PC Mode + Gaming On Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-10-2012, 08:16 PM - Thread Starter
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
I have a samy Plasma 59d550. Someone mentioned that PC mode made their picture quality better for gaming.
What exactly does PC mode do? I dont see it effecting picture quality or else you would solely use that mode for everything.
And on plasmas input lag is already quite low, so whats the benefit of PC mode and does it increase PQ in gaming?
LanceX is offline
post #2 of 6 Old 01-11-2012, 11:15 AM
volsey's Avatar
My guess would be PC Mode uses the Full RGB Mode (0-256). If you enable PC Mode on your TV, make sure to go into display settings or Nvidia Panel and change the color to 0-256.
This is just a guess though tbh.
volsey is offline
post #3 of 6 Old 01-11-2012, 02:08 PM - Thread Starter
LanceX's Avatar
Quoted: 84 Post(s)
Liked: 30
Hmm on xbox if u set to expanded reference levels it allows full rgb. So i guess pc mode is useless fir xbox n ps3
LanceX is offline
post #4 of 6 Old 01-13-2012, 11:04 PM
N8DOGG's Avatar
Quoted: 978 Post(s)
Liked: 1047
PC mode usually has dynamic mode on, other than that a plasma doesn't really have much use for it lol
N8DOGG is online now
post #5 of 6 Old 01-14-2012, 12:09 AM
JukeBox360's Avatar
Quoted: 12 Post(s)
Liked: 53
The main benefit of putting your tv in PC mode while gaming was to always get lower input lag. Other then that I really wouldn't bother with using that mode.
JukeBox360 is offline
post #6 of 6 Old 02-04-2012, 09:03 AM
jhoff80's Avatar
Quoted: 380 Post(s)
Liked: 334
On my Samsung plasma, I have to switch to a PC mode in order to turn off overscan. It disables a bunch of other options and does also decrease input lag by about 30ms (according to Rock Band 2 calibration).
And I actually do just leave it on PC mode all the time, since I just use the one input on the TV and do my video switching through the receiver.
XBL/Steam: JHoff80
jhoff80 is online now
Reply General Gaming Help
