Xbox 360 no sound through HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-28-2011, 12:37 AM - Thread Starter
killerrabbit's Avatar
Okay, I am having a very strange problem that is pissing me off to no end.
I run my Xbox 360 through a Pioneer VSX-819H A/V receiver to an Insignia 42 inch 720p HDTV. It's simple to hook up *HDMI from Xbox to receiver, and HDMI from receiver to TV. Everything worked great, and I got my surround sound. Three days ago, I removed the HDMI cable connecting my Xbox to the receiver to use at a friend's house. When I brought my cable back and plugged it back in exactly the same way as before, Xbox to receiver I now get no sound from my Xbox. What is going on? I've google for solutions but have not found anything that works. The cable is not at fault; I have switched the two and still get no audio. Meanwhile, when I watch regular TV, the audio still works. How can I fix this? I can't play most of my games without sound!
killerrabbit is offline
post #2 of 2 Old 04-28-2011, 10:26 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
Just a couple of thoughts:
*Can you hook up another device to that specific cable and input on the receiver to see if you get audio?
*I can't quite remember off the top of my head, but is there a Dolby Digital on/off option in the 360 menu? Make sure it's on.
*Can you cycle through the inputs on the receiver few times while the 360 is on? Sometimes the HDMI handshake is finicky and requires some "massaging."
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
Reply General Gaming Help
