Blue pixelation with video games? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-06-2008, 11:29 AM - Thread Starter
brian oakville's Avatar
This is my problem?
I have the Onkyo 706 receiver and I run my PS3 and XBOX 360 through it using HDMI cables (1.3a). I have recently bought the Samsung 50" Plasma series 6 TOC.
When I play video games on both systems I get blue pixelation in the dark areas. I plugged the HDMI from both systems directly into the TV and the blueness goes away. So it only appears when I have it going through the receiver.
I recently had a Toshiba DLP and I never had this problem.
I am begging for some help here, I just got my system set up using all HDMI's and I really dont want to have to go back and use optical cables to my receiver and plug directly into the TV.
I know you guys are the best, please help.
brian oakville is offline
post #2 of 6 Old 12-06-2008, 08:14 PM
PvtChurch's Avatar
Calibrate your TV then come back if the problem persists. Avia is the best disc to use for calibration. Followed by Digital Video Essentials and the good old cheap-o route of the THX Calibrator you can find on any Star Wars movie as well as many others.
Always remember: The pessimist is never disappointed.
PvtChurch is offline
post #3 of 6 Old 12-06-2008, 09:23 PM - Thread Starter
Hey,
Thanks for replying, I tried it and it didnt work. The picture does look better though. lol
Its definately something to do with my receiver, because when I plug the PS3 and XBOX directly to the TV it goes away.
post #4 of 6 Old 12-08-2008, 07:20 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
Looks like a nice receiver. I'm guessing you tried messing around w/ the settings on the Onkyo? Are there many setting options for HDMI?
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #5 of 6 Old 01-15-2009, 05:42 AM
dtanner's Avatar
I am having the same problem with the TX-SR806. It occurs all the time in some games, and only sometimes in others. Did you find a solution to this problem?
dtanner is offline
post #6 of 6 Old 01-20-2009, 03:24 PM - Thread Starter
No I havn't and its been in for servicing twice. I'm wondering if its dirty power. I am currently resurching power conditioners and will be purchasing one soon. I'll let you know.
Reply General Gaming Help
