Hooking my Gaming PC to an Onkyo HTS5300 Home Theater System - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2011, 03:08 PM - Thread Starter
Agauos's Avatar
I just need to know if I can plug this:
LINK: (http://www.tigerdirect.com/applicati...28&CatId=1587#)
from this this port (what i believe to be SPDIF out/digital out):
LINK: (http://www.newegg.com/Product/Produc...82E16813128392)
to this digital in port on the Onkyo HTS5300 Home Theater System:
LINK: (http://www.us.onkyo.com/model.cfm?m=...ss=Systems&p=i)
and have it all work fine and dandy with amazing sound? Obviously I will need to hook the system up and I can do that, I just need to know if this cable will work between my computer and the Onkyo. Thanks for your help!
Agauos is offline
Old 01-07-2011, 04:56 PM - Thread Starter
Agauos's Avatar
On another note, if I just plug an HDMI cord from my video card, into the system, will I get actual 7.1?
Agauos is offline
Old 01-10-2011, 06:41 PM
modernninja's Avatar
If your video card supports 7.1 audio, I would suggest the hdmi...
modernninja is offline
