Pro Logic - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-28-2009, 08:03 PM - Thread Starter
avfan9's Avatar
Do video games work well with Pro Logic II? Any recommendations?
avfan9 is offline
post #2 of 5 Old 09-01-2009, 08:17 AM
oktoberrust11's Avatar
Quoted: 71 Post(s)
Liked: 38
Yes, Pro Logic II is a good surround format if your console/receiver doesn't support Dolby Digital. What console(s) do you have?
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #3 of 5 Old 09-02-2009, 04:15 PM - Thread Starter
avfan9's Avatar
Wii and PS2 (old version)
avfan9 is offline
post #4 of 5 Old 09-03-2009, 05:55 AM
Quoted: 71 Post(s)
Liked: 38
Perfect, they should both sound good. The Wii can output a max of Pro Logic II, and it sounds quite good. I can't recall if PS2 outputs DD, but either way, it should sound good as well.
post #5 of 5 Old 09-03-2009, 09:22 AM
jwebb1970's Avatar
Liked: 38
When done right (ie REIV, RB2, most any Nintendo-developed title), DPLII sounds damned fine & surround FX are great on the Wii. Games that use Wiimote's speaker can add another level of audio immersion. You won't get discrete 5.1 audio, but you get something close.
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
Reply General Gaming Help
