32" HDTV .. HDMI doesnt look good, would DVI to VGA not go 1920 x 1080? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-14-2011, 11:28 PM - Thread Starter
dark_chiggin's Avatar
I was a fool and bought the 280$ 32" iSymphony,
currently have the HDMI plugged in and it looks like im typing on television screen.. wait a minute, because i AM typing on a television screen!!!!
anyway- the manual says PC use VGA ...
I have a GTX 580 geforce (DVI output)
would going from DVI to VGA still let me be at the 1920 x 1080? Because I will buy the cable right now from newegg if it does..
however, my friend said it wouldnt..
but a monitor this size, I would imagine it would let me go to 1920 x 1080...
(NO the monitor does not have a DVI plug in... only VGA)
(any other options.. or do I have to put this on the shelf as a regular old tv box..)
a friend gave me a DVI to HDMI cable ... but the display would still be in Hdmi...
thanks for the help.
dark_chiggin is offline
post #2 of 4 Old 07-15-2011, 01:18 PM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
So just to clarify, you're currently hooking up your PC to the iSymphoney via a DVi -> HDMI cable? Does it allow you to select the 1920 x 1080 resolution? What exatcly doesn't look good about it?
And just to verify, your TV is 1080p capable, correct?
Regarding the VGA port, not all TV's VGA ports accept a 1920 x 1080 resolution. I looked on iSymphony's website for the manual to you TV, but couldn't find the 32" 1080p model. I looked at the manual for the 42" 1080, and it actually says the VGA port will only accept up to a 1280 x 1024 resolution (page 7):
http://www.isymphonyproducts.com/IM%20LC42iF56.pdf
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #3 of 4 Old 07-15-2011, 10:48 PM - Thread Starter
hey buddy, I appreciate it.. saves me the trouble of worrying about it..
The HDMI is off screen, doesnt have a size scale.. kind of ridiculous that only the "VGA" setting would have a scale option, but meh.. im just gonna let it sit on the other table as a TV upgrade..
it DOES play bluray very well,
but do not recommend for a computer monitor.
post #4 of 4 Old 07-17-2011, 04:30 PM
darklordjames's Avatar
Liked: 94
When making a post like this, giving us the model number of the display makes a world of difference as to whether we can help you.
RonAlam likes this.
darklordjames is offline
Reply General Gaming Help
