AV Newbie... Setup Question - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2011, 11:22 AM - Thread Starter
leroyvegas's Avatar
As part of a new home construction I have an area in the basement that will serve multi-purposes...
- Place for my kids Wii (or some future video game console)
- Golf simulator (driven from a gaming computer)
- Extra screen for Sunday football (via a DirecTV receiver)
I will use a ceiling projector (probably Epson 8350) for the video display for all three of these units and would like to incorp two in-ceiling speakers for audio. Don't need sourround or anything like that.
Not sure what cable/wires to run during construction to give the cleanest finish. Initial thought was to place the Wii console, Gaming CPU, and DirecTV receiver together in back corner of the room and connect appropriate video/audio cables to wall jacks/plates that run through wall/ceiling to projector and speakers respectively. Not sure if this is best way to do this and/or what specific type of cables to use. Thanks for any advice/suggestion.
leroyvegas is offline
Old 09-26-2011, 02:03 PM
Big Wes's Avatar
Sounds like you are going to have a very nice set up when your room is finished. To answer your question, we'll need to know more about your equipment choices. You mentioned your sources, but you didn't mention what sort of receiver you're planning to use. You'll probably want to use a receiver to drive your sound system and change sources. If it was me, I would connect all of the sources to the receiver using the best possible connection (Component for the Wii and HDMI for the gaming PC and the DirectTV and then run every supported type of video out of the receiver to the projector (composite, component, HDMI). This should cover all of your bases.
Cables are cheap enough from a source like Monoprice that you'd be insane not to pull one of everything while you're at it. You don't want to find out after the fact that your projector chokes on 480i over HDMI or something and not have an easy way to switch up your connections from the receiver to the projector. You'll also need to either extend the wire on your existing Wii sensor bar or go with a battery powered replacement.
The cleanest install would be to have your equipment in a dedicated closet or in-wall rack.
TWW resident bullet sponge
PSN: ThreeWulfMoon
Big Wes is offline
