connectivity with crt monitor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-31-2009, 01:55 PM - Thread Starter
matryx's Avatar
I have a PS3/Xbox360 that I want to play on my CRT monitor. It only has a 15 Pin VGA D-SUB and 5 pin BNC inputs. What can I use to connect my PS3 to my monitor where can I get on of those cables in Canada? Any help would be appreciated.
matryx is offline
post #2 of 11 Old 02-02-2009, 08:02 AM - Thread Starter
matryx's Avatar
anyone?
matryx is offline
post #3 of 11 Old 02-04-2009, 07:16 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
Well for the 360 you can just pick up the the 360 VGA cable like the one at monoprice.com (http://www.monoprice.com/products/pr...seq=1&format=2).
I don't know much about the PS3 connections..
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is online now
post #4 of 11 Old 02-06-2009, 08:23 AM
m.fox's Avatar
Unfortunately, you cannot connect PS3, because your TV doesn't have the necessary inputs. Since I can't post URLs 'cause of 3 posts rule, google "PlayStation 3 accessories" and on Wikipedia under AV Cables you'll find more info.
Have a nice day.
m.fox is offline
post #5 of 11 Old 02-12-2009, 01:07 PM
j6044's Avatar
pickup a cheap scan converter. Thats what i do. I just press the button on it to cycle through sources, in my case it is tv / ps3 / or camera ( for baby)
j6044 is offline
post #6 of 11 Old 02-12-2009, 03:52 PM
257Tony's Avatar
You will need a converter that will handle HDMI to VGA conversion. The HD fury would work well, but it is not cheap.
257Tony is offline
post #7 of 11 Old 02-18-2009, 10:29 PM
DarkZero24's Avatar
http://www.gameyeeeah.com/wii-ps3-vga-cable-p-746.html
It's not a true VGA cable (it transcodes a component signal into VGA, basically), but it should do the work. It also works for Wii.
DarkZero24 is offline
post #8 of 11 Old 03-02-2009, 07:54 AM - Thread Starter
matryx's Avatar
I have another question. Is it possible to connect my PS3 to my CRT monitor by connecting it to my ATI AIW 9800 PRO video card that has input adapter? The video card will be connected to my 21" Sony CRT monitor using a VGA-DVI adapter. The video card has a component input adapter and it has one for composite inputs (yellow,red,white)
Would this be possible and what would I need to do or what programs would I need to get this working?
matryx is offline
post #9 of 11 Old 03-02-2009, 04:49 PM
darklordjames's Avatar
Liked: 94
"The video card has a component input adapter and it has one for composite inputs (yellow,red,white)"
You should double check that info. Chances are good that it has a component video output adapter, and composite/svideo input.
darklordjames is offline
post #10 of 11 Old 03-03-2009, 09:08 PM
WiseGuy2k7's Avatar
for the money ur gunna spend on cables and hdmi to vga converters.. u might as well have bought an lcd computer monitor or lcd tv.
PSN:The_Wise_Guy
XBL:DirtySanWiseGuy
Steam:The_Wise_Guy
BF4 PC:The_Wise_Guy
WiseGuy2k7 is offline
post #11 of 11 Old 03-03-2009, 09:19 PM
Liked: 94
Novel idea, WiseGuy! "Buy a modern display."
Reply General Gaming Help
