Setting up Xbox 360 w/ Onkyo TX-604 (Fixed) - AVS Forum | Home Theater Discussions And Reviews
Old 01-11-2009, 12:08 AM - Thread Starter
nflu2154's Avatar
I have a Mitsubishi DLP with an Onkyo receiver. I'm trying to set up my Xbox 360 to use component over HDMI. Right now I have my Xbox hooked up through the Component IN1 slot. I want to use it on the input of Video 2, so I went into the Video Input menu and under the Component section I set Video 2 to IN1. From there I don't know where to go, all the manual says is that it supports Component over HDMI, but doesn't say how to set it up.
I am pretty new at this stuff so any advice would help.
I have figured out the issues I ran into.
nflu2154 is offline
