What are the best affordable gaming tv's out there LED, PLASMA'S & LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-07-2011, 12:43 AM - Thread Starter
aylmer's Avatar
aylmer is offline
post #2 of 7 Old 09-13-2011, 08:29 AM
Tendoboy's Avatar
I want this answered as well...no hits?
Tendoboy is offline
post #3 of 7 Old 09-13-2011, 05:59 PM
whoizit's Avatar
I too would like to see a good answer to this question. I am still playing my 360/ps3 on a box sdtv and the tv is going out. I have been wanting a good hdtv for gaming for a long time now but have held off since forever out of fear of getting the wrong one and it sucking for my gaming needs,
whoizit is offline
post #4 of 7 Old 09-14-2011, 08:01 PM
joeblow's Avatar
Liked: 233
The question is too open ended. Specify a price range and screen size to get the best help.
Still, I'll post up a list of HDTVs approved by hardcore fighting gamers. A lot of HDTVs have 3+ frames of lag, even in Game Mode, but these all have one frame of lag (16ms) or less. The lower the input lag, the more responsive your games will be:
Panasonic TC-L32X1 - 8-9ms input lag 32" 720p
Samsung LE32C530 - 14ms input lag (Any mode) 32" 1080p (U.S model LA32C530)
Samsung LE32C450 - 16ms input lag 32" 720p (U.S model LA32C450)
Panasonic TX-P42C3B - 16ms input lag 42" 1024×768
Panasonic TX-P42ST30B - 16ms input lag 42" 1080p (U.S model TC-P42ST30)
Panasonic TX-P50S20B - 16ms input lag (Game picture mode) 50" 1080p
Panasonic TX-P42GT20 - 16ms input lag (2D to 3D conversion mode only) 42" 1080p
Panasonic TX-P42VT20B - 16ms input lag (2D to 3D conversion mode only) 42" 1080p
Panasonic TX-P46VT20B - 16ms input lag (2D to 3D conversion mode only) 46" 1080p
LG 32LD450 - 16ms input lag (Game picture mode) 32" 1080p
Los Angeles Lakers - 16 NBA Championships!
joeblow is offline
post #5 of 7 Old 09-17-2011, 12:38 AM
Mr Fusion's Avatar
I see you have a TC-L32X1 listed in your chart with impressive results. How does Panasonic's newer TC-L32X30 (also 720P) compare with that older model as far as input lag is concerned? This is assuming all of the subsequent "X" models were made with the same mentality.
Mr Fusion is offline
post #6 of 7 Old 09-18-2011, 04:27 PM
joeblow's Avatar
Liked: 233
Unfortunately it doesn't work like that. Different models can vary from size to size, let alone model to model from the same company. I can't find any info for you on that set, so you may have to be the gaming guinea pig for the world?
The best suggestion I can give is research to see if the panel inside the model you want is the same panel inside the HDTV from that same company you know has low input lag. It would then be safer to consider that they both have similar input lag numbers before testing it to be sure.
joeblow is offline
post #7 of 7 Old 10-16-2011, 10:25 AM
Badgerst's Avatar
How about the newer sammys? Looking at the u55d8000 line.
Is the lag pretty bad?
Badgerst is offline
Reply General Gaming Help
