Problems With Cat5e Cable to Xbox - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-21-2011, 09:07 AM - Thread Starter
cllelectrical's Avatar
We have run a cat5e cable to the Xbox from the router, over the roof, and run it with a TV coax cable. When I use a cable tester is says that the cable is fine and that the ends are in it ok. But when I plug it into a laptop or the Xbox it wont connect to the internet.
Any ideas??
cllelectrical is offline
post #2 of 2 Old 06-23-2011, 05:36 AM
Uronacid's Avatar
Usually this problem is associated with electromagnetic interference, but first make sure your XBOX 360 network card isn't damaged by moving the 360 close to the router and using another Ethernet cable. Also, are you connecting the 360 to a switch or router? If you've setup your network improperly over a switch, then you might not have enough public IP addresses available for your XBOX 360 to connect to the internet.
Usually testers only check for broken pairs, then don't check for EMI. Are you running the cable close to power lines? Are you running the cables over florescent lighting? There are many things that can result in a warped signal over the wire. If that signal is warped, then DHCP packets will not reach the XBOX 360 and you will not receive an IP address.
Uronacid is offline
Reply General Gaming Help
