA is obviously better when supported properly (for most games).
SlaughterX is offline
post #24 of 44 Old 03-27-2009, 08:24 AM
kmlm13's Avatar
What VGA box do you have?
kmlm13 is offline
post #25 of 44 Old 03-31-2009, 11:32 AM
bleedingthru's Avatar
this happend to me as well tried 2 s video cables thye dont work tried all my tv's in house nothing worked , i took my cables back to play n trade where i got them the clerk said this happend to 3 other guys saying the same thing (black and white picture with s video)
bleedingthru is offline
post #26 of 44 Old 04-01-2009, 11:24 AM
Liked: 32
I have a working S-video cable for DC, but actually I can't get my monitor (Dell 2005FPW) to work with my VGA Box.
post #27 of 44 Old 05-23-2009, 02:23 PM
implant's Avatar
I have tried using an s-video cable as well as using the s-video out on my VGA box/adapter and have the same problems. I have tested 3 Dreamcasts on 2 HDTVs (LCD and CRT) and have the same problem as the original poster. I'm starting to think the Dreamcast puts out some non-standard s-video that modern s-video components don't display correctly? I am going to run over to my parents house and test on their standard def TV to see what happens.
I wish my LCD TV had VGA inputs... (not about to shell at $200 for a VGA -> component adapter)
(my Saturn and Jaguar with S-Video work great on both TVs)
Could be a bad cable, check out this thread from Digit Press http://www.digitpress.com/forum/showthread.php?t=123024
implant is offline
post #28 of 44 Old 01-17-2011, 09:57 PM
Super XP's Avatar
I too am having the same issue with S-Video cable connected to my Dreamcast. I tried two of them with the same black & white problem. I've confirmed that my S-Video connections on my DVD Recorder, my 2 x HDTV's and on my Digital Receiver all work great, so it must be the Dreamcast somehow blocking us from using S-Video or something...
Though I've tried something interesting if anybody wants to try it, I hooked up my Dreamcast via RCA Composite to my Toshiba DR7 DVD Recorder and up-converted my Dreamcast to full 1080p. It looks "A LOT" better than when I had it running at 480i. The picture looks a lot cleaner. Resident Evil: Code V looks fabulous along with Crazy Taxi 1 & 2.
I did order the VGA box because I am willing to go down to 480p if it provided me with better image quality seeing how the Dreamcast's Picture was originaly designed for 480p...
Did anybody find a FIX in regards to Dreamcast cennected via S-Video and producing B&W images?.
Super XP is offline
post #29 of 44 Old 01-18-2011, 01:08 AM
darklordjames's Avatar
Liked: 94
A grayscale image on s-video means you are getting luma (light) but not chroma (color) through the connection, which are two distinct wires in the s-video standard. This would imply that one of the connectors is not making contact somewhere. On one of my Dreamcasts that used to live in my bedroom, the s-video cable was a little wonky. It would go gray, until you gave it a little downward pressure, at which point color would snap right back in. I ended up just replacing the cable, but I would suspect that the video port on the DC is just a little poorly designed for s-video out, plus the cable probably has an ever so slightly bent pin.
http://pinouts.ru/Game/dreamcast_pinout.shtml
Pin 11 looks to be your culprit. Look at the cable and see if it's possible to just bed the pin a little further up, helping it make contact.
Also, if you have VGA on the display, then holy hell just get the VGA box. VGA out of a Dreamcast is fantastic. It looks better than a PS2 or Xbox, and rivals a component Gamecube in video quality.
darklordjames is offline
post #30 of 44 Old 01-19-2011, 07:17 AM
Super XP's Avatar
Would VGA at 480i look better than composite via my DVD Recorder up-scaled to 1080p? I mean without up-scaling the picture looks kind of crapy but once up-scaled, it does make a big difference.
I have a VGA box on the way because I am fed up with the S-Video connection. I am getting my money back for the S-Video.
Though I will try wiggling the cable where it meets the Dreamcast.
Super XP is offline
Reply General Gaming Help
