Pc Gaming monitor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-06-2013, 11:15 AM - Thread Starter
LOA5000's Avatar
Hello i am looking at getting a bigger monitor i would like 2560x1440 or 2560x1600. I will be playing mostly battlefield 3. I have a real nice custom desktop with a gtx680. I have rite now a gateway 24inch 2ms 1920x1200. But i would really like to go bigger with the better picture. I found an 30inch lcd apple cinima display localy for 500 dollars used in good condion. hes had it sence 07. Its responce time is 14ms i am thinking maybe that wont be a problem becuase apple makes good products. Anyways what do you think about getting the apple 30 lcd for gaming? 500 dollars doesent seem bad at all.
Any help would be great
Link to product. http://www.amazon.com/Apple-30-inch-Flat-Panel-Display-M9179LL/dp/B0002ILKWM/ref=sr_1_1?ie=UTF8&qid=1357496114&sr=8-1&keywords=apple+30
LOA5000 is offline
Reply General Gaming Help
