Xbox 360 & PS3 Connect to DVI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-01-2009, 01:11 PM - Thread Starter
L-Kuco's Avatar
Ok Guys and Gals, here is my issue.
I have an LG DU-42x12xc (I have attached a pic of the inputs & outputs that are on the back of the Plasma)
What I'm trying to do is Hook up My xbox360, PS3, and HD Cable Box but i only have 1 DVI slot. I know i can hook up the xbox360 and PS3 using Component cables but i want the best picture quaility and DVI is the best that my Plasma has.
So what can i Do? IS there a splitter that i can get? Does it really matter if im hooking up my gaming systems using Component cables? What about when i want to watch Blue Ray movies using my PS3, what will happen to that quaility?
In advance thanks for what every advice any one can offer.
L-Kuco is offline
post #2 of 4 Old 12-02-2009, 03:58 AM
darklordjames's Avatar
Liked: 94
Hook up the PS3 with HDMI-to-DVI, and hook up the 360 with VGA. VGA out of the 360 is excellent, and is usually the only way to run the 360 at the display's native resolution.
darklordjames is offline
post #3 of 4 Old 12-02-2009, 08:17 PM
glum's Avatar
also, cable box to component.
glum is offline
post #4 of 4 Old 12-02-2009, 09:13 PM
Liked: 94
Oh yeah. Cable is so terribly compressed that it won't matter if it's on component.
Reply General Gaming Help
