S-Video Checkerboard Pattern help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-28-2009, 08:07 AM - Thread Starter
notsonic's Avatar
I'm getting a pretty defined checkerboard pattern with nearly all of my consoles that I hook up to my tvs with s-video. Dreamcast, saturn, n64, snes, and so on, all show a really annoying checkerboard or screen door type pattern.
I don't know if they've always done this, but I don't really recall seeing it before, though it was on a different tv. (for a period of time I really only played my newer consoles with component or older ones with only composite.)
Any ideas? Theres not much info online about this.
Should I just get scart cables for all of em and get a scart to rgb converter?
notsonic is offline
post #2 of 6 Old 09-28-2009, 09:02 AM
number1laing's Avatar
Liked: 32
A checkerboard all over the whole screen? Or just in certain games, in certain sections.
number1laing is offline
post #3 of 6 Old 09-28-2009, 09:07 AM - Thread Starter
notsonic's Avatar
its a noise pattern over the whole screen.
i know checkerboards are used to simulate transparencies but its not that at all.
here are some pictures of whats going on. i didn't take these but its exactly whats happening.
the guy who took em said that he upgraded his svideo cables to get rid of it. went from a cheap cable to a $30 one.
notsonic is offline
post #4 of 6 Old 09-28-2009, 09:11 AM
Liked: 32
Yea I doubt its the TVs, and I doubt its the systems, if I were you I'd test out that guy's theory by upgrading your cable with one of the systems and seeing what happens.
post #5 of 6 Old 11-28-2009, 02:18 PM
DarkZero24's Avatar
I can confirm it is definitely the cable. I also had a cheapo 3-systems-in-1 cable for the Xbox, PS2, and GameCube, which I used with the SNES, and I would get diagonal lines all across the screen, similar to that picture. Then I went ahead and ordered a Monster GameCube S-video cable off Amazon for $5, and the lines went away.
Apparently, it has to do with how they wire the cheap cables. I don't remember the specifics, but it has something to do with the chroma and luma signals crossing over somehow.
So yeah, get a good quality cable, and you won't get this problem.
DarkZero24 is offline
post #6 of 6 Old 11-29-2009, 09:34 AM
joe531's Avatar
Hey this is like my problem: http://www.avsforum.com/avs-vb/showthread.php?t=1198196
My solution is also to buy a new cable. Sigh.
joe531 is offline
Reply General Gaming Help
