connecting two VGA cables into Samsung LED - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-21-2009, 04:59 PM - Thread Starter
Grimmy89's Avatar
Hey this is my first post on the site and I think I've found a good spot for my question. If this is not the correct spot please direct me to where.
As for my question,
I am trying to figure out how to hook up my game system (xbox 360), and desk top computer via VGA to my UN46B8000 LED TV. The LED tv has one PC IN slot so I was thinking of finding a splitter. Will this work? And if it does will it degrade anykind of quality?
I am not sure if we are allowed to post links for explanation purposes but I can describe it.
I found this splitter, HD15 Male to (2) HD15 Female. The VGA splitter cable is for splitting VGA signal to 2 VGA high-resolution monitors. Splitter supports High Resolution and the splitter is tested at 1920X1440 resolution at 75Hz refresh rate.
Is this good?
Help is apprectiated and I thank anyone who posts in advance.
Grimmy89 is offline
post #2 of 3 Old 06-21-2009, 08:23 PM
257Tony's Avatar
I think you'd be better of with a switch vs. a splitter, that way you can actually have both devices running at the same time if you want. Something like this should work.
http://www.monoprice.com/products/pr...mat=4#feedback
You may be able to find one with a remote if you look around.
257Tony is offline
post #3 of 3 Old 06-21-2009, 09:27 PM - Thread Starter
Grimmy89's Avatar
thank you your post was extremly helpful.
-Grimmy
Grimmy89 is offline
Reply General Gaming Help
