SD Projector setup for old gaming systems - AVS | Home Theater Discussions And Reviews
post #1 of 2 Old 03-27-2012, 09:41 PM - Thread Starter
Szarach's Avatar
Sorry if this is in the wrong place, I'm fairly new to the forums but this looked like the best spot.
I'm wanting to do a cheap SD projector setup for an N64, Playstation, Snes etc...
Basically when friends come over we tend to pick up some of the classics: Goldeneye, Mario Kart, stuff like that. I'd like to do this as cheap as possible as it will be strictly for old game systems. Can anyone recommend me a projector / screen that would fit my needs for this?
Szarach is offline
post #2 of 2 Old 07-18-2012, 10:01 PM
Yomaster's Avatar
I'm not too knowledgeable when it comes to projectors, but I would assume that any standard definition projector with RCA inputs would allow for this. As for the screen, well, that's pretty much your call.
I'd recommend doing some Amazon/eBay/Google sleuthing and see what you can come up with.
It appears Optoma produces a pretty cheap projector intended for gaming purposes. You can take a look here: http://www.amazon.com/Optoma-PT105-Playtime-Gaming-Projector/dp/B005MXK1ZY/ref=cm_cr_pr_product_top
Hope this helped!
Yomaster is offline
Reply General Gaming Help
